Review of Eachine QX65 - Tiny Whoop - 48CH 700TVL Camera F3 OSD 65mm Micro Quad - RC Groups
This thread is privately moderated by mlilasic, who may elect to delete unwanted replies.
Feb 11, 2018, 05:10 PM
FPV addict
mlilasic's Avatar
Mini-Review
Review of Eachine QX65 - 5.8G 48CH 700TVL Camera F3 Built-in OSD 65mm Micro FPV Racing Drone Quadcopter w DVR flight footage
This is new micro (65mm) quad from Eachine. Looks really nice in bright yellow color and with great looking canopy.
But most important, it flies great... just great.
I took it for a spin with "out of the box" settings and here is a quick maiden, more videos to follow...
Eachine QX65 - race test - 700TVL Camera F3 OSD 65mm Micro FPV Quad - tiny whoop (2 min 49 sec)
Fast home run & crash test - DVR flight of Eachine Beecore V2.0 Brushed F3+OSD FCd - tiny whoop (2 min 19 sec)
Eachine QX65 - 700TVL Camera F3 OSD 65mm Micro FPV Racing Drone Quadcopter - DVR maiden flight (1 min 38 sec)
Eachine QX65 - Tunnel run & crash test - "out of the box" F3 OSD 65mm Micro FPV Quad - tiny whoop (2 min 58 sec)
If you are more interested into DIY build and you are skilful with solder iron you can check my Beecore V2.0 flight controller review with build and DVR flight footage HERE.
Desc from Banggood:
Eachine QX65 is a new upgrade Tinywhoop based on Betaflight 3.2.2 integrated Betalight OSD , support ACRO/ANGLE/AIR flight mode, it’s built-in Eachine Beecore V2.0 flight controller and 700TVL 1/4’ CMOS Camera and 5.8g 48CH 25mw VTX, the camera comes with an lens angle adjustable holder, the Booster 615 coreless motor supply much more power ,it’s a best Micro in-door FPV racing drone which include all your need’s FPV gears.
Specification:
Wheelbase:65mm
Prop size: 31mm
Weight:20g (Not include the battery);
26g (Include 4.35v 250mah battery)
Battery Power: 3.8v 250mah 30C
Battery Connection Plug:PH1.25
Camera: 700TVL 130degree 1/4’ CMOS
VTX:5.8G 48CH 25mw
Motor: 0615 Coreless motor
Frame: High quality ABS
Flight controller: Eachine Beecore V2.0
Features:
- Betaflight 3.2.2 Firmware
- F3 Flight controller Built-in Betaflight OSD
- Support ACRO/ANGLE/AIR flight mode
- Comes with four LED’s(2 red + 2white)
- Camera Lens Angle adjustable
- 0615 Booster coreless motor supply much more punch
- HV 4.35v Lipo much more power
2.4G Receiver option:
Frsky 8CH protocol D8 Mode (SBUS)
Flysky 6CH AFHDS 2A protocol (IBUS)
Spektrum DSM2/DSMX protocol
Compatible:
1.Frsky Receiver Support FRSKY X9D/X9D PLUS(D8 mode),and XJT (D8 Mode),DJT DFT DHT Transmitter.
2.Flysky Receiver Support Eachine i6, FS-i4, FS-i6, FS-i6S, FS-i6X, FS-i10, FS-GT2E, FS-GT2G, FS-GT2F, Turnigy Evolution Transmitter.
3.Spektrum DSM2/DSMX Receiver Support Spectrum/JR(DSM2/DSMX protocol) DEVO10/DEVO 7E(with deviation firmware).
In the Box:
Basic Version:
1 x 65mm Frame
1 x Cover
4 x 31mm Propellers
1 x Eachine Beecore V2.0 flight controller(Built-in 2.4G receiver and OSD)
1 x Aio 3in1 Camera & vtx
4 x 615 coreless motor
1 x 3.8v 250mah 30C Lipo Battery
1 x 4.35v USB charger
1x Propeller disassembly tools
Standard Version (this is my version):
1 x 65mm Frame
1 x Cover
8 x 31mm Propellers
3 x 3.8v 250mah 30C Lipo Battery
1 x Propeller disassembly tools
Advanced Version:
3 x 65mm Frame
3 x Cover
12x 31mm Propellers
6 x 3.8v 250mah 30C Lipo Battery
1 x 4.35v 6-way charger charger
Pros:
  • BetaFlight FW - upgradable and highly customizable by the user
  • FPV cam has tilt mechanism
  • Flies great "out of the box"
  • HV lipos
  • Very fast
  • OSD
  • Nice control range
  • Nice video transmission range
  • Grear BNF kit (I got Standard Version with 3 lipos and USB single lipo charger)
Cons:
Conclusion:
Great little flyer. Tons of fun, zero issues. Highly recomedned.
Grab yours QX65 HERE
Feb 11, 2018, 05:12 PM
FPV addict
mlilasic's Avatar
def BF settings
Feb 11, 2018, 05:13 PM
FPV addict
mlilasic's Avatar
ALL DEFAULT "out of the box" settings...
Feb 12, 2018, 06:36 AM
Bill Glover's Avatar
Originally Posted by mlilasic
def BF settings
Looks pretty smooth on those. Would be interesting to see diff output, if you still have the default settings?
Hoping my QX65 arrives soon!
I would regard the 1.25 pack connector as a small "Con" as most Lipos seem to have the 2.0 one. But it's easy enough to replace the battery pigtail.
Latest blog entry: Eachine QX65 FPV quad review
Feb 12, 2018, 04:23 PM
FPV addict
mlilasic's Avatar
Agreed on the connector, E010S had more robust connector also.
Here is my diff, its almost "out of the box", I just adjusted flight modes, calibrated voltage with multimeter and cleaned up the osd a little:
Code:
# diff
# Betaflight / OMNIBUS (OMNI) 3.2.2 Nov 11 2017 / 00:38:45 (77782e602) MSP API: 1.36
name MLI_QX65
feature -RX_PPM
feature RX_SERIAL
feature MOTOR_STOP
beeper -GYRO_CALIBRATED
beeper -RX_LOST
beeper -RX_LOST_LANDING
beeper -DISARMING
beeper -ARMING
beeper -ARMING_GPS_FIX
beeper -BAT_CRIT_LOW
beeper -BAT_LOW
beeper -RX_SET
beeper -ACC_CALIBRATION
beeper -ACC_CALIBRATION_FAIL
beeper -READY_BEEP
beeper -DISARM_REPEAT
beeper -ARMED
beeper -SYSTEM_INIT
beeper -ON_USB
beeper -BLACKBOX_ERASE
serial 2 64 115200 57600 0 115200
aux 0 0 0 1300 2100
aux 1 1 1 900 1300
aux 2 2 1 1300 1700
aux 3 28 1 1550 2100
rxfail 4 s 1000
rxfail 5 s 1000
set baro_hardware = NONE
set rssi_channel = 9
set serialrx_provider = SBUS
set blackbox_device = NONE
set motor_pwm_protocol = BRUSHED
set vbat_min_cell_voltage = 29
set vbat_warning_cell_voltage = 29
set current_meter = NONE
set vbat_scale = 111
set osd_vbat_pos = 2081
set osd_rssi_pos = 2049
set osd_tim_1_pos = 54
set osd_tim_2_pos = 2060
set osd_flymode_pos = 2456
set osd_throttle_pos = 2305
set osd_vtx_channel_pos = 377
set osd_crosshairs = 200
set osd_ah_sbar = 200
set osd_ah_pos = 200
set osd_current_pos = 385
set osd_mah_drawn_pos = 353
set osd_craft_name_pos = 2433
set osd_gps_speed_pos = 218
set osd_gps_lon_pos = 82
set osd_gps_lat_pos = 65
set osd_gps_sats_pos = 51
set osd_home_dir_pos = 302
set osd_home_dist_pos = 303
set osd_compass_bar_pos = 266
set osd_altitude_pos = 247
set osd_pid_roll_pos = 423
set osd_pid_pitch_pos = 455
set osd_pid_yaw_pos = 487
set osd_debug_pos = 1
set osd_power_pos = 321
set osd_pidrate_profile_pos = 345
set osd_warnings_pos = 329
set osd_avg_cell_voltage_pos = 44
set osd_pit_ang_pos = 257
set osd_rol_ang_pos = 289
set osd_battery_usage_pos = 392
set osd_disarmed_pos = 2315
set osd_nheading_pos = 311
set osd_nvario_pos = 279
set osd_esc_tmp_pos = 82
set osd_esc_rpm_pos = 83
profile 0
rateprofile 0
Feb 13, 2018, 06:59 AM
Thanks for that - I was interested to see whether it shipped with specific PIDs, but it obviously just has the BF defaults.
Even my son's old Eachine E010 uses the 2.0 connector (albeit on the board, rather than a pigtail)!
Feb 14, 2018, 08:10 AM
FPV addict
mlilasic's Avatar
Feb 14, 2018, 11:31 AM
FPV addict
mlilasic's Avatar
res
Feb 15, 2018, 03:59 PM
FPV addict
mlilasic's Avatar
Feb 19, 2018, 09:54 AM
FPV addict
mlilasic's Avatar
Feb 20, 2018, 07:49 AM
FPV addict
mlilasic's Avatar
Cruising speed endurance test: 4min
Eachine QX65 - cruising speed endurance test: 4m - F3 OSD 65mm Micro FPV Quad - tiny whoop (4 min 26 sec)
Feb 20, 2018, 08:57 AM
FPV addict
mlilasic's Avatar
From this point on flights are with my new settings:
Code:
CLI
# dump
name MLI_QX65
resource BEEPER 1 C15
resource MOTOR 1 B08
resource MOTOR 2 B09
resource MOTOR 3 A03
resource MOTOR 4 A02
resource MOTOR 5 B07
resource MOTOR 6 B06
resource MOTOR 7 NONE
resource MOTOR 8 NONE
resource SERVO 1 NONE
resource SERVO 2 NONE
resource SERVO 3 NONE
resource SERVO 4 NONE
resource SERVO 5 NONE
resource SERVO 6 NONE
resource SERVO 7 NONE
resource SERVO 8 NONE
resource PPM 1 B04
resource PWM 1 NONE
resource PWM 2 NONE
resource PWM 3 NONE
resource PWM 4 NONE
resource PWM 5 NONE
resource PWM 6 NONE
resource PWM 7 NONE
resource PWM 8 NONE
resource LED_STRIP 1 A08
resource SERIAL_TX 1 A09
resource SERIAL_TX 2 A14
resource SERIAL_TX 3 B10
resource SERIAL_TX 4 NONE
resource SERIAL_TX 5 NONE
resource SERIAL_TX 6 NONE
resource SERIAL_TX 7 NONE
resource SERIAL_TX 8 NONE
resource SERIAL_TX 9 NONE
resource SERIAL_TX 10 NONE
resource SERIAL_TX 11 NONE
resource SERIAL_TX 12 NONE
resource SERIAL_RX 1 A10
resource SERIAL_RX 2 A15
resource SERIAL_RX 3 B11
resource SERIAL_RX 4 NONE
resource SERIAL_RX 5 NONE
resource SERIAL_RX 6 NONE
resource SERIAL_RX 7 NONE
resource SERIAL_RX 8 NONE
resource SERIAL_RX 9 NONE
resource SERIAL_RX 10 NONE
resource SERIAL_RX 11 NONE
resource SERIAL_RX 12 NONE
resource I2C_SCL 1 NONE
resource I2C_SCL 2 NONE
resource I2C_SDA 1 NONE
resource I2C_SDA 2 NONE
resource LED 1 B03
resource LED 2 NONE
resource LED 3 NONE
resource RX_BIND 1 NONE
resource RX_BIND_PLUG 1 NONE
resource TRANSPONDER 1 A08
resource SPI_SCK 1 A05
resource SPI_SCK 2 B13
resource SPI_SCK 3 NONE
resource SPI_MISO 1 A06
resource SPI_MISO 2 B14
resource SPI_MISO 3 NONE
resource SPI_MOSI 1 A07
resource SPI_MOSI 2 B15
resource SPI_MOSI 3 NONE
resource ESCSERIAL 1 B04
resource CAMERA_CONTROL 1 NONE
resource ADC_BATT 1 A00
resource ADC_RSSI 1 NONE
resource ADC_CURR 1 A01
resource ADC_EXT 1 NONE
resource BARO_CS 1 A13
mixer QUADX
mmix reset
servo 0 1000 2000 1500 100 -1
servo 1 1000 2000 1500 100 -1
servo 2 1000 2000 1500 100 -1
servo 3 1000 2000 1500 100 -1
servo 4 1000 2000 1500 100 -1
servo 5 1000 2000 1500 100 -1
servo 6 1000 2000 1500 100 -1
servo 7 1000 2000 1500 100 -1
smix reset
feature -RX_PPM
feature -INFLIGHT_ACC_CAL
feature -RX_SERIAL
feature -MOTOR_STOP
feature -SERVO_TILT
feature -SOFTSERIAL
feature -GPS
feature -SONAR
feature -TELEMETRY
feature -3D
feature -RX_PARALLEL_PWM
feature -RX_MSP
feature -RSSI_ADC
feature -LED_STRIP
feature -DISPLAY
feature -OSD
feature -CHANNEL_FORWARDING
feature -TRANSPONDER
feature -AIRMODE
feature -RX_SPI
feature -SOFTSPI
feature -ESC_SENSOR
feature -ANTI_GRAVITY
feature -DYNAMIC_FILTER
feature RX_SERIAL
feature OSD
feature AIRMODE
feature DYNAMIC_FILTER
beeper -RX_LOST
beeper -DISARMING
beeper -ARMING
beeper -BAT_LOW
beeper GPS_STATUS
beeper -RX_SET
beeper -READY_BEEP
beeper MULTI_BEEPS
beeper -ARMED
beeper -SYSTEM_INIT
beeper -ON_USB
map AETR1234
serial 20 1 115200 57600 0 115200
serial 0 0 115200 57600 0 115200
serial 1 0 115200 57600 0 115200
led 0 0,0::C:0
led 1 0,0::C:0
led 2 0,0::C:0
led 3 0,0::C:0
led 4 0,0::C:0
led 5 0,0::C:0
led 6 0,0::C:0
led 7 0,0::C:0
led 8 0,0::C:0
led 9 0,0::C:0
led 10 0,0::C:0
led 11 0,0::C:0
led 12 0,0::C:0
led 13 0,0::C:0
led 14 0,0::C:0
led 15 0,0::C:0
led 16 0,0::C:0
led 17 0,0::C:0
led 18 0,0::C:0
led 19 0,0::C:0
led 20 0,0::C:0
led 21 0,0::C:0
led 22 0,0::C:0
led 23 0,0::C:0
led 24 0,0::C:0
led 25 0,0::C:0
led 26 0,0::C:0
led 27 0,0::C:0
led 28 0,0::C:0
led 29 0,0::C:0
led 30 0,0::C:0
led 31 0,0::C:0
color 0 0,0,0
color 1 0,255,255
color 2 0,0,255
color 3 30,0,255
color 4 60,0,255
color 5 90,0,255
color 6 120,0,255
color 7 150,0,255
color 8 180,0,255
color 9 210,0,255
color 10 240,0,255
color 11 270,0,255
color 12 300,0,255
color 13 330,0,255
color 14 0,0,0
color 15 0,0,0
mode_color 0 0 1
mode_color 0 1 11
mode_color 0 2 2
mode_color 0 3 13
mode_color 0 4 10
mode_color 0 5 3
mode_color 1 0 5
mode_color 1 1 11
mode_color 1 2 3
mode_color 1 3 13
mode_color 1 4 10
mode_color 1 5 3
mode_color 2 0 10
mode_color 2 1 11
mode_color 2 2 4
mode_color 2 3 13
mode_color 2 4 10
mode_color 2 5 3
mode_color 3 0 8
mode_color 3 1 11
mode_color 3 2 4
mode_color 3 3 13
mode_color 3 4 10
mode_color 3 5 3
mode_color 4 0 7
mode_color 4 1 11
mode_color 4 2 3
mode_color 4 3 13
mode_color 4 4 10
mode_color 4 5 3
mode_color 5 0 9
mode_color 5 1 11
mode_color 5 2 2
mode_color 5 3 13
mode_color 5 4 10
mode_color 5 5 3
mode_color 6 0 6
mode_color 6 1 10
mode_color 6 2 1
mode_color 6 3 0
mode_color 6 4 0
mode_color 6 5 2
mode_color 6 6 3
mode_color 6 7 6
mode_color 6 8 0
mode_color 6 9 0
mode_color 6 10 0
mode_color 7 0 3
aux 0 0 0 1300 2100
aux 1 1 1 900 1300
aux 2 2 1 1300 1700
aux 3 0 0 900 900
aux 4 0 0 900 900
aux 5 0 0 900 900
aux 6 0 0 900 900
aux 7 0 0 900 900
aux 8 0 0 900 900
aux 9 0 0 900 900
aux 10 0 0 900 900
aux 11 0 0 900 900
aux 12 0 0 900 900
aux 13 0 0 900 900
aux 14 0 0 900 900
aux 15 0 0 900 900
aux 16 0 0 900 900
aux 17 0 0 900 900
aux 18 0 0 900 900
aux 19 0 0 900 900
adjrange 0 1 0 900 1200 12 1
adjrange 1 0 0 900 900 0 0
adjrange 2 0 0 900 900 0 0
adjrange 3 0 0 900 900 0 0
adjrange 4 0 0 900 900 0 0
adjrange 5 0 0 900 900 0 0
adjrange 6 0 0 900 900 0 0
adjrange 7 0 0 900 900 0 0
adjrange 8 0 0 900 900 0 0
adjrange 9 0 0 900 900 0 0
adjrange 10 0 0 900 900 0 0
adjrange 11 0 0 900 900 0 0
adjrange 12 0 0 900 900 0 0
adjrange 13 0 0 900 900 0 0
adjrange 14 0 0 900 900 0 0
rxrange 0 1000 2000
rxrange 1 1000 2000
rxrange 2 1000 2000
rxrange 3 1000 2000
vtx 0 0 0 0 900 900
vtx 1 0 0 0 900 900
vtx 2 0 0 0 900 900
vtx 3 0 0 0 900 900
vtx 4 0 0 0 900 900
vtx 5 0 0 0 900 900
vtx 6 0 0 0 900 900
vtx 7 0 0 0 900 900
vtx 8 0 0 0 900 900
vtx 9 0 0 0 900 900
rxfail 0 a
rxfail 1 a
rxfail 2 a
rxfail 3 a
rxfail 4 s 1000
rxfail 5 s 1000
rxfail 6 h
rxfail 7 h
rxfail 8 h
rxfail 9 h
rxfail 10 h
rxfail 11 h
rxfail 12 h
rxfail 13 h
rxfail 14 h
rxfail 15 h
rxfail 16 h
rxfail 17 h
set align_gyro = DEFAULT
set gyro_lpf = OFF
set gyro_sync_denom = 2
set gyro_lowpass_type = PT1
set gyro_lowpass_hz = 90
set gyro_notch1_hz = 0
set gyro_notch1_cutoff = 300
set gyro_notch2_hz = 0
set gyro_notch2_cutoff = 100
set moron_threshold = 48
set align_acc = DEFAULT
set acc_hardware = AUTO
set acc_lpf_hz = 10
set acc_trim_pitch = 0
set acc_trim_roll = 0
set align_mag = DEFAULT
set mag_hardware = NONE
set mag_declination = 0
set magzero_x = 0
set magzero_y = 0
set magzero_z = 0
set baro_bustype = SPI
set baro_spi_device = 1
set baro_i2c_device = 0
set baro_i2c_address = 0
set baro_tab_size = 21
set baro_noise_lpf = 600
set baro_cf_vel = 985
set baro_cf_alt = 965
set mid_rc = 1500
set min_check = 1050
set max_check = 1900
set rssi_scale = 41
set rssi_invert = OFF
set rc_interp = AUTO
set rc_interp_ch = RP
set rc_interp_int = 19
set fpv_mix_degrees = 0
set max_aux_channels = 14
set sbus_inversion = ON
set spektrum_sat_bind = 0
set spektrum_sat_bind_autoreset = ON
set airmode_start_throttle = 1350
set rx_min_usec = 885
set rx_max_usec = 2115
set input_filtering_mode = OFF
set blackbox_p_ratio = 32
set blackbox_on_motor_test = OFF
set blackbox_record_acc = ON
set min_throttle = 1040
set max_throttle = 2000
set min_command = 1000
set dshot_idle_value = 450
set use_unsynced_pwm = ON
set motor_pwm_rate = 16000
set motor_pwm_inversion = OFF
set thr_corr_value = 0
set thr_corr_angle = 800
set failsafe_delay = 4
set failsafe_off_delay = 10
set failsafe_throttle = 1000
set failsafe_kill_switch = OFF
set failsafe_throttle_low_delay = 100
set failsafe_procedure = DROP
set align_board_roll = 0
set align_board_pitch = 0
set align_board_yaw = 0
set gimbal_mode = NORMAL
set bat_capacity = 0
set vbat_max_cell_voltage = 43
set vbat_full_cell_voltage = 41
set vbat_hysteresis = 1
set battery_meter = ADC
set vbat_detect_cell_voltage = 30
set use_vbat_alerts = ON
set use_cbat_alerts = OFF
set cbat_alert_percent = 10
set vbat_cutoff_percent = 100
set ibata_scale = 400
set ibata_offset = 0
set ibatv_scale = 0
set ibatv_offset = 0
set beeper_inversion = ON
set beeper_od = OFF
set beeper_frequency = 0
set beeper_dshot_beacon_tone = 0
set yaw_motors_reversed = OFF
set 3d_deadband_low = 1406
set 3d_deadband_high = 1514
set 3d_neutral = 1460
set 3d_deadband_throttle = 50
set servo_center_pulse = 1500
set servo_pwm_rate = 50
set servo_lowpass_hz = 0
set tri_unarmed_servo = ON
set channel_forwarding_start = 4
set reboot_character = 82
set serial_update_rate_hz = 100
set accxy_deadband = 40
set accz_deadband = 40
set acc_unarmedcal = ON
set imu_dcm_kp = 2500
set imu_dcm_ki = 0
set small_angle = 25
set auto_disarm_delay = 5
set disarm_kill_switch = ON
set gyro_cal_on_first_arm = OFF
set fixedwing_althold_reversed = OFF
set alt_hold_deadband = 40
set alt_hold_fast_change = ON
set deadband = 0
set yaw_deadband = 0
set yaw_control_reversed = OFF
set pid_process_denom = 1
set tlm_switch = OFF
set tlm_inverted = OFF
set tlm_halfduplex = ON
set frsky_default_lat = 0
set frsky_default_long = 0
set frsky_gps_format = 0
set frsky_unit = IMPERIAL
set frsky_vfas_precision = 0
set hott_alarm_int = 5
set pid_in_tlm = OFF
set ledstrip_visual_beeper = OFF
set sdcard_dma = OFF
set osd_units = METRIC
set osd_rssi_alarm = 20
set osd_cap_alarm = 2200
set osd_alt_alarm = 100
set osd_ah_max_pit = 20
set osd_ah_max_rol = 40
set osd_tim1 = 2560
set osd_tim2 = 2561
set osd_pidrate_profile_pos = 2446
set osd_stat_max_spd = OFF
set osd_stat_max_dist = OFF
set osd_stat_min_batt = ON
set osd_stat_min_rssi = OFF
set osd_stat_max_curr = OFF
set osd_stat_used_mah = OFF
set osd_stat_max_alt = OFF
set osd_stat_bbox = OFF
set osd_stat_endbatt = ON
set osd_stat_bb_no = OFF
set osd_stat_tim_1 = OFF
set osd_stat_tim_2 = ON
set task_statistics = ON
set debug_mode = NONE
set pwr_on_arm_grace = 0
set vtx_halfduplex = ON
set vcd_video_system = 0
set vcd_h_offset = 0
set vcd_v_offset = 0
set max7456_clock = DEFAULT
set displayport_msp_col_adjust = 0
set displayport_msp_row_adjust = 0
set displayport_max7456_col_adjust = 0
set displayport_max7456_row_adjust = 0
set displayport_max7456_inv = OFF
set displayport_max7456_blk = 0
set displayport_max7456_wht = 2
set esc_sensor_halfduplex = OFF
set led_inversion = 0
set dashboard_i2c_bus = 1
set dashboard_i2c_addr = 60
set camera_control_mode = HARDWARE_PWM
set camera_control_ref_voltage = 330
set camera_control_key_delay = 180
set camera_control_internal_resistance = 470
profile 1
set dterm_lowpass_type = BIQUAD
set dterm_lowpass = 100
set dterm_notch_hz = 260
set dterm_notch_cutoff = 160
set vbat_pid_gain = OFF
set pid_at_min_throttle = ON
set anti_gravity_threshold = 350
set anti_gravity_gain = 1000
set setpoint_relax_ratio = 60
set dterm_setpoint_weight = 60
set acc_limit_yaw = 100
set acc_limit = 0
set crash_dthreshold = 50
set crash_gthreshold = 400
set crash_setpoint_threshold = 350
set crash_time = 500
set crash_delay = 0
set crash_recovery_angle = 10
set crash_recovery_rate = 100
set crash_limit_yaw = 200
set crash_recovery = OFF
set iterm_windup = 50
set iterm_limit = 150
set pidsum_limit = 500
set pidsum_limit_yaw = 400
set yaw_lowpass = 0
set p_pitch = 100
set i_pitch = 130
set d_pitch = 45
set p_roll = 90
set i_roll = 110
set d_roll = 45
set p_yaw = 190
set i_yaw = 120
set d_yaw = 20
set p_alt = 50
set i_alt = 0
set d_alt = 0
set p_level = 80
set i_level = 30
set d_level = 25
set p_vel = 55
set i_vel = 55
set d_vel = 75
set level_limit = 55
set horizon_tilt_effect = 75
set horizon_tilt_expert_mode = OFF
rateprofile 0
set rc_rate = 221
set rc_rate_yaw = 207
set rc_expo = 0
set rc_expo_yaw = 0
set thr_mid = 50
set thr_expo = 0
set roll_srate = 0
set pitch_srate = 0
set yaw_srate = 0
set tpa_rate = 10
set tpa_breakpoint = 1650
Feb 22, 2018, 04:11 AM
I need to change my voltage scale as I noticed it reads 4.0 with a freshly charged HV pack.
Your house is a much better layout for flying than mine
Feb 22, 2018, 08:16 AM
FPV addict
mlilasic's Avatar
Thanks. Outside is snow so I am forced to fly indoors.
Eachine QX65 - snow run - F3 OSD 65mm Micro FPV Quad - tiny whoop (1 min 37 sec)
And yes, I calibrated voltage sensing with a multimeter.
Did you maybe discover why RSSI doesn't work?
I have same FC on my other whoop and RSSI works:
DVR flight of Eachine E011C + Beecore V2.0 Brushed F3+OSD Flight Control Board - tiny whoop (2 min 2 sec)
New Product Eachine QX65 with 3 Flight Mode 615 Motor 5.8G 48CH 700TVL Camera Micro FPV Racing Dr smg24 Banggood.com 352 Yesterday 04:18 AM
Mini-Review Eachine Tiny QX90 - Brushed Micro FPV Quad with F3 Board (review, work in progress) SoloProFan Micro Multirotor Drones 16 Jan 01, 2017 08:22 AM
