Feb 19, 2018, 02:04 PM
four candles
2 servos 1 power feed..?
I'm just about to start building Ava pro 4m glider in which the rudder and elevator servos are housed in the vertical stabiliser. My question is this.. To save weight is it possible to run both those servos off just 1 pos. and 1 neg. + 2 signal, if so is there a downside ?
Thx Chris
Feb 19, 2018, 03:07 PM
Yep totally, same way to wire up the wing servos on top drive f3k models. , 1 positive, 1 ground and then a signal line to each servo.
Feb 19, 2018, 04:58 PM
four candles
Thx Mark
How does the wiring work, do you join the 2 positives and grounds together as they leave the rx then re-engineer the join at the other end ?
Feb 19, 2018, 05:15 PM
gwh
gwh
You can join the wires any where it is convenient. in a glider it is typically at the wing connections. If you look inside a RX you will see that all of the + connections are tied together. The - are the same. These are sometimes referred to as a power bus. It is only the signal wires that are unique. For long runs you may want to increase the size of the wires for less voltage drop.
Feb 19, 2018, 05:29 PM
four candles
I think I'll keep the original heavier gauge wire for the -/+ and replace the signal wires with the lighter gauge I have, still a weight saving over a 1.5m
Thx guys.. back to the build
Feb 19, 2018, 09:04 PM
From the wing to the rx is just the 4 leads, from wing to the servos is then the normal 3 leads to each servo.
Discussion Audio hum in the feed when connecting a camera with power to Vector? Ground loop? markm75 FPV Talk 17 Oct 18, 2018 08:13 PM
Discussion Losing video feed on 1.2 Lawmate AdamGUK FPV Equipment 6 Feb 16, 2015 12:05 PM
Discussion gopro 1 live feed problem - b/w feed only from hdtv out goodwillberlin FPV Equipment 1 Nov 25, 2014 05:19 PM
Discussion Light Bridge live feed at almost 2.1 kilometers (1.3 miles) range is crystal clear thangchelsea Multirotor Drone Talk 21 Jun 24, 2014 02:23 PM
Discussion 1/760 USS Enterprise (2 servo powered) -james- Micro and Sub-Micro Boats 9 Aug 11, 2012 07:02 AM
