Feb 28, 2018, 08:00 PM
ı ɐɯ uoɹɯɐן
Curtis in Texas's Avatar
Contest
The March Big Sky, Anyone can enter, Informal Soaring Contest
THE MARCH BIG SKY INTERNATIONAL
LONGEST DURATION CONTEST FOR ALL ELECTRIC AND HAND LAUNCHED GLIDERS, THERMAL SOARING, AND SLOPE SOARING -
RULES AND INFO:
Contest will run from 12:01 am March 1st to 11:59 PM March 31st Eastern US time. The contest is for ALL electric or hand launched gliders or airplanes of all sizes, all materials and all controls. The contest is intended to help motivate you to develop your thermal and slope soaring skills. The contest is open to all gliders, e-gliders and, if you like, e-airplanes too. If it glides, it qualifies.
In Thermal Duration, the contest is split into three classifications; 2 Meter and under E Gliders, Open E Gliders, and Hand Launch Gliders.
You can post as many times as you like using as many planes as you like, but only one will be counted per pilot per category regardless of what kind of plane you are flying. You can replace a shorter time with a longer time any point during the contest. You can fly as many flights as you like.
Goal - longest duration thermal and slope flights without use of the motor.
THE PLANES
* Any electric motor system or unpowered hand launch glider. (No winches or Hi-Starts).
* Any wing controls and any wing span
* Any construction
ELECTRIC GLIDER SOARING
1) From a fresh hand or ground launch you can run the motor for up to 30 seconds, then you turn the motor off and you can not restart it. Reclimbs are not permitted. If you restart the motor the flight time is no good.
2) Motor time starts as soon as you apply throttle. This is an LMR, Limited Motor Run contest with a pretty long motor run allowed so that the motor run itself does not provide much advantage to anyone. Many will choose to shut off the motor in less than 30 seconds. No credit for shorter motor runs.
3) Soaring time starts when the motor goes off. Either you time the whole flight and subtract the motor run or you use two watches, one to time the motor run and one to time the flight. How you do this is up to you.
4) You can time your own flight if you wish. You are on your honor. Time is truncated to the second. No fractions and no rounding. Read the seconds only.
5) Landing must be within 100 feet of the original launch location or the flight does not count. Landing must be on the ground/grass or pavement. Landing in a tree, bush, structure or other elevated spot that would not normally be a landing spot does not count. There are no other rules around the landing.
6) Time stops when the glider comes to a rest. So the clock keeps running if you clip a branch, or go to land and bounce back into the air. When the plane stops, time stops.
7) You can launch as many times as you like but each flight has to be from a fresh launch from the ground/hand. No reclimbs permitted.
8) Report your best time of the day by posting here. You can post as many times as you like, but only the best one will count. You can fly as many days as you like to work toward your best time. The goal is to achieve personal bests in the fun atmosphere of a contest.
HAND LAUNCH SOARING
1) Soaring time starts at release of the plane.
2) You can time your own flight if you wish. You are on your honor. Time is truncated to the second. No fractions and no rounding. Read the seconds only.
5) Landing must be within 100 feet of the original launch location or the flight does not count. Landing must be hand catch or on the ground/grass or pavement. Landing in a tree, bush, structure or other elevated spot that would not normally be a landing spot does not count. There are no other rules around the landing.
7) You can launch as many times as you like but each flight has to be from a fresh launch.
SLOPE SOARING
1) From a fresh hand or ground launch you can run the motor for up to 5 seconds, if you need it to get into the lift. I would expect most slope flights will have no motor run but some sites need a boost to the lift.
2) Motor time starts as soon as you apply throttle and is subtracted from the total flight time.
5) Landing has to be within 100 feet of the original launch location or the flight does not count. Landing must be on the same level as the launch. Landing down the slope or up in the trees does not count. You must come to rest in a "normal" landing spot and be able to walk over and pick it up. I realize this can vary by slope site so you are on your honor as to whether this was a normal landing.
7) You can launch as many times as you like but each flight has to be from a fresh launch from the ground or hand. No powered reclimbs permitted. If you restart the motor the flight does not count.
8) Report your best time of the day by posting here. You can post as many times as you like, but only the best one will count. Try as many days as you like to get your best time of the month.
For either contest you report the results via post.
REPORT FORMAT
Your Name - Real or RCGroup Name - your choice
Glider/plane name and wingspan:
E Glider, Hand Launch or Slope:
Date and Time of flight:
Duration of flight:
Comments - You are welcome to report anything you like about the day, the flight. Pictures, videos, gps plots, etc are welcome but not required.
I will maintain the thread and keep the second post updated with the top 3 flight durations from each Class. Only one flight of each type will be recorded in the standings for each pilot. A new, better time will replace the previous one.
ALL-TIME CONTEST RECORDS
2 Meter and under E Glider Class
Andy Grose (dee-grose)
Glider name:Radian
Thermal or Slope: Thermal
Date and Time of flight:April 19, 2012 11:20am
Duration of flight:1:38:04 (after 30 sec motor run)
Max Altitude: 3028ft AGL
Open E Glider Class
MrE / Larry
Sailplane: Bubble Dancer
Date and Time of flight: 13 October 2013 2:30PM
Duration of flight: 1 hr 52 minutes 37 seconds
Weather: Mostly clear, +55F, light variable winds
Hand Launch Class
xStatiCa (Adam)
Glider Binary IV DLG (1.5m)
May 14th, 2015
Time 5:48pm
Duration 75:49
New Port Richey, FL
Slope Class
744Drv
Sailplane: Radian Pro 2m
Discipline: Slope
Date time of launch: 26 Nov 12:57
Place: Lookout Hill overlooking Discovery Bay, Hong Kong
Conditions: E 5-10kts
Duration: 3 hrs 2 mins
Feb 28, 2018, 08:04 PM
ı ɐɯ uoɹɯɐן
Roger
Glider name:Radian
Date and Time of flight: March 27,2018 Around 11AM
Duration of flight:21:53(after 30 sec motor run)
Matt D
Plane: Radian
Date: 3/16/18
Temp: 35 and sunny
Flight time: 20:06 after 25 second motor run
Ernie B
1.5 meter e-powered Sunbird by Dave Thornburg
Thermal
Mar 10, 11:48 hrs
Duration: 11:42 (after 24 sec motor run)
36F Winds from the East at 5 mph, mostly sunny.
No real thermals, but rode the ridge lift off the trees at the East end of the field.
Open E Glider Class
AMA69405
Aether 3.7M
E Glider - Open
Mar 28 2018 - 1430 hrs CST
23 min 15 sec (after 28 sec motor run)
Dexter, Kansas USA
49 deg F, Wind Variable 2-4 mph
Hand Launch Class
Slope Class
Pilot name: Jan
Glider name: MPX Solius - 2200 mm
Thermal or slope: slope
Date and Time of flight: 25th March 2018, 14:00-15:30
Duration of flight: 71:03
Current thru #31
Mar 02, 2018, 06:22 PM
ı ɐɯ uoɹɯɐן
Curtis
standard Radian
Thermal
Mar 2, 1630hrs
Duration: 11:01 (after 28 sec motor run)
Temperature:72
Humidity:47
Wind Speed :5
Direction:East
Not really thermals, just kinda general lift with a couple noisy *** 40% 3Ders flyin nearby while I'm staring up.
It's all good, they asked before flying since I was on the line 1st.
Mar 02, 2018, 09:50 PM
3RN13
ernie b's Avatar
Spring is just around the corner!
Ernie
Mar 03, 2018, 09:21 AM
Pilot name: Jan
Glider name: Hai 1 Evo - wingspan about 1500 mm
Date and Time of flight: 3rd March 2018, 11:00-12:00
Duration of flight: 22:20
Quite cold (-7 C, about 20 F), very light wind - not strong enough to keep the 1 lb wing in the air, on the other hand this was just good due to low temperature, otherwise a nice sunny day with a lot of thermals (and sinks as well). I went for slope flying and ended up with thermalling. I did fly three flight on 5 seconds motor run, resulting in 22, 9 and 21 minutes.
Thanks, Curtis, for organizing this, and wish long flights to all participants, Jan
Mar 03, 2018, 09:36 AM
ı ɐɯ uoɹɯɐן
You're welcome Jan, it's my pleasure.
Good to see slope entry for a change.
Mar 04, 2018, 10:26 PM
mdickey's Avatar
I have been practicing for F3RES lately. Will be out with the Calypso tomorrow!
Mar 07, 2018, 08:03 PM
Gary L
After two consecutive days and nights of extreme winds (my anemometer was showing steady 40-ish mph and 50+ gusts yesterday afternoon), it started to get back to normal today. By six this evening, it was downright calm, compared to what we had been experiencing, so I went out for a quick flight just because I could. No significant lift (a couple of blips at 2 to 3 minutes in ) but also no sink, and the prop was obviously getting a good bite on the launch, so...
AMA69405
Aether 3.7M
E Glider - Open
Mar 07 2018 - 1800 hrs CST
12 min 13 sec (after 28 sec motor run)
Dexter, Kansas USA
48 deg F, Wind NW 5-9 mph
Mar 09, 2018, 10:56 PM
ı ɐɯ uoɹɯɐן
And I get frustrated with 1 day of "high" winds touching the twenties. It's all relative . . .
Poor Ernie is still waiting for the thaw while the foliage here began budding 2 weeks ago.
Mar 09, 2018, 10:59 PM
ı ɐɯ uoɹɯɐן
Calypso .. blah blah blah, tomorrow .. blah blah blah. We're still waiting for a report.
Mar 10, 2018, 08:05 AM
3RN13
ernie b's Avatar
Good Morning Curtis
Might be cold & windy here, but we have been flying all Winter long. Mostly just testing and tuning new builds and getting ready for the Woodcrafters event in Muncie, IN. June 1-3.
I've also designed some new funfly contests for the Manville group like LMR 6 minute precision time and distance, LMR MOM double elim thermal and LMR MOM double elim spot landing.
With all that going on I must confess I have not given this contest the effort it deserves, sorry!
Ernie
Mar 10, 2018, 02:26 PM
3RN13
ernie b's Avatar
Hey guys after beating myself up for not contributing more on this thread / contest, I decided oh what the heck, lets try it today.
Ernie B
Thermal
Mar 10, 11:48 hrs
Ernie
Mar 10, 2018, 05:26 PM
Gary L
Open E Glider Entry
Nice early spring conditions with very little wind, sunshine getting through high thin cloud cover all day... we got in 9 or 10 flights. No real boomers found, but enough here and there on this one flight to log nearly double the time we logged a few days ago. Notice the next flight though, on the chart below... what a letdown!
AMA69405
Aether 3.7M
E Glider - Open
Mar 10 2018 - 1500 hrs CST
22 min 09 sec (after 28 sec motor run)
Dexter, Kansas USA
68 deg F, Wind SE 3-5 mph
Mar 12, 2018, 05:44 PM
Gary L
No improvement on my last flight, but there should have been... I had to bring it down prematurely due to watering eyes and generally bad vision. It's Hell to get old. Notice the spin-down to lose about 400 ft of altitude, 3 minutes after motor cutoff... I had already lost sight of the plane once, decided I needed to be closer to it.
But why am I posting, you ask? Just had to show you what was probably the strongest thermal I've seen hereabouts for quite a while. Add the nominal sink rate of the plane to this, and you've got at least 12 ft/sec air. Only about 50 degrees F, but strong sunshine all day, with this being a 1630 hrs CDT flight. Damned shame it was a wasted piece of air.
Mar 13, 2018, 09:25 AM
3RN13
ernie b's Avatar
I guess I would take heart in the fact that you read the air correctly and launched into a thermal. Nice job!
Ernie
Contest The December Big Sky, Anyone can enter, Informal Contest Curtis in Texas Electric Sailplanes 17 Dec 25, 2017 12:14 PM
Contest The November Big Sky, Anyone can enter, Informal Contest Curtis in Texas Electric Sailplanes 46 Nov 30, 2017 09:46 AM
Contest The October Big Sky, Anyone can enter, Informal Contest Curtis in Texas Electric Sailplanes 57 Oct 25, 2017 05:46 PM
Contest The September Big Sky, Anyone can enter, Informal Contest Curtis in Texas Electric Sailplanes 37 Oct 01, 2017 11:58 AM
Contest The August Big Sky, Anyone can enter, Informal Contest Curtis in Texas Electric Sailplanes 57 Sep 04, 2017 12:33 PM
