Crossfire Micro and Vector - RC Groups
Feb 12, 2018, 02:44 AM
because rust never sleeps....
HugoRogers's Avatar
I am looking into purchasing a TBS Crossfire Micro for use with my Taranis QX7 and Eagletree Vector.
Are there any issues I need to be aware of ?
1. Do all the Crossfire RXs provide SBUS input to Vector.
2. Is there an RSSI output from the Crossfire RXs which will plug straight into the Vector to give me RSSI percentage on the OSD.
3. Are there any other issues I might need to be aware of?
May 12, 2018, 03:10 AM
Yes, if you want rssi and link quality you need to connect the bst port of the crossfire rx to the vectors bus port that is open... Or you can select ppm out of crossfire rx and set rssi to a unused ch and lq to another, bst port is best though cuz then you get gps coordinates displayed on the crossfire rx too
May 12, 2018, 11:27 AM
HugoRogers's Avatar
I managed to sort this, but thank you for replying.
Jun 14, 2018, 11:19 PM
I am in process of doing the same set up, what connector do you use between crossfire micro to vector? Or if you even need any?
Jun 15, 2018, 01:33 AM
HugoRogers's Avatar
TBS BST to Vector Bus connector
https://www.rcgroups.com/forums/show...84&postcount=1
Mini-HowTo Vector RSSI/LQ and Telemetry on the TBS Crossfire billpa Eagle Tree Systems 173 Jun 03, 2018 03:47 PM
Discussion ET Vector with TBS Crossfire DV RX and SBUS f33dback Beginner Multirotor Drones 2 May 02, 2018 07:47 PM
Discussion Vector UART Telemetry via TBS Crossfire keithsuth Eagle Tree Systems 2 Apr 15, 2018 09:29 AM
Discussion Crossfire vs. crossfire micro Warfighters Multirotor Drone Electronics 0 Nov 21, 2017 12:00 PM
Discussion Vector > Crossfire Full Telemetry question. keithsuth Eagle Tree Systems 0 Feb 25, 2016 03:58 PM
