FWIW, I know it's more money, but the big brother version is the 10428 and it has a two-speed gearbox for those who like to crawl. It's also a lot taller.
I can shift my 10428 and see the arm move on the gearbox, but, I don't really see the reduction in speed. I'd hate to tear it all apart to find out what's going on because I don't see myself using it as a crawler. I bought it based on the height so I can run it in my yard with tall grass.
I am still waiting for my O-Rings from Banggood to try rebuilding my stock shocks. I bought the ones I listed on page #1 for the rear. Most of what I buy from them takes a good 3 weeks to get here. The O-rings have been a month and I'm still waiting. I would like to put in another order, but this waiting has me worried.
Rear Links
I posted yesterday about the new rear links I made. I think they're a little overkill and heavy. I'll try doing the same thing in 8-32 size instead of 1/4-20.
Wheel hex extenders arrived. Decided I'm not lowering it for I like how it looks. Bigger wheels next I think.....
For some reason, they broke up my order into 3 orders. If they had left it all as one, there would be less chance of it getting lost. A bunch of O-rings will come in a small envelope that can easily get lost coming from China!
Pastell, the truck looks good. I had those wheels and tires on mine, but had clearance problems when I put the new rod ends on the front.
Speaking of which, if I turn mine left and and let the transmitter wheel go, it comes to one center position. If I turn right and let it go, I get something completely different. Drives you nuts when you're trying to set the front alignment! |
Ordered the same O-rings 12/12/17 arrived 29/12/17, 17 days to deliver and they work as expected.
Steering assembly fix?
Hey Guys! Has anyone figured out a better setup for the 12428 steering system? The first thing that failed was the original plastic slider, so as you can see, I upgraded the entire front end with Aluminum, and it still sucks! lol The flaw is in the design. When the servo rod push/pulls on the attachment point of the slider, it twists (torques) the bar which increases friction and jambs. So bad that it twists the plastic chassis where the servo mounts.
Thanks! Jimmy PS: the only other thing that has failed (so far!) was the sh1tty rear diff. I think the front might be getting worn internally as well but still works. Gonna try and lock the original rear with epoxy as an experiment/spare. One of these days, I will make a thread with all my mods. I did something interesting with longer rear upper links (96 mm) which straightens out the rear drive shaft angle. $3.50 https://www.ebay.com/itm/RC-1-10-Cen...n/192356839758 |
Thread Tools | |
Similar Threads | |||||
Build Log | PCF SWIFT BUILD THREAD 1:12 scale | CaptDH | Scale Boats | 82 | Feb 05, 2024 05:38 PM |
Video | WLtoys A333 2.4GHz, 2Ch, 2WD, (1:12 Scale) Monster Truck RC Car (RTR) + FPV driving | hermit81 | Off-Road Vehicles | 0 | Jun 06, 2017 04:37 AM |
Alert | [Snap up]Wltoys L959 2.4G 1:12 Scale RC Cross Country Racing Car | BG Tobey | Banggood.com | 0 | Aug 22, 2016 04:25 AM |
