Futaba 9chp super main board PPM signal - RC Groups
Feb 25, 2018, 10:29 AM
Tarzanstyle English Sorry
AgoMago's Avatar
Question
Hi all
I'm trying to put a turnigy module inside my futaba 9c , but I want to maintain the original 40 mhz module outside.
I try to find the right cabels to use them to commute from one module to the other by a two way commutator.
I think I find + and - and the ppm signal only where the original futaba module go in...(and between this pin and the main board there are other components)
I want to know where the ppm signal come from the main board.
In the photo attached there are several cables coming from the main board..I think I've discovered that but I'm not sure:
From the top:
-Yellow: V+ from the battery pack
-Blue: V+ from the main board (the one I want to commute from one module to the other)
-Brown: ?
-Orange: PPM from the main board (?) (the one I want to commute from one module to the other)
-Green: ?
-Grey :?
-Lillac : V- ground (I want to leave connected permanently with both module)
Can somebody confirm it?
Thank you in advance.
Ago
Mar 01, 2018, 11:40 AM
AgoMago's Avatar
Problem Solved
OK after a lot of searching I find a way to connect the turnigy module.
Following the suggeston of The Don in this post https://www.rcgroups.com/forums/show...&postcount=620 , my radio now can transmit via 40 mhz or via 2,4 mhz with internal Turnigy module.
Thanks again Don .
Ago
Discussion Futaba T7CHP PPM signal? policeman0077 Radios 0 Dec 04, 2015 09:32 PM
Discussion How to pull up the amplitude of the HRS / PPM signal from a Futaba RX? micke_b DIY Electronics 1 Sep 29, 2009 08:25 AM
Discussion need help on reading futaba 3KP ppm signal chinweihung DIY Electronics 5 Feb 23, 2009 02:19 AM
Question Futaba 9CHP RF module PPM output? village_idiot DIY Electronics 2 Jul 31, 2007 11:17 PM
Futaba 8U TX, turn PPM signal off PLMS Radios 11 Oct 25, 2005 02:53 AM
