Eachine Wizard TS215 215mm FPV Racing RC Drone F4 5.8G 72CH 40A BLHeli_32 720P DVR 12 - RC Groups
This thread is privately moderated by scousethief, who may elect to delete unwanted replies.
Feb 10, 2018, 07:08 AM
Quad Erat Demonstrandum
scousethief's Avatar
https://www.banggood.com/Eachine-Wizard-TS215-215mm-FPV-Racing-RC-Drone-F4-5_8G-72CH-40A-BLHeli_32-720P-DVR-1200TVL-BNF-PNP-p-1259022.html
Do we have an Eachine brand mascot ?
The included accessory pack , the addition of a carbon plate for battery protection , non-slip pad and foam risers means you dont have to buy "extras"
The props are some of my favourite , Dal Cyclones , these are nice and reliable and some of the best props you can get imo.
A full bag of replacement bolts.
standard lock-nuts
Carbon spanners , i am assuming the inclusion of the "gun" is to show off the cutting skill of the router, or is the first piece cut as a test.
The internals. The Wizard TS215 is a triple stack configuration with the bottom level comprising the PDB and Flight Controller Onboard DVR takes the middle section whilst Video transmitter is the top board and shows selection via a single digit LCD , selection button is on the opposite side. Underneath you can see the Microsd slot for the onboard DVR. Both sides are easily accessible so theres no issues changing settings. The is a buzzer hidden in there as well so remember to remove the paper cover.
The video antenna is a "stubby" or a shorter than standard clone of the TBS Triumph . This side also has the MicroSD slot for the flight controllers black box and the usb connector for firmware upgrades and PiD tuning should you prefer to use your computer/phone rather than the OSD. The antenna will be moved to the standard position of the top rear for mine.
The Esc's are 32bit 40Amp and 5S capable which should be more than capable of supplying this birds power requirements. Each Esc has its own status Led and are coloured , i assume these can be programmed to suit the owners choice.
The motors are really quite beautiful , the picture does them no favours. The windings are exceptionally clean and tidy and the motors turn with a very slight but definite "cogging" . The specs list these as 12N14P and 2450 kv giving a max thrust of 2300g when running a 6x4 2 blade prop....................... thats insane
Discussion Eachine Wizard TS215 215mm F4 5.8G 72CH 40A BLHeli_32 720P DVR 1200TVL BobFromMars Banggood.com 3 Feb 02, 2018 06:52 PM
Discussion Eachine Lizard105S FPV Racing Drone BNF Omnibus F4SD 28A Blheli_S ESC 720P DVR 5.8g BobFromMars Banggood.com 1 Feb 01, 2018 12:16 PM
Discussion Eachine Wizard X220S FPV Racer Omnibus F4 5.8G 72CH VTX No Receiver version scousethief Banggood.com 0 May 26, 2017 10:56 AM
Discussion Smart Drone SMD Red Arrow Racing 5.8G FPV 720P Camera 2.4G 8CH RC Quadcopter GeekBuying Geekbuying.com 0 Oct 18, 2016 05:17 AM
