Feb 07, 2018, 09:51 PM
New Product
FuriousFPV F-35 Lightning Flight controller Full Options (Horizontal)
Furious FPV F-35 Lightning FC - Elevate Your Horizons.
Step into the all new F-35 Lightning FC - Furious FPV's 1st dedicated wing flight controller, ready and waiting to open all new worlds to winged FPV.
Encompassed by a robust case for maximum levels of protection and strength, the F-35 FC offers the ultimate levels of FPV capability that is dedicated & purpose built for the demands and capabilities of FPV winged flight.
Ultra easy to install with a massively powerful MCU STM F4 micro controller, the F-35 Lightning FC supports a full (6) UART's for GPS, VTX Control, S.PORT Telemetry,
Crossfire RX, RX, Bluetooth functionality. With these systems in play, the F-35 offers worlds of capability & performance for maximum levels of FPV flight.
Integrating a built in 5V@3A BEC, buzzer port, anti vibration silicone dampeners and battery monitor with current sensor, the F-35 Lightning FC packs a massive punch in an ultra compact form. Pair this with a built in Barometer & OSD system, the F-35 FC is the game changing flight controller that is ready for anything and everything a pilot could possibly desire.
Take your winged FPV flight to new worlds and beyond with the Furious FPV F-35 Lightning FC - the ultimate winged FPV flight control system.
Features and Specifications:
• Flight controller 9 DOF with MPU-9250 + 1 DOF Barometer BMP280
+ 1 DOF Airspeed (Analog & Digital)
• MCU STM F4 high performance
• Built-in OSD
• Support up to 6 UARTs (GPS, VTX Control, S.PORT Telemetry,
Crossfire RX, RX, Bluetooth)
• Support 2 motors and 4 servos
• Built-in Driver Inverter for SBUS and S.PORT connections
• Built-in Battery Voltage and Current monitor
• Camera and VTX port built-in Peripheral pass
• Built-in 5V@3A BEC for small Digital servos, can be easily changed to External BEC for bigger Servos
• Built-in Buzzer port
• High quality silicone wires with optimized lengths are included
• Support INAV firmware
• Vertical USB ports and pads, easy to install
http://globerc.com/product/furiousfp...ons-horizontal
Mar 23, 2018, 06:14 AM
FPVLK's Avatar
Anyone connected with DragonLink RX?
Mar 26, 2018, 11:48 AM
I just did yesterday. Getting into it now. PPM signal cable is the white cable from the camera cable and the FR rx cable you eliminate the white and yellow and just use the black grd and red power cables. Tie those 3 together to a three pin sevo cable (white, red, grd and they plug into the ppm channel 7 on the DL micro rx. Thats where Im at so far.
Apr 02, 2018, 10:08 AM
Shifteer's Avatar
Is there another thread on this?
Apr 14, 2018, 03:29 AM
I was thinking the same thing
Jun 14, 2018, 07:48 PM
deeh_46's Avatar
Anyone knows how to receive RSSI signal with this FC? I'm using R9M and R9 combo.
Jun 20, 2018, 09:42 PM
Is there possible to use one of motor channels for servo ( I need it for flaps)?
Jul 27, 2018, 06:12 AM
pumuklis's Avatar
Can somebody help me?
How do I show RSSI on R9 slim+ receiver?
Aug 09, 2018, 12:47 PM
pumuklis's Avatar
Is there anyone here who can answer?
Aug 21, 2018, 10:33 PM
pumuklis's Avatar
Did the Topic die?
No one to help?
WHERE IS THE MANUFACTURER FuriousFPV?
Sep 05, 2018, 06:26 AM
pumuklis's Avatar
Someone please reply.
The servos do not work.
Engine is running, motor, servo output enabled .Serving control sliders INAV2.0 Operate.
Servos do not work.
What should I do in the program?
Please help me somebody !!!
FuriousFPV F-35 Lightning problem (1 min 1 sec)
May 27, 2019, 08:08 PM
you can use airspeed input as analog RSSI or you can use dedicated RSSI channel
May 27, 2019, 08:17 PM
Servos do not work.
https://www.youtube.com/watch?v=VzIx...ature=youtu.be
Do not use inav, they are unstable.
Use ardupilot they are stable, easy to use, and they have better support team.
Just look at the ardupilot website, you'll find more detail and better configuration for this FC
Jun 19, 2019, 04:19 PM
Servos do not work.
Don't use inav, use ardupilot instead, inav is known to be buggy, what it seems from your pics and video that some of your PID is incorrect.
but it's hard to tell which one is false, since it needs more details on hardware analysis and debugging.
The most common reason for this is the mistake on selecting voltage on 5V or 3,3V.
Jul 03, 2019, 09:21 PM
If it Flies I Want It!!!! ...
Hi guys ..
New to FC's but not to FPV .. So bare with me with this concept .. my new FPV Aircraft has retractable Landing gear .. and i want to know the status of the gear without having to take the goggles off ..
So .. Ive made the wiring on the model with microswitches on the gear and the system works ..
0v =gear UP
1.5v = Gear in TRANSIT
3v = Gear is DOWN ..
I have the F35 ready to install into the aircraft..
Does the F35 have any sort of voltage input .. That i can then assign text to Voltage .. to display on the screen ..
Cheers in advance .
Brgds
Michael
Build Log F-35 Lightning II - Full Fuse Depron Pusher Parkjet Clickety Pusher Prop Jet Models 131 Oct 02, 2020 03:01 AM
Discussion F-35 Lightning. Scale 1:11 phantomphan Scratchbuilt EDFs 44 Jan 18, 2018 02:13 AM
