This thread is privately moderated by aero nishi, who may elect to delete unwanted replies.
Feb 22, 2018, 08:35 AM
RC Factory Crack Wing Twin Modification
Specifications:
Motors: SunnySky R1106 8000KV Brushless Motor x 2
Props: 3x2" T-Type 3020 Multirotor Propeller x 2
ESCs: TURNIGY Plush 6A with BlHeli firmware x 2
RX:FM800 Pro 2.4G 8CH Receiver
FC: F4 Micro Flight Controller with iNav firmware
Battery: Dualsky 300mAh 30C 7.4V
RC Factory Crack Wing Twin Modification (1 min 8 sec)
Inverted hovering is still highly experimental but I'm trying with a little bit larger ESCs/ Battery and inverted setting:
Inverted Hovering Test - RC Factory Crack Wing Twin Mod. (0 min 22 sec)
Recent indoor videos of the wing in 3D mode.
RC Factory Crack Wing Twin Mod. (0 min 56 sec)
Dec 02, 2018, 10:28 AM
Great! Really impressive!
What INAV modes do you use and is it configuread as a fixed wing or a bicopter?
Dec 21, 2018, 04:54 AM
Thanks. I used flying wing with differential thrust setting.
Dec 21, 2018, 05:13 AM
Thanks a lot for the information!
May I ask some more question?
1. Which flight mode(s) are you using for stabilization? I mean the plane seems to be stabilized when you hover it and when flying it horizontal, too. Looks really impressive but I have no idea, which flight mode in iNav can do this.
2. Are you using special props which deliver the same thrust in forward/backward flight?
Thanks in advance!
Dec 21, 2018, 05:54 PM
Thanks in advance!
1. I use Acro mode for normal flight. For hover flight, I use modified Horizon mode.
2. For inverted flight, it is still highly experimental, I use modified betaflight with 3D props.
Discussion RC Factory Edge 540 vs Crack Yak (Standard): trumpy959 3D Foamies 9 Nov 27, 2012 07:56 PM
