This thread is privately moderated by Bad Company, who may elect to delete unwanted replies.
Mar 05, 2018, 05:16 PM
Trader Rating: 29
Bad Company's Avatar
$58.00 USD
Seller Pays Shipping
For Sale
ServoCity SPT200H Pan & Tilt System
New
Comes with one New Hitec HS-645. You will need one more hitec servo to complete. Bought this new for a project that i never finished.
New P&T was $47 and Servo was $29
Our SPT200 Direct Drive Pan & Tilt System is perfect for cameras or sensor up to 2lbs. The rigid 1/4 ABS plastic platform and aluminum servo horns on each axis make this compact pan and tilt system very rigid. Each axis is supported by a 1/4 precision ball bearing which allows the servos to handle loads applied from any direction. The 1/4 thru-holes in the top plate make it easy to mount a camera or sensor. The top plate can easily be drilled to accept other attachments if needed. The SPT200 will accept any standard size Hitec or Futaba servo (2 servos are required to assemble the kit). For loads up to 1lb, the HS-485HB or HS-645MG servos work very well. For loads exceeding 1lb, the HS-5685MH works well. For the ultimate in torque and precision, the HS-7950TH is recommended. Units come in kit form with a full set of instructions. Servos are not included and must be purchased separately (please choose the SPT200H if you intend to use Hitec servos; SPT200F if Futaba).
Sold ServoCity SPT200H Pan & Tilt System Bad Company FPV Equipment (FS/W) 0 Oct 04, 2017 09:21 PM
Sold ServoCity SPT200H Pan & Tilt System Bad Company FPV Equipment (FS/W) 0 Feb 26, 2016 09:21 AM
For Sale Immersion EZ AntennaTracker V2 + ServoCity Pan Tilt wamdue FPV Equipment (FS/W) 1 Dec 09, 2015 10:36 AM
Cool Video of ServoCity SPT200 Pan & Tilt System ServoCity ServoCity.com 0 Sep 12, 2011 02:20 PM
Discussion NEW Pan & Tilt System from ServoCity Tech Aerial Photography 23 Jul 26, 2007 07:53 AM
