Blade Nano QX Issue - RC Groups
Feb 10, 2018, 01:44 PM
Blade Nano QX Issue
After binding with the transmitter, the propellers start spinning without any throttle. I have the throttle all the way down and the motors are still spinning the propellers.
I can control it pretty well but when it crashes it wonít stop spinning the propellers unless I power off the transmitter.
I donít know if itís a problem with the drone or with the transmitter.
Feb 10, 2018, 02:04 PM
KC
KC
Registered Loiterer.
KC's Avatar
Itís probably the Tx. Try putting in down trim on the throttle.
Which Tx are you using?
Welcome to RCG, by the way!
Feb 10, 2018, 02:31 PM
Iím not sure how to do that.
I have the Blade MLP4DSM transmitter. The drone was a gift and didnít come with a transmitter. I ordered this on off eBay. Did I maybe buy a lemon transmitter?
Feb 10, 2018, 02:45 PM
KC
KC
KC's Avatar
The two throttle trim buttons are located just right of the throttle stick. Press the bottom one several times to trim the throttle down till the motors stops spinning.
Feb 10, 2018, 02:56 PM
Thanks. Ok so I pressed the bottom button all the way to the lowest setting and it still didn’t stop the motors. It did slow them down some though.
Feb 10, 2018, 03:23 PM
KC
KC
KC's Avatar
That’s promising.
I would try rebinding. Make sure all the trims are centered and the throttle stick is all the way at the bottom.
I found this video that might be helpful.
How to Fly the Blade Nano QX Part 6 Binding (3 min 22 sec)
Help! Blade Nano qx bnf motor issue :/ x_Klean_x Multirotor Drone Electronics 0 Jun 20, 2016 09:07 PM
Question Blade Nano QX FPV Motor Issue snoopstar Mini Multirotor Drones 2 Feb 19, 2016 11:11 AM
Discussion Blade Nano qx FPV issues Cman Mini Multirotor Drones 2 Nov 14, 2015 08:33 PM
Discussion Turnigy 9X \ OrangeRX DSMX module \ Blade Nano QX issue OhOneWS6 Radios 1 Nov 25, 2014 09:29 AM
Discussion Blade Nano QX Issues / Questions pfriederichs Mini Multirotor Drones 0 Jul 15, 2013 08:51 PM
