Feb 14, 2018, 10:11 AM
telemetry: which have it?
a chart that includes all the products available that have telemetry, specifying exactly what they have or do would be ideal.
perhaps if we ask all that have any, or knows about, to bring the data here would do?
in other words: if you have (or know about) a product that has telemetry, please bring data. thats all that we need.
just that. if you dont, dont post.
if you have any suggestion pm me.
but this wont go anywhere if nobody cooperates.
to get started:
for instance:
1- https://hobbyking.com/en_us/quanum-2...-mah-v3-1.html
(i know its discontinued, but is an example of something that has telemetry)
1st, lets see what is the definition of telemetry:
from the dictionary:
telemetry /təˈlɛmətri/ noun
Learner's definition of TELEMETRY
[noncount] technical
: the process of using special equipment to take measurements of something (such as pressure, speed, or temperature) and send them by radio to another place
this post will be the place where we will show the products, the list and link to the posts.
2 classes:
1-independent;
2-through the receiver to the radio
as far as i know, there are few that run by themselves, no matter what radio. the rest are dependent of the specific transmitter, radio or protocol.
class 1:
1- https://hobbyking.com/en_us/quanum-2...-mah-v3-1.html -see post 4
2- https://hobbyking.com/en_us/quanum-p...9-5mhz-fm.html post 4
class 2:
1- taranis. see post 5
Feb 14, 2018, 10:18 AM
data
and we need to be precise on the data that each device sends or is able to receive.
for instance, if it brings volts, amps, whatever. everything. i hope am clear.
on the example before:
Show Temperature in centigrade or Fahrenheit
Battery capacity (Used/remaining)
Feb 14, 2018, 02:28 PM
classes
lets start with specifying the several classes;
1-independent, that send signals to a receiver separate from the radio you use for controlling the vehicle;
2-transmitting through the receiver to the radio.
if there is another way, please tell.
Feb 14, 2018, 02:33 PM
class 1-independent
with class 1 we have the 1st example that was mentioned at post 1:
1-low voltage alarm (transmitter installed at the model): sends Temperature in centigrade or Fahrenheit and Battery capacity and an alarm beep when reaching low voltage (to the receiver at the ground).
2-low voltage alarm (transmitter at the model): sends an alarm (vibration) to the receiver at the ground when reaching low voltage:
https://hobbyking.com/en_us/quanum-p...___store=en_us
low voltage alarm: the receiver at your hand vibrates when reaches a low voltage programmed by you.
Feb 15, 2018, 09:14 AM
FA3PR9WM79
Oldgazer's Avatar
Taranis.
You can use individual sensors, or if you use a Pixhawk flight controller you can run Flight Deck and get every thing directly from the flight controller to the radio. You get a custom flight status display, haptic and voice alerts.
Also, you can add separate telemetry radios. One goes on the aircraft and is connected to the flight controller. The other is connected to a USB port on a computer running Mission Planner. With this setup you get full ground control station functionality. As an added bonus you can add a video capture device to the lap top and feed your FPV video to Mission Planner and have it displayed in the HUD.
TH9X or any similar 9x radio with an AR9X board running OpenTX. Very similar functionality to Taranis.
Question can anyone tell me which rc car do i have ? saad rocks Car Talk 14 Jul 04, 2016 07:55 PM
Discussion Avoiding "model match" -- which brands don't have it? aeronaut999 Radios 98 Feb 17, 2016 08:24 PM
Discussion How to tell which Alula I have natterjak Hand Launch 13 Feb 14, 2016 01:43 PM
Discussion Quanum Nova - which Telemetry unit? Geordieboy Multirotor Drone Talk 0 Dec 22, 2015 04:27 AM
FAQ PHOENIX 25 / Which Version do I have? 1.5 amp or 3 amp BEC Clintstone Castle Creations 0 Nov 18, 2015 01:10 PM
