HobbyKing Piaget 2 Foamboard 3D Plane
Check out this cool looking foamy from HobbyKing. The Piaget is a flat foam 3D plane that is built from foambaord. You can get it in a kit, but this ARF is only $88.26 with the motor, ESC and servos included.
Foamy ARF Under $90
Check out this cool looking foamy from HobbyKing. The Piaget is a flat foam 3D plane that is built from foambaord. You can get it in a kit, but this ARF is only $88.26 with the motor, ESC and servos included. We really like the color scheme and this should be a tough model for learning 3D flight. Get your build on, but don't worry, it should take less than an hour to get it ready to fly. You'll just need to include your own battery and receiver to finish it out. What do you guys think about this one?
Check out the HobbyKing Piaget 2 ARF Foamboard 3D Plane Here
Specifications:
  • Length: 900mm (35.4")
  • Wingspan: 820mm (32.2")
  • Weight: 210 - 240g
  • Motor: 1500kV Brushless outrunner
  • Servo: 3 x 9g
  • ESC: 10A
  • Requires: 2S~3S 800mah Lipo and a receiver
Mar 02, 2018, 11:49 AM
ltc
ltc
AMA 97737
ltc's Avatar
I can't find a manual on the HK website, but it looks like there is no carbon rods to stiffen the fuse and flying surfaces?
Is the foamboard stiff enough 'as is' ?
Looks like it might be a fun backyard flyer.
Mar 02, 2018, 01:22 PM
pull up -- PULL UP!!!
Try this:
http://www.techonehobby.com/wp-conte...-ll-Manual.pdf
Don't know if HK changed anything besides colors. This is a great choice if you're into slow and easy 3D.
Mar 02, 2018, 01:53 PM
ltc
ltc
AMA 97737
ltc's Avatar
Originally Posted by hard line
Try this:
Thank you very much; I had no idea it was a TechOne plane.
Have a nice weekend !
Mar 02, 2018, 02:15 PM
Techone includes a high quality motor in their PNP. HK might have changed that out for one of their own. It would something to check out.
Mine:
https://www.motionrc.com/collections...aget-ii-3d-arb
Mar 02, 2018, 04:34 PM
ltc
ltc
AMA 97737
ltc's Avatar
Mine:
The Techone is listed as EPP foam.
The HK says foam board ... which to me is Depron type foam skinned with paper.
Maybe they just switched the plane construction?
Mar 02, 2018, 06:15 PM
I would bet poor wordsmanship on HK's part. It must be the Techone design to be able to use the name -- I'd imagine it's the same plane with some HK chrome on it. But I could be wrong.
Mar 02, 2018, 09:29 PM
Hobbyking have been selling rebranded Tech One Planes for many many years now.
Mar 03, 2018, 06:05 AM
Flying a Falcon or a 3D model.
fauconnier's Avatar
In the HK specification it is written EPP.
I'm sure it's the same plane. I red good things about it ( Paleomanjim) .
I had 2 old ver. Piaget. They were made of 5mm Epp instead of 10mm for the new one. With a higher wing loading, the new one is certainly faster, not best for indoor, but more crash resistant.
Mar 03, 2018, 09:08 AM
Hmmm, faster? My Piaget 2 is the slowest plane I own. Even slower than my Crack Yak Superlite which weighs much less. Since it doesn't seem attributable to wing loading, I assume it must be a very high drag count. But whatever the reason, "faster" and "Piaget 2" don't seem to go together.
Aug 17, 2018, 03:27 PM
I just started to put my HobbyKing Piaget together and I ran into a problem. I am using Foam-Tac glue which I believe is ok for this FOAMBOARD plane.
The problem is that the edges of the pieces are not flat! Either are U shapped or partial U such that when glue together the bottom side is about 1/32 "
away from each other.
So, looks like will have to square off all the edges.
Anybody else notice this?
Thought it was the same as the Techone, and they even refer you to that for the build instructions, but the big difference is that the Techone is EPP, and I just got done building their MXS-800 with no problems!
Bob
Question Hobbyking foamboard Soufiani Foamies (Scratchbuilt) 18 Jan 11, 2017 12:27 PM
Discussion Using Foamboard on 3D planes RcNewbAddict Foamies (Scratchbuilt) 64 Jan 27, 2011 05:50 PM
Discussion Using Foamboard on 3D planes RcNewbAddict 3D Foamies 4 Oct 03, 2010 04:45 AM
Discussion Piaget Micro 3D plane EPP fjernstyrten Foamies (Kits) 0 Dec 17, 2009 10:32 AM
Discussion what 3D plane to build with Dollartree foamboards? brian94066 Foamies (Scratchbuilt) 3 Feb 12, 2008 06:07 PM
