Aug 08, 2018, 08:00 AM
jeti 3d printed files
di someone have a holder file for REX10
Aug 09, 2018, 08:40 AM
this is awesome stuff.
keep these ideas coming.
Aug 10, 2018, 01:42 PM
89" Kool Aid drinker.
Smash McCrash's Avatar
REX10 receiver mount
Hi all,
As requested. I've been using these for a while in my electric planes then adjusted the file to accommodate a thin foam pad for gas/glow powered planes.
More details and the .stl files can be downloaded here.
Aug 20, 2018, 12:39 PM
GerdS's Avatar
I just designed a GoPro compatible mount for DC14 and DC16 as well as adapters for mounting either a monitor or smartphone for flying FPV.
See at https://www.thingiverse.com/thing:3056124.
Dec 27, 2019, 04:39 PM
Does anyone have a file for a R3 RSW that has screw mounting holes
Dec 27, 2019, 05:51 PM
Edgar Perez's Avatar
I added the screw mounting holes as you requested. 😀
Jan 18, 2020, 03:42 PM
Small Case for two additional guarded switches.
Regards, Walter
Feb 13, 2020, 12:24 PM
IMAC 4 LIFE!
On your original first post as I don't see any files attached to this one.
Any idea how long the CB200 and the RE3 mounts take to print? I don't own a printer but can use local Library but they have a 2.5 hour maximum print time.>
This is a great thread, thanks for starting.
Feb 13, 2020, 02:54 PM
It will vary depending on the printer used. Also, you won't be able to directly print the provided .stl file. You will need to use slicing software to convert it to a file usable by the printer. It's simlpe enough to do but there will be various settings that can be changed that will affect the print time, which the slicing software should predict reasonably accurately for the printer being used. Still, it's real easy to have something take over 2 hours..
The bottom line, it's not quite as simple as copying the posted .stl files and sending them to a 3d printer..
Feb 13, 2020, 03:31 PM
Active Cooled CB200 Enclosure
Here is a actively cooled enclosure for the CB200.
Air is drawn across both sides of the PCB.
On the bottom side across the full width.
On the top side the air enters over the polyfuses.
Case also has flanges that alone screw down mounting.
I have some cooling data and images, for different current load scenarios if there is interest.
It anybody is interested, let me know by PM.
Feb 13, 2020, 04:03 PM
If anybody is interested in messing with the DS backplates, changing the grips or adding custom switches etc, i have a good model of the DS backplate.
I also have a good model of the grips where they mate with the back plate.
And a couple variations of custom grips.
Feb 13, 2020, 08:39 PM
On your original first post as I don't see any files attached to this one..
all files are in the thingverse website
Don't quite recall, but I'm sure its much less than that time for the R3 mount and no maybe 1-1.5 hour for the CB200.
Feb 18, 2020, 08:31 PM
Eury's Avatar
Yes please! I was planning on modeling the backplate so I could add a module bay to it. Getting a head start on it would be awesome.
Discussion 3D Lab Print - 3D Printed Boeing Stearman northernmonkey 3D Printed Planes 915 Oct 22, 2019 08:28 AM
Discussion 3 Axis antenna mount for Jeti, Futaba, etc. 3d printed Dpetsel Electric Plane Talk 0 Jan 19, 2018 03:20 PM
Discussion Sketchup Plugin to Prepare 3D Models for 3D printing reemaj3D 3D Printing 0 Feb 24, 2016 07:10 AM
Discussion How to prepare 3D design for 3D printing reemaj3D 3D Printing 1 Jan 22, 2016 09:23 AM
Discussion Wild stuff made with 3D printing dll932 Life, The Universe, and Politics 8 Sep 27, 2013 11:03 PM
