True-MoX 915 - TrueRC Canada
The True-MoX is designed for LRS transmitters such as the FrSky and TBS. It is based on the original Moxon style LRS antenna.
Designed For The TBS Crossfire and FrSky R9M
TrueRC is pushing boundaries once again with their new 900MHz moxon antenna, designed for the FrSky R9M or TBS Crossfire bi-directional long range transmitter. The True-MoX 915 is not a patch, therefore is not supposed to be pointed at the aircraft with it's flat side, but rather the top edge towards the target.
Here's what TrueRC says about the new True-MoX: The True-MoX 915 is our revision of the moxon using latest 3D electromagnetic simulation tools and RF rated PCB material. Interactions with radio or pilotís body are kept at near zero thanks to our patent pending design. Great for TBS crossfire. or FRsky R9M. Note that this is not a patch, do not point the flat part toward the target. Point the long edge of the white panel toward the intended flight area. Having the long edge vertical produce vertical polarization.
CLICK HERE for more information on the new TrueRC True-MoX.
Specifications:
  • Frequencies: 902-925MHz
  • Gain:5.4dBi
  • Beam width*: 156deg
  • Beam width @-3dB**: 133deg
  • Connector: SMA
  • Dimensions: 103mm x 165mm
Feb 05, 2018, 10:42 AM
UAV Integrations
Very cool! I immediately wondered how well this would work with a 900mhz serial modem? And even as a Vrx antenna for my 900mhz video system?
Feb 05, 2018, 10:56 AM
Matt Gunn's Avatar
Hopefully Hugo will chime in.
Feb 05, 2018, 11:38 AM
Hugeone's Avatar
Work great from 905 to 925, so video, data will be fine as long as within band.
A EU 868MHz version will come.
-Hugo
Feb 05, 2018, 01:50 PM
KC9TPL- Get Legit
BloomingtonFPV's Avatar
Is there a version for TSLRS? BNC?
Feb 05, 2018, 02:05 PM
UAV Integrations
Eh? I always assumed TSLRS was 433mhz like most other LRS systems out there...?
Feb 05, 2018, 04:27 PM
400' + is where fun starts.
Martin Y's Avatar
It is.
Feb 05, 2018, 04:35 PM
KC9TPL- Get Legit
It just has a different BNC connector. These are SMA. It may be as simple as crimping a different connector on, but I don't have the tools for that.
Feb 05, 2018, 05:54 PM
UAV Integrations
Ok, in that case you don't want to use this antenna. This antenna is 900mhz.
I'm sure Hugo can create a 433mhz version of this antenna, though, later on (depending on how many requests he gets, I'm sure...)
Feb 06, 2018, 11:09 AM
Hugeone's Avatar
433 is possible, but pretty far down the list of new products
-Hugo
Feb 07, 2018, 11:19 PM
FPV Lawnmower
Fluxone's Avatar
so is this similar to the TBS diamond or no?
similar radiation patterns - directional in front of you?
better with vertical or horizontal with long edge - or same?
Feb 08, 2018, 10:40 PM
Hugeone's Avatar
The Diamond is folded dipole, omni-directional 2ish dBi
The True-MoX is a moxon directional 5.4dBi in front. Assuming the antenna(s) on the aircraft are vertical, then the moxon need its long edge vertical too.
-Hugo
Jul 23, 2018, 11:34 AM
hi all, I do a comparison between 3 transmitter antennas(TBS Diamond, true-mox 915 and R9M stock antenna), I try to fly the same path using a frsky slim with horizontal antenna, so we have a indisputable winner, just see the video!!!!
TBS Diamond vs TrueMox915 vs Frsky R9m stock Antenna comparsion (1 min 51 sec)
Aug 02, 2018, 08:32 PM
So is the the TBS diamond better for freestyle quad flying?
Aug 03, 2018, 12:22 PM
FPV really is fun.
Scotth72's Avatar
Diamond is a omni. Moxon is directional.
News AXII Antennas From TrueRC Canada Matt Gunn FPV Talk 3 Mar 11, 2018 05:12 PM
Discussion 433, 869, 915-which are ok in canada? phil alvirez Radios 3 Oct 21, 2016 02:04 AM
Cool TrueRC Canada new website! Hugeone Product Announcements 0 Dec 07, 2007 07:09 AM
Yippee! TrueRC lipos are now in Canada! Hugeone Canada 5 Feb 22, 2006 09:15 PM
