Feb 13, 2018, 04:16 AM
Data
Multigp Micro Race Frame Zappy 120 fpv
Zappy 120 fpv frame from Rocket Quads
This thread is intended to be a resource and guide for the zappy frames from Rocket Quads
Frame kit available from Armattan Productions click here
Rocket Quads thread: https://www.rcgroups.com/forums/show...d-its-variants
120 Frame: 3mm 5.60g
2 x Sleds: 1.5mm 1.35g
1 x Clip: 2mm 0.35g
Total Weight 7.30g
Designed for 11xx motors, 16x16 or 20x20 hardware
Front or rear mount camera
Up to 3 inch props
Target flying weight (with battery) around or under 70g
reserved for cameras vtx etc
Feb 13, 2018, 04:19 AM
reserved for motor data
reserved for prop data
Feb 13, 2018, 04:20 AM
reserved for electronics
Feb 13, 2018, 04:21 AM
reserved for things we have not thought of
Mar 02, 2018, 09:52 AM
in the top can we have some TPU lightweight canopy? frame looks very good otherwise
Mar 02, 2018, 06:28 PM
Test Pilot
teracis's Avatar
For stack protection? How tall are we talking? I run a stack that stays well below the prop line so didn't want to add extra but it's a valid concern for some builds.
Mar 02, 2018, 07:19 PM
3 stack layer... With vtx, Rx. If you make a 22/24mm simple light pod would be amazing match.
Mar 11, 2018, 05:11 PM
Test Pilot
teracis's Avatar
Here's my current build with the vtx in a nicer position, between the rails. There's conformal coating on the vtx to resist corrosion from wet grass and help keep components on there, kapton tape on the back and a bit of hot glue holding it to the frame.
Stack:
Description:
Vtx Placement:
Description:
Battery Placement:
Description:
Sep 14, 2021, 04:44 AM
Wingfan
Time to revive the Top Mount Version
https://armattanproductions.com/pages/kit_detail/1830
i found it searching for a light caddx vista build and i think it is possible with TM 1204 or TM1303 with GF 3016 on 2S.
i guess the mount will be for 16mm cams, with a bit modification even the polar is usable, or the Nebula Nano.
Never read or seen this fram in action, but should do the job with its 3mm and that weight.
Hey Rocket Quad, are there plans to make a HD Version?
Are you still active?
regards
roland
Discussion Colorado MultiGP Chapters - FPV Racing cdee Drone Racing Leagues 903 Jan 05, 2018 01:26 PM
New Product 92MM Micro FPV Racing RC Quadcopter Frame Kit - AIO F3 EVO Micro Frame sevet Micro Multirotor Drones 4 Feb 01, 2017 06:05 PM
Discussion MultiGP - FPV Racing - Tools Needed for Racing MultiGP Drone Racing Leagues 36 Nov 06, 2016 01:18 PM
Discussion MultiGP FPV racing in Colorado VikingTattoos Drone Racing Leagues 2 Sep 05, 2015 01:27 PM
Article MultiGP FPV Racing - RCGroups.com Interview at FliteFest 2015 Matt Gunn Drone Racing Leagues 14 Aug 16, 2015 08:38 PM
