Review of Eachine Beecore Upgrade V2.0 Brushed F3+OSD Flight Control Board - RC Groups
This thread is privately moderated by mlilasic, who may elect to delete unwanted replies.
Feb 08, 2018, 07:37 PM
FPV addict
mlilasic's Avatar
Mini-Review
Review of Eachine Beecore Upgrade V2.0 Brushed F3+OSD Flight Control Board For Inductrix Tiny Whoop E010 E010S
My Beecore V2.0 FC just came. The first bind to Taranis and flight test went well.
Its almost plug n play. I connected motors and soldered power lead for an initial test that went great (I only had to adjust ch order and arming switch, all other is default).
Later I soldered FPV cam&VTX combo which I had laying around from my Lizard95 as I changed original one for SpeedBee SEC.
Eachine Beecore V2.0 Brushed Flight Control Board is a new upgraded version which integrated Betaflight OSD and MPU6000 at SPI bus. The new version also integrated 2.4G receiver with 3 versions to choose(FRSKY/FLYSKY/DSMX). It's the best flight controller for indoor brushed quadcopter (BeeDuctrix / Tiny Whoop / Inductrix setups/Eachine E010 E010C E010S ect.).
DVR flight of Eachine Beecore Upgrade V2.0 Brushed F3+OSD Flight Control Board build (2 min 38 sec)
Eachine QX65 - race test - 700TVL Camera F3 OSD 65mm Micro FPV Quad - tiny whoop (2 min 49 sec)
Fast home run & crash test - DVR flight of Eachine Beecore V2.0 Brushed F3+OSD FCd - tiny whoop (2 min 19 sec)
Eachine QX65 - 700TVL Camera F3 OSD 65mm Micro FPV Racing Drone Quadcopter - DVR maiden flight (1 min 38 sec)
Eachine QX65 - Tunnel run & crash test - "out of the box" F3 OSD 65mm Micro FPV Quad - tiny whoop (2 min 58 sec)
Specifications:
CPU: STM32F303CCT6
Six-Axis: MPU6500
ESC: All FETs are rated at 10A maximum
Work voltage: 3.5V-4.35V / 1S Lipo battery input
Firmware Version: BETAFLIGHTF 3.2.0
Firmware Target: Omnibus
OSD: Built-in BetaFlight OSD (STM32 controls OSD chip over SPI in DMA mode)
Size: 26mm x 26mm (Fully compatible with the Inductrix quad and Eachine E010/E010S frame and mounting pattern.)
Receiver option: Frsky 8CH protocol D8 Mode (SBUS)
Flysky 6CH AFHDS 2A protocol (IBUS)
Spektrum DSM2/DSMX protocol
Weight: 3.2g
Features:
1.The world's first F3_EVO controller compatible for Frsky/Flysky/DSM2 (Optional).
2.BETAFLIGHTF ready, born for acro flight controller for the BeeDuctrix / Tiny Whoop / Inductrix quad!
3.Full Cleanflight/Betaflight compatibility on a STM32 F303 F3_EVO 3x1 style processor.
4.Fully programmable through Cleanflight / Betalfight using the onboard USB port! Tune all the parameters, PID's, and rates to your perfect settings!
5.High discharge battery connector wire for more power and performance.
6.Can fly your Inductrix style quad in full rate mode (or even air mode!), fully execute flips/ rolls, and shoot the smallest of gaps with precision! Tuned to give you that locked in feeling you get with standard race quads.
Compatible with:
1.Frsky Receiver Support FRSKY X9D/X9D PLUS(D8 mode),and XJT (D8 Mode),DJT DFT DHT Transmitter.
2.Flysky Receiver Support Eachine i6, FS-i4, FS-i6, FS-i6S, FS-i6X, FS-i10, FS-GT2E, FS-GT2G, FS-GT2F, Turnigy Evolution Transmitter.
3.Spektrum DSM2/DSMX Receiver Support Spectrum/JR(DSM2/DSMX protocol) DEVO10/DEVO 7E(with deviation firmware).
In the Box:
1 x Beecore V2.0 Flight Control Board
3 x Power Cable (For Inductrix x1, For E010x1, For QX Serials x1)
4 x Rubber Shock Absorber
4 x Screws
Pros:
  • F3
  • BetaFlight SW - constant updates, development and highly customizable
  • OSD
  • Great control range
  • 3 type of power connectors, screws and rubber grommets are provided in the box
Cons:
None
Conclusion:
Highly recomended!
Grab yours Eachine Beecore V2.0 Brushed FC HERE.
FPV addict
mlilasic's Avatar
quick test build
and flight
Quick test flight of Eachine Beecore Upgrade V2.0 Brushed F3+OSD Flight Control Board build (1 min 23 sec)
Parts used:
Eachine Beecore Upgrade V2.0 Brushed F3+OSD FC - https://goo.gl/nM38tj
4X Chaoli CL-615 6x15mm Coreless Motor - https://goo.gl/7zT4jf
5PCS Eachine E010S 3.7V 150mAh 45C Battery USB Charger Set - https://goo.gl/zjcsi5
Eachine E010 RC Quadcopter Blades Propeller - https://goo.gl/xip6oP
Taranis Q X7 transmitter - http://goo.gl/iMrQu6
Skyzone FPV googles - https://goo.gl/zXK8Zg
with ImmersionRC SpiroNet Antenna - https://goo.gl/GvZJeG
HMDVR Mini DVR - https://goo.gl/xOtjm0
ISDT Q6 Plus 300W 14A MINI Pocket Battery Balance Charger - https://goo.gl/ZhxnYQ
Feb 08, 2018, 07:48 PM
FPV addict
mlilasic's Avatar
FPV added
FPV cam + VTX combo is taken from lizard95 - product LINK
Feb 10, 2018, 08:03 PM
FPV addict
mlilasic's Avatar
Fpv test rig
Feb 12, 2018, 05:17 PM
FPV addict
mlilasic's Avatar
my settings
Code:
# diff
# Betaflight / OMNIBUS (OMNI) 3.2.0 Sep 28 2017 / 16:38:02 (ceb6f70) MSP API: 1.36
name MLI_Beecore
feature -RX_PPM
feature RX_SERIAL
feature MOTOR_STOP
beeper -GYRO_CALIBRATED
beeper -RX_LOST
beeper -RX_LOST_LANDING
beeper -DISARMING
beeper -ARMING
beeper -ARMING_GPS_FIX
beeper -BAT_CRIT_LOW
beeper -BAT_LOW
beeper -GPS_STATUS
beeper -RX_SET
beeper -ACC_CALIBRATION
beeper -ACC_CALIBRATION_FAIL
beeper -READY_BEEP
beeper -MULTI_BEEPS
beeper -DISARM_REPEAT
beeper -ARMED
beeper -SYSTEM_INIT
beeper -ON_USB
beeper -BLACKBOX_ERASE
serial 2 64 115200 57600 0 115200
aux 0 0 0 1300 2100
aux 1 1 1 900 1300
aux 2 2 1 1300 1700
rxfail 4 s 1000
rxfail 5 s 1000
set baro_hardware = NONE
set min_check = 1020
set rssi_channel = 9
set serialrx_provider = SBUS
set blackbox_device = NONE
set motor_pwm_protocol = BRUSHED
set current_meter = NONE
set vbat_scale = 112
set pid_process_denom = 2
set osd_vbat_pos = 2081
set osd_rssi_pos = 2113
set osd_tim_1_pos = 65
set osd_tim_2_pos = 2049
set osd_flymode_pos = 2073
set osd_throttle_pos = 225
set osd_vtx_channel_pos = 377
set osd_crosshairs = 200
set osd_ah_sbar = 200
set osd_ah_pos = 200
set osd_current_pos = 385
set osd_mah_drawn_pos = 353
set osd_craft_name_pos = 2506
set osd_gps_speed_pos = 218
set osd_gps_lon_pos = 82
set osd_gps_lat_pos = 65
set osd_gps_sats_pos = 51
set osd_home_dir_pos = 302
set osd_home_dist_pos = 303
set osd_compass_bar_pos = 266
set osd_altitude_pos = 247
set osd_pid_roll_pos = 423
set osd_pid_pitch_pos = 455
set osd_pid_yaw_pos = 487
set osd_debug_pos = 1
set osd_power_pos = 321
set osd_pidrate_profile_pos = 345
set osd_warnings_pos = 426
set osd_avg_cell_voltage_pos = 76
set osd_pit_ang_pos = 257
set osd_rol_ang_pos = 289
set osd_battery_usage_pos = 392
set osd_disarmed_pos = 2283
set osd_nheading_pos = 311
set osd_nvario_pos = 279
set osd_esc_tmp_pos = 82
set osd_esc_rpm_pos = 83
set osd_stat_max_curr = OFF
set osd_stat_used_mah = OFF
set osd_stat_bbox = OFF
set osd_stat_bb_no = OFF
profile 0
rateprofile 0
Yesterday, 10:56 AM
FPV addict
mlilasic's Avatar
I got to review Eachine QX65 which also uses Eachine Beecore V2.0 Brushed FC and here is the review with lots of DVR flights and dump of BF settings:
Review of Eachine QX65 - 5.8G 48CH 700TVL Camera F3 Built-in OSD 65mm Micro FPV Racing Drone Quadcopter with DVR flight footage
Mini-Review Beecore Upgrade V2 0 Brushed F3+OSD FC Board for Inductrix Tiny Whoop Bill M - RC Micro Multirotor Drones 88 Today 01:42 AM
New Product Realacc F3 V1.0 Betaflight Brushed Flight Controller with Integrated OSD and Buzzer montis Multirotor Drone Electronics 24 Feb 18, 2018 05:13 AM
Mini-Review Eachine EX110 Tiny Brushed FPV Quad F3 Flight Controller (Review) SoloProFan Micro Multirotor Drones 65 Sep 10, 2017 03:48 AM
New Product How small can you go? - Eachine Tiny 32bits F3 Brushed Flight Control Board sevet Micro Multirotor Drones 23 Feb 15, 2017 09:07 AM
Discussion Need Help upgrading Eachine-DSF3_EVO-Brushed-Flight-Control-Board-Built-in-DSM2 Fidy$Trainer Multirotor Drone Electronics 1 Feb 14, 2017 06:02 PM
