This thread is privately moderated by Herb, who may elect to delete unwanted replies.
Apr 07, 2019, 12:17 PM
Lithium Member
Herb's Avatar
Another good day at the field flying the F-4 Phantom
After a year of flying & abuse still all original retract pins etc. but two slightly cracked mains gear doors (been too lazy to replace).
JetFan 90 / HET inrunner motor & Hitec HS5245MG servo on elevator.
Apr 11, 2019, 12:00 PM
Lithium Member
Herb's Avatar
The original F-4 Phantom was/is a Mach 2.2+ fighter jet ...
The foam model flies pretty jet-like, but could always use some extra speed & performance .
This could be achieved say by brute force, using a 14S setup - which nevertheless makes little sense in this rather draggy foamie, with $2 flimsy styrene retract mounts etc. ...
Another option is to improve flight characteristics by reducing drag. The foam model has plenty of it : ridges, finger-deep panel lines, bumps, large wide slots, sharp blunt edges etc.
I did not want to ruin the top-side appearance of the F-4. So all my filling & sanding work was confined to the bottom, as on many of my other foamies.
For ex. a smooth clean wing & tail surfaces will give some slight improvement in top speed, and improved overall handling. That's at least my experience
Apr 11, 2019, 12:27 PM
Innocent Bystander
Bobaroo's Avatar
We are 'Worlds Apart' on this whole Minimize Drag on our F-4s thing Herb ... !!! Hahahahaha Cheers !!
Apr 11, 2019, 03:36 PM
Lithium Member
Herb's Avatar
I like both When I fly though I prefer a cleaner airframe ...
Turbines have excess power, so there stores hanging off the wings matter less ... To me EDFs are always on the edge of being underpowered
Apr 11, 2019, 05:28 PM
I NEED those bombs and rockets !
Where can I get them ? Thanks
Apr 14, 2019, 11:55 AM
Lithium Member
Herb's Avatar
Some more good flights on the Phantom yesterday ...
Took a couple of pictures of my "straight and level" elevator trim after a year of flying, and with the CG moved slightly back with respect to the manual,
New Product Freewing 90mm F-4 Phantom xplaneguy Foamy EDFs 5883 Yesterday 03:57 PM
Discussion Freewing F-104 Starfighter 90mm EDF Rich2wd Foamy EDFs 3387 Apr 17, 2019 10:44 AM
