Feb 07, 2018, 12:00 PM
Spectrum AR500 Help!
I have an AR500 with a broken antenna the good one is your common snap on wire,the broken side is solder'd on to the board on only one spot, this wire appears to be a short plain wire with no shield.I thought all 2.4 antennas were coax cable?where i'm required to solder the shield and the center antenna to two different spots.I'm pretty good at soldering and need some advise.The other option i have several long Fry Sky antennas with plugs and thinking to just change out the existing one mount external and disregard the broken one HiTec run several Rx models on one antenna? Thanks in advance
Feb 07, 2018, 12:20 PM
AndyKunz's Avatar
Send it in. It'll probably only cost you $3 in postage.
Andy
Feb 07, 2018, 01:02 PM
Thanks Andy but right now i'm wintering in sunny Barbados,around here there's no next day air there's next month air and more in postage than a new one lol.I hoping for a reply with what this plain wire antenna is all about i can solder a wire.Thanks Peter
Feb 08, 2018, 08:48 AM
The broken antenna is the short one anyone know the length of this wire so i can replace it.Sending it back is not an option right now.Thanks
Feb 08, 2018, 09:03 AM
S.A.D. member
ivanc's Avatar
29mm = 1.14" to 31mm = 1.25"
Feb 08, 2018, 09:10 AM
Thank you sir,i'll be airborne shortly.Sinse you seem to be in the know ,am i correct in thinking this is only the antenna and sinse not longer than 31mm does not require a shield and only needed if extending it's length,i see the wisker on the other long one is 29mm,i had'nt really thought about that.Again thanks i owe you a beer Peter
Question orange rx and spectrum ar500 problem. I need help jajiyiko Radios 10 Dec 18, 2013 05:21 AM
Question Spectrum AR500 and flaperons… machild Hand Launch 9 Apr 13, 2010 05:02 PM
Discussion HELP Spectrum AR500 reciever - FLAPS Heritic Sailplane Talk 4 Jan 14, 2010 12:39 PM
Discussion Spectrum AR500 Power issue. MerlinV Radios 3 Dec 29, 2009 09:21 PM
Discussion mislabeled (wrong stickered) spectrum AR500 receivers ? gerard_nl Radios 4 Mar 05, 2009 06:16 PM
