Feb 06, 2018, 12:42 AM
LUFTGUCKER
lotsasteam's Avatar
Brand new F86
Got my Freewing F 86 assembled try to hook up my AR 7350 AS3X RX so i could maiden it ,no matter what i tried could not get that rx into programing mode frustrating isn't it?? Good thing i had some lemon rx around !!! 5 min later my F 86 was ready to go maiden it successfully! Back to the spektrum RX brought the 9 channel RX back to the dealer and got credit for it ,will do the same with the AR 7350 its such a pity the DX9 TX is such a nice and easy unit but the receivers are a pain to set up ,no more spektrums fiddle rx for me !!
Might be a good product but definitely not a "plug and play" item!
Feb 07, 2018, 02:41 PM
LUFTGUCKER
lotsasteam's Avatar
3 days later and one half hour call to horizon service center rx still on the bench bound to the dx9 works like a regular rx (compared with the lemon rx i am good with about $24 equity) but what do I get for the other $ 115 i spend ???I know,FRUSTRATION !Can't register rx because neither phone or computer is able to work with the spectrum app!
Feb 07, 2018, 02:52 PM
AndyKunz's Avatar
SPMA3065 - I've never had it fail me. What's it doing wrong on your computer?
Andy
Feb 07, 2018, 11:20 PM
LUFTGUCKER
lotsasteam's Avatar
XP not compatible !! I phone not compatible !!
That's what it says ,i was able to get the serial number on screen,loaded the my spektrum registration page (registered DX6e and DX9 before) filled out everything included i am not a robot ! Here comes the but: not a valid registration number !! Checked entries multiple times doesn't let me ??
Feb 08, 2018, 08:42 AM
AndyKunz's Avatar
The serial number is internal in the receiver. You need to be able to use the cable to access it for registration.
If you have too old a PC then yes, you need to use something that is newer. I use Windows 7. As much as I like XP, 7 is still not bad. 8, Vista, and 10 are awful, but 7 is pretty good.
Andy
Feb 08, 2018, 10:50 AM
LUFTGUCKER
lotsasteam's Avatar
That's the case i used the cable and then the serial came up ;i only came this fahr ,entering the registration # there was a problem no matter which way i tried i always get the :invalid registration number!
Will try again on a friends Window 7 computer,Thanks Andy!
Feb 08, 2018, 10:52 AM
AndyKunz's Avatar
Copy/Paste it in. That will work. If not, copy/paste it in a PM to me and I'll investigate it from our side to make sure it's valid, or to get you the corrected serial.
Andy
Discussion New F86 due in May E-flite Spaceshuttle1 Foamy EDFs 8 Apr 12, 2010 02:00 PM
Discussion looking for alfa f86 wing, or have f86 fuselage available tommythecat Foamy EDFs 0 Apr 27, 2009 08:40 PM
Discussion New F86 eliminator Electric Ducted Fan Jet Talk 1 Apr 20, 2007 03:35 PM
Discussion New to Fans , Santa gave me an F86 ! Duke58 Foamy EDFs 5 Jan 08, 2007 03:27 PM
new Alfa F86 rcguy01 Electric Ducted Fan Jet Talk 1162 Oct 17, 2005 09:14 PM
