Mar 13, 2018, 03:15 PM
Originally Posted by HVFeathers
Hi Vasyfan,
Crazy numbers! Absolutely mad. Such a beautiful fan too.
What wind did you select for your TP100? It sounds like your fan is running about 12.5krpm, but delivering 23kW, the TP100's max power rating for it's full speed. I suspect that the motor is saturating a bit. Do you know how warm the windings get?
I can't wait to see what you do with these monster EDF's.
Cheers,
- Feathers
Hi friend,
My TP100 is 25kw with 250kv. I bought it about 1 year ago, now there is no more on the tp table. After the video test the motor rotor arrived at a temperature of 47°C soon I will do the longest test to understand if it goes on a lot of temperature.
The EDF is designed for aircraft G91 3m.
Then maybe I should do another 6 edf for a client who is doing an experimental plane.
Greetings from Italy.
Vasy
Mar 13, 2018, 03:24 PM
Originally Posted by Zenoaheli
it seems the blade is much thinner than that of the jetfan, i wonder how this will affect the performance
Dear Zenoaheli,
The finest and easiest blade penetrating the air is less frictional, and the effect increases as a consequence.
The blade has been enlarged by the small edf type 90mm.
Regards
Vasy.
Mar 14, 2018, 10:25 AM
Zenoaheli's Avatar
Originally Posted by Vasyfan
Dear Zenoaheli,
Regards
Vasy.
Dear Vasy,
now they might start to copy you
Cheers, Zenoah !
Mar 14, 2018, 11:09 PM
Dear Vasy,
Cheers, Zenoah !
No problem is that there are still so many secrets! 😉😎
Mar 15, 2018, 01:09 AM
Lee Liddle
Knife Liddle's Avatar
That is an impressive unit! Would fly a massive single engine turbine airframe.
Mar 19, 2018, 07:23 AM
Lynxman's Avatar
I'd love to see a video of that giant G91 when it's done.
Mar 28, 2018, 05:51 AM
Micro-Turbine Superhero
henke's Avatar
I've been following this guy at facebook since 2015 and I have seen constant development being done during the years. From time to time I have compared numbers with others and found the fans to do well... just the other day I looked to se if he made a 64mm fan för my small foamies.
I never had the thought it would be schubi copies and I still doubt.
I call Vasyfan and his work legit. At the same time I se Schubi moving from carbon fans to plastic ones and removing lots of the old gems from the shop.
Apr 08, 2019, 09:58 AM
Dear friends, I want you to see the new edf 160 mm, tested at the desk at 12 and 14s.
Soon the test also in flight in the MIG-15 1/4.
Apr 08, 2019, 10:06 AM
I believe that I will fly if the weather permits me over the weekend. I look forward to putting this new 160mm edf on the web site.
Apr 08, 2019, 10:58 AM
Pro Hoarder
turbonut's Avatar
Cool! that fan looks small in the plane...One big Mig
Latest blog entry: In flight
Apr 08, 2019, 05:04 PM
Zenoaheli's Avatar
waow good job man! I see you got the blade curvature on lock
Apr 08, 2019, 05:05 PM
Zenoaheli's Avatar
what material is that mig 21? made out of?
Apr 08, 2019, 06:05 PM
Lynxman's Avatar
Looks like a plug. Very nicely done.
These fans are spectacular.
Apr 09, 2019, 05:44 PM
That mig 21 is an upcoming kit from Mugumodels
Help! Freewing 80mm edf owners Please share your edf setup juanjulian Foamy EDFs 3 Oct 19, 2017 05:08 PM
Discussion How to dynamically balance the Delta V 180 28mm EDF (UMX size EDF's) 4stripes Micro EDF Jets and Power Systems 5 May 25, 2017 01:11 PM
Discussion Neptune EDF Flying Wing EDF Impeller/Unit ronmeister Electric Ducted Fan Jet Talk 1 Jul 09, 2016 05:24 PM
