Top Flite 1/7 P-51D Mustang P51 - RC Groups
This thread is privately moderated by AGForce, who may elect to delete unwanted replies.
Feb 14, 2018, 01:00 PM
Trader Rating: 8
$595.00 USD
Buyer pays shipping
Sold
Top Flite 1/7 P-51D Mustang 60 GP Electric w/Retracts and Flaps
Excellent condition, BNF Mustang includes:
HiTec HS605 Dual Ball Bearing Servos 1- Rudder, 1- Elevator
Futaba S3004 Dual Ball Bearing Servos 2- Ailerons, 2- Flaps
Stock mechanical Retracts with Spektrum AR7000 hi torque Servo
Spektrum AR610 Receiver
Castle Creations 10Amp BEC unit.
Hacker X70 Opto Pro ESC unit.
Hacker A50 16S Brushless Outrunner Motor
SPECIFICATIONS
Wingspan: 64.5 (1640mm)
Wing Area: 721 sq in (46.5 sq dm)
Weight: 8.75 - 10lb (3970 - 4540g)
Wing Loading: 28 - 32 oz/sq ft (85 - 98 g/sq dm)
Length: 56 (1420mm)
Airfoil: Fully-symmetrical, low-wing
Center of Gravity: 5-5/8 (143mm) Back from the wing's leading edge
Control Throws: High Rate Low Rate
Elevator: Up & Down 5/8 (16mm) 3/8 (9.5mm)
Rudder: Right to Left 1-1/8 (29mm) 7/8 (22mm)
Ailerons: Up & Down 11/16 (17.5mm) ½ (13mm)
Flaps: Down 1¼ (32mm) 5/8 (16mm)
Feb 14, 2018, 04:10 PM
Trader Rating: 0
Blairhalk's Avatar
Beautiful looking plane.
And the internals look so tempting!
Feb 14, 2018, 07:58 PM
Trader Rating: 69
More Speed Indeed!
Hossinarizona's Avatar
Hello,
I assume you were running this on 6s, if so how many mAh's and what was the "C" rating? Also, how do you install the battery, a hatch somewhere, or do you have to take the wing off every time?
Any additional pictures would be helpful.
Build Log Top Flite P-51D Mustang 1/7th scale build RJFnewhavenCT Balsa Builders 27 Sep 03, 2016 11:33 AM
Sold Price reduction!!! Top Flite Giant P-51D Mustang ARF 2.1-2.8,84.5" Mike Fortune Aircraft - Fuel - Airplanes (FS/W) 8 Aug 22, 2016 10:45 PM
Sold Top Flite Giant P-51D Mustang ARF 2.1-2.8,84.5" Mike Fortune Aircraft - Fuel - Airplanes (FS/W) 0 Aug 14, 2016 06:09 PM
Sold Top Flite P-51D Mustang ARF - .60-1.20 LPU dawhale Aircraft - Fuel - Airplanes (FS/W) 1 Jan 29, 2016 02:41 PM
Build Log Top Flite 1/7 Scale P-51D Mustang M3Aviator Electric Warbirds 39 May 25, 2010 02:55 PM
