Mar 06, 2018, 01:36 AM
vmaxmasonrya's Avatar
Need help setting up Turnigy 9x
Hi, I am trying to set up dual aileron servos on a new Turnigy 9x. The instruction manual has not given me more info than how to program ail diff. I have plugged the first aileron servo into ch 1 on the receiver. The second (slave) servo, I plugged into ch 5 on the receiver. I just for the life of me cannot find how to program the mix between the two channels on the receiver. I've tried Prog Mx but the instructions do not show how to assign ch 5 as the slave
Vincent
Mar 06, 2018, 10:56 PM
According to the manual https://hobbyking.com/media/file/358697369X13667X46.pdf
you use channels 1 and 7 for ail diff.
If you want the most out of your 9x, flash it with er9x or OpenTX. The easiest way is to use this board: http://smartieparts.com/shop/index.p...roducts_id=383
though there are also ways to DIY.
Mar 07, 2018, 12:52 PM
thanks!
Thanks! this manual gives more info than the one that came from Turnigy. I will try that tonight
Vince
Discussion Setting up a Turnigy 9X for use with RC boats? Kenwhite23 Dock Talk 7 Feb 05, 2018 05:38 PM
Discussion Setting up VARIO altitude on Turnigy 9x with OpenTX Telemetry MOD. brunoneves21 FrSky 0 Mar 26, 2017 03:56 PM
Help! Eachine Racer 250 and Turnigy 9x r/c, can't get rate switch set up lookatmeow Multirotor Drone Talk 2 Feb 23, 2016 12:40 AM
Discussion AHH! I need help setting up my radio (Turnigy 9x) and receiver with arducopter 2.5 maphappy Multirotor Drone Talk 1 Jun 13, 2015 10:15 AM
Help! Need turnigy 9x/flyskyfs-th9x travel settings help Lt1ssteve Radios 0 Jul 20, 2014 02:25 PM
