This thread is privately moderated by old4570, who may elect to delete unwanted replies.
Feb 21, 2018, 09:58 PM
old4570's Avatar
Time to make a new wing ( assemble )
Wing of choice is the Spirit 600mm from Banggood ..
This will be my 2nd Spirit 600 ..
The first was made more robustly with 9g servos and a larger motor ( 18 something ? )
And a heavy 3ch car Rx
And it needs some weight in the nose to balance things out .. ( Larger battery )
So hopefully the 2nd time around I can do it better :
This time I am going with the 1306 - 4000KV motor ( small - light )
Also a much smaller lighter ESC ( not sure 6A is enough - will see )
Also the servos this time will be 3.7g
And I will be using a Redcon 6ch Rx ( very light )
This will hopefully allow for the use of a small 2s like a 250 -300mAh battery ..
The goal on this build is to go light .. This should allow for much slower flight speed / glide better as well ..
I know , less weight will mean less tolerance to wind ..
But I really want a slow wing ( compact for easy deployment )
Mar 01, 2018, 06:22 PM
NELICOPTER's Avatar
good luck with the build! is the Spirit a good wing? How many others have you used?
Mar 01, 2018, 07:51 PM
old4570's Avatar
Just two ...
Rainbow 2 ( 1 meter ) and Spirit 600 ...
Rainbow two flies slow - Spirit 600 flies fast ..
Hence the 2nd go at a spirit 600 ..
I want to try and slow it down = Build it lighter ... Just waiting on some ESC ...
I want to get the ESC / motor combo sorted out first ..
After that the build should be very fast , especially as I know where to CG ..
Assembling the spirit 600 is very easy , and its relatively robust .
The lighter you build one , the slower you can fly it .
Plus the $$ value is insane .. ( Very cheap way to RC )
Discussion New york times makes "scientific case" for outlawing free speech kenpoprofessor Life, The Universe, and Politics 7 Jul 18, 2017 01:29 AM
Help! New to making delta type wing questions ninjasword71 Foamies (Scratchbuilt) 26 Sep 06, 2016 09:38 AM
Video Amazing time-lapse of aircraft carrier Lego-like assembly Dennis99 Dock Talk 1 Dec 17, 2015 01:06 AM
Discussion New long flight time build, want to make sure my reasoning and build makes sense. sodaant Multirotor Drone Talk 0 Oct 05, 2014 07:38 PM
Help! I broke a part during assembly. Need help to make a new one. Ultimate 20-300. Michaelinpr Electric Plane Talk 14 Apr 09, 2011 06:04 AM
