Feb 06, 2018, 01:27 PM
CoopDrone Pilot
Transmitter Waveform Analysis
Has anyone looked on a RF Spectrum Analyzer at the PCM waveform from a spread spectrum transmitter?
Thanks'
Bill W
Feb 06, 2018, 01:49 PM
Sagitta Fanboy
1. There is no PCM waveform, as the modulation used is not PCM for any modern TX. QPSK and similar modulations are used. PCM is a method of modulating a sampled analog signal (the PPM pulsestream in the case of PCM transmitters). The signal is purely digital for modern systems.
2. You can see the spectrum analysis of the systems on the FCC certification documents.
Feb 07, 2018, 04:01 AM
Futaba PCM analysed here:
http://autopilot.sourceforge.net/pcm.html
Each brand has his own encoding, unlike PPM which is de facto standard for all, with small variations.
Help! Output Waveform Of Reciever And The Bldc Controller CLEMENT DIY Electronics 4 Feb 01, 2010 08:08 AM
LRK BEMF waveform question mcross Power Systems 11 Jul 01, 2005 09:43 AM
Adding an offset to an AC waveform Neil Stainton DIY Electronics 9 Dec 17, 2004 06:31 PM
Brushless Motor Waveform Neil Stainton Power Systems 10 Jun 26, 2003 04:13 AM
Output waveform to coil actuator lkykenneth Scratchbuilt Indoor and Micro Models 8 Jun 21, 2003 06:23 PM
