Cut the soldering and wiring time down to a minimum with the Strix Stratosurfer PNP FPV Pod from ReadyMadeRC. The Stratosurfer is a well-known FPV airplane that performs well right out the box; this FPV pod is designed to fit the Stratosurfer and only requires it to be plugged inline between the battery and ESC with a pre-made XT60 harness. It retails for $99.99 and is currently in stock at RMRC.
CLICK HERE for more information.
Here's what RMRC says about the PNP FPV Pod: If you bought a STRIX Stratosurfer and want to add FPV as fast and as easily as possible, this PNP FPV Pod is for you! It comes pre-assembled with love by the RMRC crew and made with top of the line components. No additional wiring or cables are needed with the XT-60 Battery Tap. Rule the Sky™ with STRIX!
NOTE: Since we do not know the fuselage magnet polarity on your particular Stratosurfer, we cannot glue in the canopy magnet ahead of time. This will be required before flight.
Excellent solution for those who are overwhelmed by the myriad of options for getting started with FPV. Certainly there are better VTX solutions - but this PNP solution will make it very easy and relatively affordable to dip ones toe into the FPV experience.
Simply simple. I received my Ready Made Strix FPV canopy today. I appreciate the convenience of having it ready to go with no screwing around. The only thing I did was use the Dremel to modify the "lid" to fit around the equipment and install a few magnets to hold it in place. Excellent solution for the FPV NOOB - like me.
Thread Tools | |
Similar Threads | |||||
New Product | RMRC STRIX StratoSurfer FPV Airplane | rclab1 | FPV Aircraft | 851 | Dec 16, 2023 08:35 PM |
News | The RMRC STRIX StratoSurfer - PNP | Jim T. | FPV Talk | 256 | Nov 11, 2022 07:43 AM |
Review | The ReadyMadeRC Strix Stratosurfer - RCGroups Review | Matt Gunn | FPV Talk | 42 | May 31, 2020 12:46 AM |
Discussion | Strix Stratosurfer FPV pan | Justynkace | FPV Equipment | 5 | Jun 07, 2017 01:34 PM |
