Mar 06, 2018, 03:45 PM
DH2 1:12 scale version of Mike Roach's plan
Always intrigued by the 'interesting' configuration of a DH2. ..and with Mikes' generously provided plan.. thought I'd build this one.
Steve 85 cnc'd me a Short kit at 1:12th (reduced scale...28+") Which even at that size will strain my hanger TBH.
Photo of all the cut bits, which are Nicely done and the provided parts index sheet which is Brilliant
None of the burning sometimes found in Laser bits, Nor the use of Too light balsa... grr.
Wood choices are what I would have made.
Thanx Steve.
Just Realised I forgot to photo 4 more sheets of bits .. yet more ribs.
Gonna give my wee EDF project a rest and simply 'build' this one.
Von jaerschky's 2005 build log being a great resource.
https://www.rcgroups.com/forums/show...Mike-Roach-DH2
Starting to wonder about Sourcing 3 or 2.5 mm Carbon tubes for booms.
Wrapped 3mm carbonnes don't seem available in less than 1/4" diameter and if they were.. likely~20/30$ ...each
Place (found it w/ Google) in Missisauga (sp?) has 2.5 mm Pultruded tubes for ~4$.
https://www.google.ca/search?q=canad...hrome&ie=UTF-8
Will have to get onto that.
Mar 06, 2018, 04:37 PM
Summit Model Aeronautics
Steve85's Avatar
Bare,
Glad you like it! I'm along for the ride...
Steve
Mar 06, 2018, 05:34 PM
Come friendly bombs ....
balticS2's Avatar
This will be interesting. I built a polystyrene DH2 - Revell, I think - when I was about 10. I was in the middle of a WW1 fad having seen The Blue Max. I really wanted an FE2B which Biggles started out in, but the DH2 was closest on offer at the time.
Mar 06, 2018, 08:19 PM
Or current resident
glewis's Avatar
I'm in too. Going to be interesting to see how you do all that rigging! Possibly 3D print the engine and guns?
You put down a small EDF build to do a WWI model. I just finished a WWI model and thinking about building a small EDF...
Glenn
Mar 06, 2018, 10:04 PM
We are contrarians Last bipe I assembled was a Flyline Stearman C3b (?) in around 1979 .
Rigging !?. Haven't a clue as to how. But it sure looks as if it will need rigging to keep it all flying in formation.
Carbon booms alone don't seem as enough encouragement.
Not today's problem tho.
ps: I have a printer arriving next week.. UPS willing.
Mar 07, 2018, 12:19 PM
Ken Stuhr
Good luck on this. Shouldn't be too bad. Consider after all, this foamie! I now forget who manufactured this, maybe FMS?, but they wanted you to do the entire rigging job with one continuous piece of line threaded over, under, around and thru, and then again and again!!! Well, I tried but gave up on that idea. Thing is, it flew really well. The takeoffs were so smooth (and the bottom wing so low to the ground) you never were sure when it lifted off. Can't imagine any commercial outfit thinking there was a viable market for this. OH, its an Armstrong Whitworth FK 10.
On the subject, this is a kit very bashed old Kavan DH 2 I did, complete with rotating motor. This flew very nicely. I completely avoided the rigging!!
Mar 07, 2018, 12:47 PM
Very nicely assembled DH... can only hope my effort will be half as pretty.
You really did omit the riggings.... and it clearly works !.
Does make it look a little bit Nekid tbh. However I'm a Big fan of easier.
Interesting sprung axles and wingtip hoops..
You planned for hard landings.. whereas I'm hedging against cartwheels
Still hunting up 3mm tubes..bit of a pain, as None seem locally available, so far.
Seems our friends at Hking are the only easy (?) source
Mar 08, 2018, 10:16 PM
gluing today..
Assembled the fuse.. some steps forward .. a few back as well.
Leaving one's brain in Neutral... even with a Kit, can lead to the cutting of a few replacement parts .
Got it together finally.
Bit of confusion with the plan ensued tho. Differing: versions /scales/ accuracies.
Gonna be some adlibbing required before this one's built.
Another issue is the 1/64 ply turtledeck... although cut Exactly as per plan... ( both hand drawn and Published effort) is too narrow for intended fitment ... Grrrr. As in it's ~3/8 - 7/16"" too narrow .. simply not wide enough to reach either side of the fuse, let alone the overlap fit the plan suggests.
Yesss all the formers are correct... at least as per plan (s) For whatever That's.. worth.
Likely I'll needs be cutting a replacement turtle deck .. just as soon as I draw one that actually Fits.
Who was it that claimed Model making is relaxing ?
edit;
Drew a turtle deck piece... cut a card tester.. seems OK so far.
Card stock is seeming a passable substitute for 1/64 ply.
Gonna give using it some thoughts.
Mar 09, 2018, 09:19 AM
Steve85's Avatar
Hey Bare,
You know what they say about a man with two watches; trying to build a model from two plans has got to be a frustrating experience!
As far as the turtle deck goes, I'll mock up a fuselage this weekend and re-size the turtle deck outline as required for future kits. Interestingly, Frank von J notes in his build that the part fit perfectly, so some precision has been lost somewhere along the way. Thanks for pointing this out, and I'll get it fixed.
Steve
Mar 09, 2018, 10:10 AM
Read / saw Von J's post where his deck piece apparently fit perfectly.
A full 1/2" width change on a 3 1/2" part ?
Biggish error ...to happen inadvertently
However, it's now patched . still needs a bit more work at the gun port end.
Even the Cutout shape is sketchy........ see pix above
Does make me wonder 'whats gonna surface'.. next
Edit;
Surprise!! found another issue... effing ribs ALL of them.. are 15mm Longer than the plan dwg (when leading edge added ..10mm before)
This all ahead of the main spar.
On one hand that means Mo' wing area, onna other it also means I have to draw new Lam wintip jigs as the plan ones no longer apply.
My Profile Book spec sheets for wing Chord being 4'-9" .
Passably similar would be good.
Mar 09, 2018, 08:28 PM
Decided that I'm going to have to plot an Actual Clark Y...
Carve out a pair of Ply templates and sandwich each and every darned rib between the forms... then re cut every rib..
Some fun... But there's No other choice apparent is there?
On a happier note:
Cut out out the templates/jigs for Laminating the wing end bits from 5/16 Foam core (no nor $ store junk)
See pix .
No.. 100 pins nonsense. Just an inner and outer shape with Rubber bands as compressive force.
A simple clean Jig setup
White glue and 2 x 20 sec bursts in the Microwave to seriously cure the glue.
First try was using Reeds.
Will pop it out in a half hour or so to be 100% sure the reed is fully dried.
Mar 09, 2018, 08:40 PM
jumo004's Avatar
Originally Posted by Bare
3 d printing is certainly flavour of the month... lotsa attraction for those eager to get on the bandwagon.
This CAN'T be true !!
Will the real Bare please step forward ?
Better change your password Bare, someone is posting under your name !!!
Mar 09, 2018, 09:25 PM
Steve85's Avatar
Surprise!! found another issue... effing ribs ALL of them.. are 15mm Longer than Either plan dwg (when leading edge added ..10mm before)
Noting that the plans.. Both versions are ...correct...as per the Profile Book spec sheets for wing Chord being 4'-9"
These / my ribs are simply cut wrongly. .. Kindling? Or hours reprofiling them.
Soo much for ... my motivation in buying a Cut kit to get a premade Turtle deck and Cnc'd Ribs.
Both are bungled.. Yipeee!
Bare,
Working from hand-drawn plans is often challenging. In this day of CAD-designed, laser-cut, fool-proof interlocking-parts kits, building a model from hand-drawn plans, even if the parts are CNC-cut, can be an adventure.
When I designed the cutfile for your custom-sized version of the DH2 from Mikeís larger plans, I realized that the wing chord depicted in the top view of the plans didnít correspond to the wing chord as depicted by the rib profiles on the same plan. To facilitate construction directly on the plans, I extended the ribs so that they would match the wing top view, drew the forms for the wing tips accordingly, and included a note in your short kit describing what I had done. You chose to discard the printed copy of the plan I included in the short kit (and the one I cut parts to fit) because it wasnít scale enough and substituted another version you found somewhere else. As a result, the ribs I cut donít match the plan you're using.
Iím sorry youíve had to endure this, and to make things right, as I mentioned in my response to your e-mail earlier today, Iíll cut you a new set of ribs that match the plan you found somewhere else and ship them to you at my cost. I will also refund you the full cost of your short kit and shipping.
Thanks for pointing out the challenges of trying to adapt a kit cut from a hand-drawn plan to a different, much more accurate plan, and for the opportunity to ensure that future versions of this short kit will be better than the one I sent you.
Steve
Mar 09, 2018, 09:51 PM
Wow what a Dull life you must lead.
Mar 09, 2018, 10:11 PM
Dunno what happened. Too many bogus plans floating about
Extending the ribs didn't work overly well
Yess .. a replacement set of ribs would be Great!
Certainly can't be using the ones I have now
ps: if anyone cares the Laminating Gizmo works! beautifully actually.
Download Mike Roach free plans Sopwith Mike Scale Kit/Scratch Built 111 Feb 12, 2019 11:21 AM
Discussion TurnKey RC / Mike Roach Airco DH2 vonJaerschky Scale Kit/Scratch Built 201 Jul 02, 2010 05:41 PM
Video 1/9 Scale Mike Roach Airco DH2 vonJaerschky Electric Plane Talk 8 Jan 11, 2007 02:31 PM
Discussion Rigging a Mike Roach DH2 vonJaerschky Scale Kit/Scratch Built 27 Sep 12, 2006 12:02 PM
Mike Roach/Turnkey RC DH2 Power Question vonJaerschky Power Systems 7 Jun 23, 2004 06:27 AM
