This thread is privately moderated by vulturetec, who may elect to delete unwanted replies.
Mar 04, 2018, 10:30 PM
ƃuᴉʇɐǝʞ ʇʇoɔs
vulturetec's Avatar
Flight-Time logger for OpenTX/Taranis
This is a simple LUA script I wrote to help keep track of the number of flights and flight time on individual models. The logging data is stored in GVARs and therefore will remain intact as long as the GVARs 8 & 9 (on all flight modes) are not changed. The logger data can be backed up along with the model setup using companion.
The script is intended for fixed wing aircraft, primarily gliders. Flights are automatically counted when the aircraft is above a specified height above the ground for a length of time. The flight ends and the flight time calculated when the aircraft drops below that same height. Alternatively a toggle switch can be used to manually start and stop flights.
Requirements:
  • Originally written for use with OpenTX 2.2.1 on a FrSky Taranis X9D+ it may work on other platforms but has not been tested.
  • For fully automatic operation the script relies on telemetry data from a variometer (VARI-N, VARI-H, or G-RX8) with the sensor's altitude reset before takeoff. In some situations the sensor calibration may cause it to immediately show very high readings at power-up, if that happens the telemetry should be reset immediately or false flight times will be recorded.
  • Manual operation can be configured that will use a toggle switch input instead of altitude.
Limitations:
The flight times currently cannot exceed 1024 hours. This may be revised in future versions. However, the flight counter is not restricted to 1024 flights (it has been tested to over 1,000,000 flights)
Configuration:
The script is loaded on to the SD card into the SCRIPTS/TELEMETRY directory, then a telemetry page needs to be configured to use it.
The first several lines of the script contain variables that can be configured. Multiple configurations are possible by saving the script as a different name, then loading the customized script into individual models as needed.
  • height_trigger = [height] : The height above ground that triggers a valid flight. The value is in the same units that the telemetry reports. For example, if the telemetry is configured to reports and display in feet then set the height trigger in terms of feet.
  • flight_initiate_time = [seconds] : The number of seconds the model must be at or above the "height_trigger" for the flight to start. This should be set to at least several seconds. In manual-trigger mode this specifies how long the toggle must be "on" before the flight is considered "started".
  • flight_terminate_time = [seconds] : The number of seconds the model must be below the "height_trigger" for the flight to end. Like the initiate time, this should be set to at least several seconds. In manual-trigger mode this specifies how long the toggle must be "off" before the flight is considered "ended".
  • display_average_time = [true/false] : The average flight time per flight can be displayed alongside the daily totals. Set this value to "true" to show the average times, "false" to surpress the average time displays.
  • force_manual = [true/false] : Forces the script to use a toggle to manually start and end flights. TRUE uses a toggle (mt_switch must be configured), FALSE uses altitude data. This option is intended to be used with a normal two-position toggle (switch "SF" on the Taranis, for example)
  • mt_switch = "[switch name]" : The toggle switch used when 'force_manual' is on. Example: to use switch SF this line would read mt_switch = "sf"
Log display:
Last Flight: The time of the last flight flown. This line will reset to zeros after powering off the transmitter.
Today: The number of flights and time flown on the current day. The averages show the average minutes/seconds flown.
Last Day: The number of flights and time flown on the last day flights were logged.
Total: The total number of flights and flight time logged.
This is the same data with the average times turned off:
Script:
Note: Much of the embedded comments/documentation lines will by word-wrapped by the forum software. Copying the text and inserting them into a text editor should retain the correct formatting of the code - or just download the zipped .lua.
Code:
-- Flight Logger beta 1.3
-- Simple flight-logger for OpenTX 221 Taranis X9D+
-- Mar-2018 - S.Keating www.scottkeating.net (vulturetec on rcg)
-- Configuration
local height_trigger = 30		-- height that triggers/terminates a flight (in the units the telemetry is set for)
local flight_initiate_time = 6	-- seconds required above the trigger height to initiate a flight
local flight_terminate_time = 7	-- seconds required below the trigger height to terminate a flight
local display_average_time = true	-- toggles the display the average time in decimal minutes
local force_manual = false		-- toggles triggering flights with a manual switch
local mt_switch = "sf"			-- manual switch to use if "force_manual" is toggled on
local altitude				-- altitude
local inflight = false		-- in-flight flag
local inflight_start = 0 	-- in-flight start timer
local inflight_end = 0		-- in-flight end-timer
local flight_count  		-- flight counter
local flightime_start = 0	-- flight time start-time
local flighttime_end = 0	-- flight time end-timer
local flighttime_total		-- flight time total
local flight_time_current = {}	-- current flight time HMS
local flight_time_today = {}	-- today's flight time HMS
local flight_total_time = {}	-- total flight time HMS
local flight_time_last = {}		-- last day's flight time HMS
local atime = {}				-- used for average time calculations
local flight_count_today = 0	-- number of flights today
local flight_count_total = 0	-- total number of flights
local flight_count_last = 0		-- last day's flights
local last_Y = 42			-- row and column positions
local current_Y = 21
local today_Y = 32
local totals_Y = 52
local title_Y = 11
local flights_X = 78
local times_X = 134
local function round(num, numDecimalPlaces)
-- round the value num to the specified decimal places
  local mult = 10^(numDecimalPlaces or 0)
  return math.floor(num * mult + 0.5) / mult
end
local function xbias(xval,fc)
-- bias the x-position to try centering the numbers a little
	local b=0
	if fc>9 then
		if fc>99 then
			b=6
		else
			b=3
		end
	end
	return (xval-b)
end
local function calc_flight_totals(nsets,fc)
-- calculate flight count based on the nset and fc registers
	if nsets<0 then
		nsets = 0
	end
	fc = fc + (nsets * 1024)
	return fc
end
local function creatett(tt,ttarray,rsarray)
-- tt = time value in seconds*100
-- ttarray = 3-element array representing time in h/m/s
-- rsarray = true/false; true=reset array times to zeros
	local fls
	local hh
	local hh1
	local mm
	local mm1
	local ss
	if rsarray then
		ttarray[1]=0
		ttarray[2]=0
		ttarray[3]=0
	end
	local fltot = math.floor(tt / 100)
	hh, mm = math.modf(fltot / 3600)
	mm = mm * 60
	mm, ss = math.modf((mm * 60) / 60)
	ss = (ss * 60) + ttarray[3]
	mm1, ss = math.modf(ss / 60)
	mm = mm + mm1 + ttarray[2]
	hh1, mm = math.modf(mm / 60)
	hh = hh + hh1 + ttarray[1]
	ttarray[1] = hh
	ttarray[2] = (mm * 60)
	ttarray[3] = (ss * 60)
end
local function avgtime(timearray,counts)
-- calculate the average flight time in minutes from the time in "timearray" by "counts"
	local avg = 0
	local avgst = "0:00"
	local mmtime = 0
	atime[1]=0
	atime[2]=0
	atime[3]=0
	if counts > 0 then
		avg = (((timearray[1]*3600) + (timearray[2]*60) + timearray[3])/counts)*100
		creatett(avg,atime,true)
		mmtime = (atime[1]*60) + atime[2]
		avgst = mmtime .. ":" .. string.format("%02d",  atime[3])
	end
	return avgst
end
local function show_time_string(ftarray)
	local fls
	 fls = string.format("%02d", ftarray[1]) .. ":"
	 fls = fls .. string.format("%02d", ftarray[2]) .. ":"
	 fls = fls .. string.format("%02d",  ftarray[3])
	 return fls
end
local function compdates()
-- Compare today's date against the date in memory, matched returns true
-- If the stored DAY is 0 then we force the date comparison to TRUE, which will happen
-- if the gvars for "today's" data is wiped for some reason. In that case the "last day's"
-- data would be unintentionally reset to zeros
	local datenow = getDateTime()
	local mm = model.getGlobalVariable(8,7)
	local dd = model.getGlobalVariable(8,8)
	local retval
	if mm == datenow.mon and dd == datenow.day then
			retval = true
	elseif dd == 0 then
			retval = true
	else
			retval = false
	end
	return retval
end
local function set_gvar_today()
-- store today's date in the GVAR 9, FM7 and FM8
	model.setGlobalVariable(8,7,datenow.mon)
	model.setGlobalVariable(8,8,datenow.day)
end
local function set_gvar_timetoday()
-- store today's flight times in the GVAR 9, FM2, FM3, and FM4
	model.setGlobalVariable(8,2,flight_time_today[1])
	model.setGlobalVariable(8,3,flight_time_today[2])
	model.setGlobalVariable(8,4,flight_time_today[3])
	set_gvar_today()				-- set today's date in memory
end
local function set_gvar_timelast()
-- store today's flight times in the GVAR 8, FM5, FM6, and FM7
	model.setGlobalVariable(7,5,flight_time_last[1])
	model.setGlobalVariable(7,6,flight_time_last[2])
	model.setGlobalVariable(7,7,flight_time_last[3])
end
local function set_gvar_totaltime()
-- store the total flight time in the global variables (GVARs)
	model.setGlobalVariable(7,2,flight_total_time[1])
	model.setGlobalVariable(7,3,flight_total_time[2])
	model.setGlobalVariable(7,4,flight_total_time[3])
end
local function set_gvar_resettoday()
-- reset today's totals (configures a new day)
	-- swap the last day's data to "last"
	model.setGlobalVariable(8,5,model.getGlobalVariable(8,0))
	model.setGlobalVariable(8,6,model.getGlobalVariable(8,1))
	model.setGlobalVariable(7,5,model.getGlobalVariable(8,2))
	model.setGlobalVariable(7,6,model.getGlobalVariable(8,3))
	model.setGlobalVariable(7,7,model.getGlobalVariable(8,4))
	-- configure a new day
	-- set_gvar_today()				-- set today's date in memory
	model.setGlobalVariable(8,7,0)	-- set the date in memory to "0"
	model.setGlobalVariable(8,8,0)
	model.setGlobalVariable(8,2,0)	-- set the flight time totals to 0
	model.setGlobalVariable(8,3,0)
	model.setGlobalVariable(8,4,0)
	model.setGlobalVariable(8,0,0)	-- set the flight counters to 0
	model.setGlobalVariable(8,1,0)
end
local function set_gvar_totalflights()
-- store the total flight count in the global variables (GVARs)
-- the flight count is stored in GV8 FM0 and FM1
	local nsets = math.floor(flight_count / 1024)
	local fc = flight_count - (1024 * nsets)
	model.setGlobalVariable(7,0,nsets )
	model.setGlobalVariable(7,1,flight_count)
end
local function set_gvar_flightslast()
-- store the flight count for the last day in the global variables (GVARs)
-- the flight count is stored in GV9 FM0 and FM1
	local nsets = math.floor(flight_count_last / 1024)
	local fc = flight_count_last - (1024 * nsets)
	model.setGlobalVariable(8,5,nsets )
	model.setGlobalVariable(8,6,flight_count_last)
end
local function set_gvar_flightstoday()
	local nsets = math.floor(flight_count_today / 1024)
	local fc = flight_count_today - (1024 * nsets)
	model.setGlobalVariable(8,0,nsets )
	model.setGlobalVariable(8,1,flight_count_today)
end
local function get_gvar_totaltime()
-- retrieve the total flight time from the global variables (GVARs)
	flight_total_time[1] = model.getGlobalVariable(7,2)
	flight_total_time[2] = model.getGlobalVariable(7,3)
	flight_total_time[3] = model.getGlobalVariable(7,4)
end
local function get_gvar_timelast()
-- retrieve the last day flight time from the global variables (GVARs)
	flight_time_last[1] = model.getGlobalVariable(7,5)
	flight_time_last[2] = model.getGlobalVariable(7,6)
	flight_time_last[3] = model.getGlobalVariable(7,7)
end
local function get_gvar_timetoday()
-- get today's total time from the GVARs
	flight_time_today[1] = model.getGlobalVariable(8,2)
	flight_time_today[2] = model.getGlobalVariable(8,3)
	flight_time_today[3] = model.getGlobalVariable(8,4)
end
local function get_gvar_flightslast()
-- retrieve the total flights from the last day from the GVARs
	flight_count_last = calc_flight_totals(model.getGlobalVariable(8,5),model.getGlobalVariable(8,6))
end
local function get_gvar_flightstoday()
-- retrieve the total flights today from the GVARs
	flight_count_today = calc_flight_totals(model.getGlobalVariable(8,0),model.getGlobalVariable(8,1))
end
local function get_gvar_totalflights()
-- retrieve the total flight count from the global variables (GVARs)
	flight_count = calc_flight_totals(model.getGlobalVariable(7,0),model.getGlobalVariable(7,1))
end
local function manual_trigger()
-- manual flight-trigger toggle check
	local sp = 0
	if force_manual then
		if getValue(mt_switch)>0 then
			sp = 2
		else
			sp = 1
		end
	end
	return sp
end
local function start_flight_trigger(altitude)
-- check for inflight-start status
	local sft = false
	if manual_trigger() == 0 and altitude>height_trigger then
		sft = true
	elseif manual_trigger() == 2 then
		sft = true
	end
	return sft
end
local function end_flight_trigger(altitude)
-- check for inflight-end status
	local eft = false
	if manual_trigger() == 0 and altitude<height_trigger then
		eft = true
	elseif manual_trigger() == 1 then
		eft = true
	end
	return eft
end
local function bg()
	local timediff
	altitude = getValue('Alt')
-- new-flight start-check
	if not inflight then									-- If not already in flight then check for flight-start triggers: new-flights are counted when above height_trigger for at least the specified time
		if start_flight_trigger(altitude) then					-- If the model is above the height_trigger then
			if inflight_start == 0 then						-- set the time the trigger was first detected
				inflight_start = getTime()
				flighttime_start = inflight_start
			else
				if getTime() - inflight_start > flight_initiate_time then 	-- If the start-time has already been noted, then if the model has been above the trigger height long enough count it as a flight
					inflight = true											-- And set "inflight" to true, noting that the model is currently in "a flight"
					flight_count = flight_count + 1
					flight_count_today = flight_count_today + 1
					inflight_end = 0
				end
			end
		else
			inflight_start = 0								-- Any time the altitude is below the trigger_height while not in "a flight" then reset the in-flight start time to 0
		end
	end
-- end-of-flight check
	if inflight then										-- If currently in a "flight", check for flight termination
		if end_flight_trigger(altitude) then					-- a flight terminates when the model drops below the trigger height
			if inflight_end == 0 then						-- and stays below that height for a specified time
				inflight_end = getTime()
				flighttime_end = inflight_end
			else
				if getTime() - inflight_end > flight_terminate_time  then	-- once the specified time elapses,
					inflight = false										-- terminate the flight officially
					-- Calculate the actual flight-time
					timediff = flighttime_end - flighttime_start			-- calculate the length of the flight in seconds
					creatett(timediff,flight_time_current,true)					-- load the current flight time (HMS)
					creatett(timediff,flight_total_time,false)					-- load the total flight time (HMS)
					creatett(timediff,flight_time_today,false)					-- load today's flight time (HMS)
					-- Store the totals in the GVARs
					-- reset variables for the next flight
					inflight_start = 0
					inflight_end = 0
					flighttime_end = 0
					flighttime_start = 0
				end
			end
		else
			inflight_end = 0
		end
	end
end
local function show_current_flighttime()
-- Display the time for the last-flown flight
		lcd.drawText(times_X - 16,current_Y,show_time_string(flight_time_current),0)
	else
		lcd.drawText(times_X - 16,current_Y,show_time_string(flight_time_current),INVERS + 0)
	end
end
local function show_todays_times()
-- Display the total time flown today
	local flc=0
	lcd.drawText(times_X - 16,today_Y, show_time_string(flight_time_today) , 0)
		if display_average_time then
			if inflight then
				if flight_count_today > 1 then
					flc = flight_count_today -1
				end
			else
			end
			lcd.drawText(lcd.getLastPos(),today_Y+1," " .. avgtime(flight_time_today,flc) .. " avg", SMLSIZE)
		end
end
local function show_last_times()
-- Show the last flight day's time
		lcd.drawText(times_X - 16,last_Y, show_time_string(flight_time_last), 0)
			lcd.drawText(lcd.getLastPos(),last_Y+1," " .. avgtime(flight_time_last,flight_count_last) .. " avg", SMLSIZE)
		end
end
local function show_total_flighttime()
-- Show the total flight time
		lcd.drawText(times_X - 16,totals_Y, show_time_string(flight_total_time), 0)
end
local function show_flights()
-- total flights
	lcd.drawText(xbias(flights_X,flight_count), totals_Y, flight_count, 0)
end
local function show_todays_flights()
-- Display the number of flights today
	lcd.drawText(xbias(flights_X,flight_count_today), today_Y, flight_count_today, 0)
end
local function show_last_flights()
-- Display the number of flights from the last flight day
	lcd.drawText(xbias(flights_X,flight_count_last), last_Y, flight_count_last, 0)
end
local function show_headers()
	local minfo = model.getInfo()
	local mname = minfo.name
	local hdrline = mname .. " Flight Log"
	local sp = 18 - (math.floor(string.len(hdrline)/2))
	local rp
	local lp
	-- TOP TITLE
	lcd.drawText(1,1,string.rep(" ",(sp*2)),0)
	lp = lcd.getLastRightPos()
	lcd.drawText(lp,1,hdrline, 0)
	rp = lcd.getLastRightPos()
	lcd.drawLine(rp-1,9,lp,9,SOLID,FORCE)
	lcd.drawText(flights_X - 11,title_Y,"Flights",0) -- Total Flights TITLE
	lcd.drawText(times_X - 11,title_Y,"Time",0)		 -- Total time TITLE
	-- Row headers
		lcd.drawText(1,current_Y,"Last flight",SMLSIZE)
	else
		lcd.drawText(1,current_Y,"Last flight",INVERS + SMLSIZE)
	end
	lcd.drawText(1,today_Y,"         Today",SMLSIZE)
    lcd.drawText(1,totals_Y,"         Total",SMLSIZE)
	lcd.drawText(1,last_Y,"    Last Day",SMLSIZE)
end
local function configuretoday()
-- configure the setup for today
	if not compdates() then		-- if the stored date isn't today then do...
	end
	get_gvar_flightstoday()		-- set today's flight counter
	get_gvar_timetoday()		-- set today's times
end
local function checkinit()
	if model.getGlobalVariable(7,4)==1025 and model.getGlobalVariable(7,3)==1025 and model.getGlobalVariable(7,4)==1025 then
		for a = 7,8 do
			for b = 0,8 do
				model.setGlobalVariable(a,b,0)
			end
		end
	end
end
local function init()
-- init function
	checkinit()
	flight_time_current[1]=0
	flight_time_current[2]=0
	flight_time_current[3]=0
	atime[1]=0
	atime[2]=0
	atime[3]=0
	flight_initiate_time = (flight_initiate_time * 100) - 1
	flight_terminate_time = (flight_terminate_time * 100) - 1
	configuretoday()
	get_gvar_timelast()
	lcd.clear()
end
local function run(event)
	lcd.clear()
	show_headers()
	show_flights()
	show_todays_times()
	show_last_flights()
	show_last_times()
end
return { run=run, background=bg, init=init}
Mar 11, 2018, 11:33 AM
Alt+24=↑ Alt+25=↓ Use num keys
Miami Mike's Avatar
Originally Posted by vulturetec
This is a simple LUA script I wrote...
Nice job! I'm sure people are wondering what one of your more complex scripts would look like.
Note: Much of the embedded comments/documentation lines will be word-wrapped by the forum software. Copying the text and inserting them into a text editor should retain the correct formatting of the code...
A good way to handle that is to use block comments, which are comments beginning with an opening level zero long bracket ("--[[") and ending with a corresponding closing long bracket ("]]"). The following entire block can be pasted into a script with no effect:
Code:
--[[ This is a comment in a Lua script.
It doesn't matter how many lines the comment has,
all of this text will be ignored until the closing
long bracket appears, which looks like this: ]]
Or if desired it can be done
like this, with the brackets
occupying lines of their own.
If you like, you can even make the closing
long bracket a mirror image of the
opening bracket, like this:
... but keep in mind that if you do that, any text
after the closing bracket on the same line will
also be ignored. In other words...
]]-- this text will also be ignored.
Mar 11, 2018, 04:26 PM
ƃuᴉʇɐǝʞ ʇʇoɔs
vulturetec's Avatar
I didn't know about the brackets, thanks for that, Mike!
Here's my log screen after FSS #2 today.
I had one really horrid 1:37 round, and one in the 4:30 range. With my logger triggering at 30ft it adds some time at launch and drops some landing - but the automatically logged results are still pretty close.
Oct 17, 2018, 08:26 PM
W.F.G.D
jbitz's Avatar
Vulturetec.
You mentioned "altitude reset" on the G-RX8, I have searched all over for a "how to" on that very item. Can you point me in the right direction.
John
Oct 19, 2018, 01:39 PM
ƃuᴉʇɐǝʞ ʇʇoɔs
vulturetec's Avatar
John - I just answered in the other thread... but I'll add here, the altitude/vario are reset/zeroed by holding the enter key for a couple of seconds, then select "reset", then "reset telemetry". This works to zero the GPS distance calculation too.
Apr 07, 2019, 08:00 AM
Optimized for taranis qx7/s:
Thank you for sharing!!! Nice job!!! I don't fly gliders a lot but I love big helis! And the logger is ideal to keep track of the flights because after a number of
flights you should maintain your heli.
Apr 07, 2019, 11:32 AM
ƃuᴉʇɐǝʞ ʇʇoɔs
vulturetec's Avatar
Neato, glad it works there too. Thanks for the optimized version update!
Jan 21, 2020, 11:07 AM
ƃuᴉʇɐǝʞ ʇʇoɔs
vulturetec's Avatar
OpenTX LUA Flight Logger v1.4 update
Jan 20 2020 update - Logr v1.4
A couple of small updates from v1.3
Updates:
  • The last flight date is now displayed: The last day's flight count and times are titled with the date of the last flight
  • A logical switch can be used to toggle manual-logging: A value stored in a logical switch can be used to toggle between logging via a switch or altimeter making it easy to switch between the two via the radio (largely eliminates the need to edit the script itself)
  • A * will now appear at the end of the top title line when manual-switched logging is forced on. The lack of a * indicates altitude-sensed logging is on
Configuration updates/additions:
  • force_manual = [true/false] : Update note: unchanged from v1.3. This function is made somewhat obsolete with the logical_switch toggling, however a "true" value here will effectively disable the logical_switch functionality.
  • logical_switch = [open logical-switch number] : assigns the logical-switch used to toggle between manual logging and altitude-sense logging.
    The logical switch should be set up as
    • function = a=x
    • v2=0 for altitude sensing
    • v2=1 for manual switching (the same as setting "force_manual=true"
  • dateformat = [0/1] : changes the format of the last day's date
    • 0=mm-dd
    • 1=dd-mm
Note: As before, much of the embedded comments/documentation lines will by word-wrapped by the forum software. Copying the text and inserting them into a text editor should retain the correct formatting of the code. Notepad++ is recommended - it will format and display the lua properly.
Code:
-- Flight Logger beta 1.4
-- Jan-2020 - Updated 	> v1.4
--						> The display now shows the last date flown instead of 'last day'
--			  			> A logical switch can be used to toggle the manual trigger function ("force_manual") from the radio
--						> 	programming, eliminating the need to hard-code force_manual
--						> When manual-switching is forced on a * will appear at the end of the telemetry screen's title line
-- Configuration:
-- height_trigger = [height] : 	The height above ground that triggers a valid flight.
--								The value is in the same units that the telemetry reports.
--								For example, if the telemetry is configured to reports and display  in feet then set the height trigger in terms of feet.
-- flight_initiate_time = [seconds] : 	The number of seconds the model must be at or above the "height_trigger" for the flight to start.
--										This should be set to at least several seconds. In manual-trigger mode this specifies how long the toggle
--										must be "on" before the flight is considered "started".
-- flight_terminate_time = [seconds] : 	The number of seconds the model must be below the "height_trigger" for the flight to end.
--										Like the initiate time, this should be set to at least several seconds.
--										In manual-trigger mode this specifies how long the toggle must be "off" before the flight is considered "ended".
-- display_average_time = [true/false] : 	The average flight time per flight can be displayed alongside the daily totals.
--											Set this value to "true" to show the average times, "false" to surpress the average time displays.
-- force_manual = [true/false] : 	Forces the script to use a toggle to manually start and end flights.
--									TRUE uses a toggle (mt_switch must be configured), FALSE uses altitude data.
--									This option is intended to be used with a normal two-position toggle (switch "SF" on the Taranis, for example)
-- dateformat = [0/1] :				Format of the last day's flight date. 0 = mm-dd, 1 = dd-mm
-- mt_switch = "[switch name]" : 	The toggle switch used when 'force_manual' is on.
--									Example: to use switch SF this line would read mt_switch = "sf"
-- logical_switch = [switch #] :	Toggle height-trigger vs manual trigger using this logical switch slot
--									To use it, set the logical switch function to a=x then set v2 to anything greater than 0,
--									from then on the manual function can be toggled on/off in the radio by just changing v2
local force_manual = false		-- toggles forcing triggering flights with a manual switch
local dateformat = 0			-- 0 = "mm-dd", 1 = "dd-mm"
local logical_switch = 40		-- logical switch (LS) used in place of force_manual
-- script variables
local today_Y = 32
local totals_Y = 52
local title_Y = 11
local times_X = 134
end
	local b=0
	if fc>9 then
		if fc>99 then
			b=6
		else
			b=3
		end
	end
	return (xval-b)
end
	if nsets<0 then
		nsets = 0
	end
	return fc
end
	local fls
	local hh
	local hh1
	local mm
	local mm1
	local ss
	if rsarray then
		ttarray[1]=0
		ttarray[2]=0
		ttarray[3]=0
	end
	mm = mm * 60
	ttarray[1] = hh
end
	local avg = 0
	local mmtime = 0
	atime[1]=0
	atime[2]=0
	atime[3]=0
	if counts > 0 then
	end
	return avgst
end
-- format the ftarray into a nice formatted string for display
	local fls
	 return fls
end
-- data would be unintentionally reset to zeros.
	local retval
			retval = true
	elseif dd == 0 then
			retval = true
	else
			retval = false
	end
	return retval
end
end
end
end
end
	model.setGlobalVariable(6,7,model.getGlobalVariable(8,7))
	model.setGlobalVariable(6,8,model.getGlobalVariable(8,8))
	--model.setGlobalVariable(8,7,0)	-- set the date in memory to "0" old code
	--model.setGlobalVariable(8,8,0)	-- old code
end
end
end
end
end
end
end
end
end
end
local function getls()
	local ls = model.getLogicalSwitch(logical_switch - 1)
	local retval = false
	if ls.v2>0 then
		retval = true
	end
	return retval
end
local function check_sensor()
-- check to see if altitude sensor exists
-- if it doesn't, then set force_manual to true
-- initially if the force_manual flag is true then don't do anything
	-- if the logical switch (v2) is more than 0 then set force_manual to true
	if force_manual == false then
		if getls() == true then
			force_manual = true
		end
	end
	-- check for the sensor. If there isn't an alt sensor then set force_manual to true
	-- reserved for future implementation
end
	local sp = 0
			sp = 2
		else
			sp = 1
		end
	end
	return sp
end
	local sft = false
		sft = true
		sft = true
	end
	return sft
end
	local eft = false
		eft = true
		eft = true
	end
	return eft
end
local function bg()
	local timediff
			else
					inflight_end = 0
				end
			end
		else
		end
	end
			else
					inflight_start = 0
					inflight_end = 0
					flighttime_end = 0
				end
			end
		else
			inflight_end = 0
		end
	end
end
	else
	end
end
	local flc=0
			if inflight then
				end
			else
			end
		end
end
		end
end
end
-- total flights
end
end
end
-- Show the title and line headers
	local rp
	local lp
	local mm = model.getGlobalVariable(6,7)
	local dd = model.getGlobalVariable(6,8)
	local dStr = "-----"
	-- Add a * to the end of the title line if manual switching is on
	if force_manual == true then
		hdrline = mname .. " Flight Log*"
	else
	end
	-- TOP TITLE
	-- Row headers
	else
	end
	if mm == 0 or dd == 0 then
		dStr = "-----"
	else
		if dateformat == 0 then
			dStr = string.format("%02d",mm) .. "-" .. string.format("%02d",dd)
		else
			dStr = string.format("%02d",dd) .. "-" .. string.format("%02d",mm)
		end
	end
	lcd.drawText(1,last_Y,"        " .. dStr,SMLSIZE)
end
-- configure things for today
	end
end
-- reserves the GVARs in flight modes FM6-8 for our use
	for a = 6,7,8 do
		for b = 0,8 do
			if model.getGlobalVariable(a,b)==1025 then
			end
		end
	end
end
-- init function
	checkinit()
	atime[1]=0
	atime[2]=0
	atime[3]=0
	configuretoday()
	get_gvar_timelast()
	check_sensor()
	lcd.clear()
end
	lcd.clear()
	show_headers()
	show_flights()
	show_todays_times()
	show_last_flights()
	show_last_times()
end
Jan 31, 2020, 07:04 PM
Variant for gas/glow flight
The script here provided a ton of inspiration for me to do a similar one, also incorporating battery usage in gas/glow. Yep, I stole a few bits of code for the screen lay-out!
Read all about it here: https://www.rcgroups.com/forums/show...w#post43723497
Thanks for the excellent work!
(And to other readers - I would strongly suggest using the original!)
Feb 01, 2020, 02:49 PM
ƃuᴉʇɐǝʞ ʇʇoɔs
vulturetec's Avatar
Thanks sandet!
Jun 03, 2020, 02:06 AM
Hi,
Great lua, but i use it on my x-lite, is there a way to fit al the data an the small screen? Or should i use the Q7 version?
Jun 03, 2020, 07:38 AM
ƃuᴉʇɐǝʞ ʇʇoɔs
vulturetec's Avatar
I have no experience with that radio. If the Q7 version doesn't fit then it could be redesigned with other information blocks dropped - for example, just "today's" and "total" time could be shown.
Discussion FrSky Taranis, Taranis Plus, Taranis E - OpenTX 2.1.X Jet_Flyer Radios 7359 Nov 08, 2021 08:23 AM
Discussion FrSky - We need a Taranis for Surface Radios with OpenTx! Thorvald Radios 21 May 03, 2019 05:04 AM
Discussion Migrate models from Taranis (OpenTx 1.?) to Taranis Plus (OpenTx 2.2.0) Mr Rowl FrSky 1 Aug 23, 2017 08:33 AM
FAQ Resources for FrSky Taranis and OpenTX scott page FrSky 28 Mar 15, 2014 06:00 PM
