Mar 01, 2018, 02:34 PM
Marion
Question
Binding Left in During Flight
Does leaving the binding plug in the receiver cause problems during flight? My friend keeps losing bind when changing flight batteries. His solution was to leave the binding plug in the receiver, and rebind after each batter swap. That means he is flying with the binding plug still in the receiver. So, does that cause flight problems. ?
Don't ask why he doesn't doesn't do it "right". It is a really long story :-(
TIA
Marion
Mar 01, 2018, 02:36 PM
AndyKunz's Avatar
If he ever experiences a brown-out in flight (momentary low voltage, usually caused by poor BEC-to-servo-power match) then the receiver will go into bind mode in the air, and his model will crash.
He should send his receiver and transmitter for Service to review.
Andy
Mar 01, 2018, 02:40 PM
Marion
Thanks Andy. I think I knew that. He is having some memory problems. He had this identical problem before and can't remember it. :-( :-( Is there, or are there, other problems as well??
I'll pass along your comments.
Mar 01, 2018, 03:15 PM
Rx / Tx should not lose the bind on a power cycle unless something is wrong with either Tx or Rx. He should get this fixed - and he should not fly with the bind plug attached.
Help! APM Tricoper yaws left while in backwards flight. dynam Tricopter Drones 3 Sep 22, 2016 03:19 PM
Help! Ares Ethos QX130 - front left LED dislocated/detached during crash yingjie Mini Multirotor Drones 1 Mar 12, 2016 04:32 PM
Discussion tri is rolling left when I yaw right during a banked turn.....KK2.1 rcminiman Tricopter Drones 12 Sep 30, 2015 01:00 PM
Help! V120D01 is drifting left during flight, altering trim by itself. rcminiman Micro Helis 7 Jan 03, 2014 06:51 PM
Discussion Should I use my Bind/Data port during flight? sendittokeith Beginner Training Area (Aircraft-Electric) 1 Jan 08, 2012 02:15 PM
