Feb 19, 2018, 10:52 PM
Flysky 9ch reciever setup
Hiii
I m really new to rc i m buildIng my first quad with naze 32 board,my setup is almost done i confused about my flysky 9ch reciever wiring setup with naze 32 ,you advice will be helpfull for me
Feb 19, 2018, 11:37 PM
FPV = Cardio
Originally Posted by Surender
Hiii
model numbers of your gear would help. I skipped school on they day they taught mind reading.
Feb 19, 2018, 11:41 PM
What specifically are you confused about? Have you watch some videos?
Feb 20, 2018, 07:00 AM
FA3PR9WM79
Oldgazer's Avatar
You have two options:
1. Connect the receiver like you would to anything else using individual servo leads and set the FC to use standard PWM inputs.
2. Connect the receiver to a PWM to PPM Encoder and connect the encoder to the FC. Set the FC to use PPM input.
Option #2 is the preferred method. If you use Option #1 you CANNOT use any BlHeli protocols like Oneshot.
Feb 20, 2018, 08:50 AM
thanks
for your response friends i am submitting some photos please have a look
Feb 20, 2018, 08:56 AM
this how i connect is it ok ????
Feb 20, 2018, 10:51 AM
It is difficult to tell from the photo. But it looks like you have the order backwards. Anyway, you want to connect channel signal 1 on RX to channel 1 on FC and so on. Ground to ground. 5V to 5V.
Feb 20, 2018, 11:26 AM
Ace12GA's Avatar
It's not that simple. Your channel mapping has to be correct, to match your pins from the Rx to the pins on the FC. If your channel mapping is AETR on your Tx, then going pin to pin should work. Pin 1 to pin 1, etc.. If your mapping is not AETR, you still need to get the pins from the Rx to the correct pins on the FC.
FYI, AETR =
Ailleron
Elevator
Throttle
Rudder
So Ailleron on Channel 1, Elevator on Channel 2, Throttle on Channel 3, and Rudder on Channel 4. Aux channels follow that on the respective pins; i.e.: Aux 1, Channel 5, Aux 2, Channel 6, etc...
Feb 20, 2018, 11:43 AM
FPV = Cardio
If that's the underside of the FC, then I think it's fine.
Feb 20, 2018, 09:52 PM
Thanks all of you
Feb 21, 2018, 06:56 AM
FPV = Cardio
Thanks all of you
Sorry, I just now zoomed into the pic of your receiver. You have the channels backwards, as mentioned earlier by voodoo assuming your channal mapping is AETR. You have rc pwm ch1 output from the receiver going to pwm 8 input on the FC. In your pic, the power, ground, and ch1 white wire on the Fc side are fine, so just rearrange them on the receiver side so that they're on the other end (in your pic) and go down the channel order.
While you're at it, triple check those solder pads on your PDB. A couple look like they're almost shorts across + and -
Feb 25, 2018, 12:17 AM
Hey guys i rearrange them all , in cleanflight motor are working correctly but in reciever option it is not responding reciver is binded with transmitter (orange led in reciever stable when i on the transmitter ) i am using fsth 9x tx and fsr9b reciever and fc board is naze 32 rev6
Feb 25, 2018, 01:21 AM
Setup is not responde with transmitter. I dont know what i am missing
Feb 25, 2018, 09:37 AM
Ace12GA's Avatar
What do you have it set to on the configuration page? Should be PWM. Is the Rx actually powered? If I recall correctly, USB didn't provide enough power to actually power an Rx that size, you need to connect a flight pack.
Feb 25, 2018, 09:43 AM
FPV = Cardio
Is there a power light on the receiver? That same setup was my first radio/receiver and my receiver was DOA.
Those ESCs have a BEC. Try powering the receiver off of one of those, just for troubleshooting purposes.
Discussion The FlySky/iMax/Turnigy 9x/Eurgle 9CH radio Custom Firmware Facts/How-to Thread! crucial Radios 24429 Mar 19, 2021 11:45 AM
Discussion new flysky 9ch tx rx for sale + new flysky 6ch rx for sale sameermaha India 0 Nov 23, 2012 11:49 PM
Help! FlySky / Eurgle / Turnigy 2.4Ghz 9ch system solentlife Radios 2 Aug 05, 2010 01:13 AM
Discussion $13 2.4GHz Hobbyking (Flysky) 9ch JR Module now available Gyroguru Radios 37 Sep 22, 2009 02:56 PM
