Feb 25, 2018, 12:38 PM
scared to fly
Ezuhf MinimOSD RSSI/LINK
From last several days I am trying to get RSSI or LINK quality read out in my minim osd display. But its not showing.
I am following this video tutorial from DIY drones...available in you tube.
Setup EZUHF RSSI on MinimOSD for APM or Pixhawk (18 min 58 sec)
My set up:
Apm 2.8
Ezuhf:8channel diversity ,with latest firmware. Link quality is on channel 8. The setup is PPM muxed with single servo connection with FC.
Tx>Ezuhf 2watt.
Transmitter: taranis Qx7
I am not using telemetry...only minim osd.
Everything is working fine. Ezuhf is bound and working...all flt mode and failsafe function working. But Like the video I just cant get any RAW values in screen ,it always read "0". If I change the channel for Link quality to channel 7 in Immersion RC tools then the RSSI value becomes 99%. But they are all unaffected by anything I do .They do not change whether Tx is on or off.
I have exactly followed the video....at least 50 times without result......mmosd firmware was also changed to R800 and R820 without any difference.
Till now no Raw data....pulling my hair out...help me please.
Feb 26, 2018, 10:37 AM
scared to fly
any body with solution plz. Do you need any further information??
Oct 17, 2018, 08:44 AM
have you found a solution? mine is showing as 1500% constantly
Oct 17, 2018, 02:27 PM
scared to fly
Yeah it’s working.
Max raw value 1800 min 1000 with pixhawk
Oct 17, 2018, 04:09 PM
did you get it to work with APM?
Oct 18, 2018, 12:36 PM
scared to fly
unfortunately no.I did the same thing in APM too...but it never worked. RSSI was a fixed 99 without any change.Surprisingly it worked without a hitch in pixhawk.
Oct 18, 2018, 01:07 PM
thanks for sharing! I think I am going to try to do it by converting to analog.
Help! Get RSSI from XSR to MinimOSD igorbogu FPV Equipment 0 Feb 18, 2018 05:13 AM
Discussion ezuhf 8 channel lite + RSSI output to MinimOSD with CPPM and a pin out? markm75 FPV Talk 5 May 14, 2016 12:18 AM
Help! rssi and link vector and ezuhf gkyle840 FPV Equipment 2 Feb 02, 2015 04:21 PM
Discussion EZUHF LINK and RSSI, what do the values mean Rogue.insight FPV Equipment 3 Nov 13, 2014 08:48 AM
