May 08, 2019, 03:53 PM
Originally Posted by Zenoaheli
hi vasy, i need a fully carbon fan for my f100 ducting is done for 90mm, and i need like 15 lbs of thrust is that possible? price? im ready wth paypal
Hello.
Please email me for order and other questions... Here on the forum I am not often active.
[email protected]
www.vasyfan.com
Best regards
Vasy.
May 08, 2019, 03:56 PM
Zenoaheli's Avatar
i will do that thanks
May 10, 2019, 04:42 AM
MIG-15 & edf VF-160
Dear boys, I answer for everyone! 😊
The acceleration in flight has increased a little, but the static thrust on the test bench and consumption has remained the same!
See you soon!
Best regards
May 10, 2019, 06:57 AM
My cat moderates better
BillzillaAus's Avatar
Originally Posted by Vasyfan
Dear friends!
Flight test, Edf 160mm with giant lip!
https://youtu.be/4L0mXM6JktY
It sounds more like a real jet, lovely!
Jun 24, 2019, 08:49 PM
demetrius's Avatar
wrong thread!
Jun 25, 2019, 07:36 AM
Lee Liddle
Knife Liddle's Avatar
Which diameter size is that?
Jun 25, 2019, 10:01 AM
Says 120 on it.
Any other other specs you can give us? Motor size, kv, thrust, etc.
Scott
Jun 25, 2019, 10:34 AM
Pro Hoarder
turbonut's Avatar
Cool .What is that going into?
Latest blog entry: In flight
Jun 25, 2019, 11:50 AM
demetrius's Avatar
Originally Posted by Scottfpv
Says 120 on it.
Scott
That's the mystery! All the detailed specs point to the older version however this one has the new spinner and aluminum motor housing which looks great compared to the older version however on Vasa's website, all of the information is based on the older version. I suspect it's the same. The motor housing is set up for 50mm motor however I played around with several motors I have the Neu 1527,1.5y which fits with two heat sinks and the tail cone on it.
I'm thinking of going with the Hacker 700 "E-Series". E-Cal has it with great numbers on it with approximately 93amps 4200 watts and 6.4 grams of thrust. I would like to run this at 12s with approximately an 800 kV motor however I don't have that option without running into heat issues with the other motors. I'm still deciding.
Latest blog entry: "Is that a Turbine?" Not...
Jun 25, 2019, 11:52 AM
demetrius's Avatar
I just got my hands on a BVM Sport Jet
Jun 25, 2019, 12:12 PM
Originally Posted by AIR SALLY
They look nice, vids of them running or or flying would help a bunch.
Also there is a fan on the market named the "Vasa Fan" so it might confuse some people.
What are the sizes of the fans pictured?
I thought they were the same thing - my dyslexia acting up
Jun 25, 2019, 03:22 PM
Lithium Member
Herb's Avatar
VASYFAN is not VASA FAN ... Totally unrelated
Check out the respective websites, google is your friend ...
Jun 25, 2019, 04:00 PM
demetrius's Avatar
Herb,
I just realized my mistake when I mistakenly selected the first page of this thread just right now prior to reading your response!
Thanks for again for the correction.
Jun 25, 2019, 05:43 PM
Which sport jet?
Jun 25, 2019, 06:19 PM
Lithium Member
Herb's Avatar
Andrew, it is indeed very confusing !
Help! Freewing 80mm edf owners Please share your edf setup juanjulian Foamy EDFs 3 Oct 19, 2017 05:08 PM
Discussion How to dynamically balance the Delta V 180 28mm EDF (UMX size EDF's) 4stripes Micro EDF Jets and Power Systems 5 May 25, 2017 01:11 PM
Discussion Neptune EDF Flying Wing EDF Impeller/Unit ronmeister Electric Ducted Fan Jet Talk 1 Jul 09, 2016 05:24 PM
