Feb 12, 2018, 09:46 PM
Binding SPM4648 to Blade xmtr?
Trying to see if I can use an old controller with this new Bat 100. I plan to get set up with a good transmitter and goggles but would love to fly this thing line of sight for a bit.
The transmitter is a Spektrum 2.4GHz DSM2 that came with a dual prop Force helicopter. I have several of these from a few years back when we were flying those indoor helicopters. It has 5 channels so I am hopeful. The issue may be, no means to change modes.
I installed the receiver (SPM4648),
connected up to Betaflight,
installed the battery,
set my xmtr to bind.
The receiver light turned steady yellow as it should when bound.
In Betaflight when I go to the controller screen I see nothing changing.
For Serial Rx I selected UART 3, (no idea how one would determine which to use?)
Under settings - Receiver, I selected "Serial-based receiver..." and for Serial Receiver Provider I selected "SPEKTRUM2048"
All just guesses.
Mainly, should I have any hope of this working?
Any pointers on settings I am missing?
I would love to fly this thing even on this temporary controller. In the future it might be an option to use for guests.
Appreciate any help.
Lots of learning to do, just getting my feet wet.
Jeff
Feb 13, 2018, 12:58 PM
So where did u connect the receiver to on the fc? Do you know what fc it has? Meantime it sounds like your settings are correct. I would try uart 1 and uart 2. And u can arm with the sticks so channel 5 could be ur mode switch
Feb 13, 2018, 01:10 PM
I just checked it has a minicube betaflight f3 fc. And the receiver is on uart 3. But for dsm2 you should select 1024 not 2048. And there is a jumper that has to be soldered to select either 5 or 3.3 to the receiver
https://www.google.com/url?sa=t&sour...ldaQUp3n6ziaxs
Feb 13, 2018, 01:22 PM
So i was just watching a youtube video on this quad and he said receiver on uart 1. So i would try that
Feb 13, 2018, 01:26 PM
Full Speed teeny 1S F3.
Soldered to the ground, signal, and 3 volt tab. It has both 3 volt and 5 volt.
Tried 1024 also, no go.
It binds, just doesn't talk.
Feb 13, 2018, 01:46 PM
My hope has been with the 5th channel I would be able to get it to function and have a cut off.
I am wondering if the receiver is getting power but the signal not getting to the board (bad solder? bad board?).
Is there something in betaflight that tells me if the signal is actually getting to the board?
Jeff
Feb 13, 2018, 02:03 PM
Could it just simply be that the receiver is DSMX and the transmitter is DSMR?
Feb 13, 2018, 02:37 PM
I tried all 3 available UARTs, 1, 2, and 3.
I tried each UART on each Serial setting, 1024, and 2048.
I'm now suspicious of the flight board. Seems like everything else works in betaflight.
Feb 13, 2018, 02:44 PM
I suppose if I could hook up with a "Real" radio that may tell me another story.
Feb 13, 2018, 04:12 PM
I just googled ur receiver and if does say just dsmx. I would say that is probably ur problem
Feb 13, 2018, 04:29 PM
Thanks for the input.
Trying to get airborne on a tight budget.
I guess I'll look for a used radio.
Feb 13, 2018, 04:40 PM
Thanks for the input. Just trying to get airborne.
Feb 13, 2018, 07:40 PM
I dont blame u man. That looks like a pretty cool little quad. Like an upgraded qx95s!
Feb 13, 2018, 08:14 PM
This learning curve is quite a bit of fun
I think I will like this fpv drone thing.
I generally avoid the easy route. As you can see, I bought a drone that would immediately need a component sodered on which is a skill I lack.
Feb 14, 2018, 07:33 AM
Stick with it man. It is an awesome hobby. It seems overwhelming at first, there is a lot to absorb. But u will get there. Do you have any other receivers to try?
Discussion Binding SPM4648 to Spektrum xmtr? Swath Beginner Training Area (Heli-Electric) 1 Aug 19, 2020 03:26 PM
Question The new Spektrum SPM4648 sat, stand alone only? eviltwin Radios 45 Jan 11, 2020 09:21 AM
Discussion Blade 350 qx2 wont bind borru Multirotor Drone Talk 0 Sep 12, 2015 08:58 PM
Question Blade 200QX XMTR & Payload Questions heliflyer13 Multirotor Drone Talk 4 Aug 16, 2014 09:32 AM
Mini-HowTo Binding the Blade CX2 to the Spektrum DX6i (Blade 400) CallMeNick Coaxial Helicopters 102 Feb 25, 2014 08:27 PM
