PCB Antenna for receivers - RC Groups
Feb 16, 2018, 03:46 PM
E_ferret's Avatar
hi Jim, are these pcb antennas any good and/or suitable for receivers like the RFU?
Feb 16, 2018, 07:05 PM
No. You can't use any antenna except what was included with the RFU. During the FCC testing process you have to provide the antenna(s) you intend to have used with your product. Using ANY other antenna would be illegal. In the case of the RFU, the circuitry on the DivBee module is tuned specifically for the antenna we use. Other antenna options would likely not have the same range, even those with higher gain due to the fine tuning done to perfectly match the 1.1dBi wire.
Discussion Proper fixed wing antenna position for FrSky X8R PCB antenna Wildvortex Radios 0 Jan 03, 2018 05:06 PM
Discussion X8R PCB Antenna Placement propflux01 Multirotor Drone Electronics 2 Aug 07, 2017 01:26 PM
Discussion Frsky PCB antennas Eric_04 Radios 6 Jun 26, 2017 11:15 PM
Discussion X8R pcb antenna Eric_04 Radios 2 May 08, 2017 03:14 PM
Discussion Receiver board with PCB printed antenna? Cellux Multirotor Drone Electronics 3 Mar 31, 2016 02:25 PM
