Apr 27, 2018, 04:39 PM
Originally Posted by brat002
This plane is so heavy... mine weights 1220g without a battery. That's some kind of craziness...
That weird cause mine weighs less than 1.2kg with the battery
Apr 28, 2018, 12:43 AM
I have installed
Sunnysky x2814 900kv
Kiss esc 30a
Pitlab osd
Predator mini camera
Qlrs 100mw rx
Emax es08 ma II
Partom 800mw 1.2g without a heavy case.
Becs
nothing special else.
Apr 28, 2018, 07:35 AM
I have installed
Kiss esc 30a
Pitlab osd
Qlrs 100mw rx
Emax es08 ma II
Becs
The frame on its own weighs 400g. Are you sure you weighed it right. My plane has more stuff in it but just from the feel I know for a fact it's not over 1.2kg. Feels to light in my left hand when I hold it (and I'm right handed)
Apr 28, 2018, 08:03 PM
NMdesertracer's Avatar
Mine comes in at 1700g just got her done today. Using the trusty EG Vector this is gonna be my rapid response mountain plane. Using a titan 3s 5200 li-ion pack when It comes. Got a bad one but there sending me a new one super nice people. might have to use my 3s 7000mah li-ion 3dxr packs. The bird pulls 34 amps. gonna start with the cg at 300mm. now I had to add nose weight since the li-ions are light weight. Might put a micro servo on the other hatch and have the camera where it can pan. I rather have the weight used for something!
Apr 29, 2018, 11:56 AM
Did some work to the lid for a pan servo also strengthens the top plate.
Apr 29, 2018, 03:43 PM
HexaFlexa's Avatar
Nice build.. That should Haul A$$..
May 01, 2018, 07:26 AM
Heres some 3 min CAD i came up with for better motor mount. I didnt take out the center hole for the motor shaft. This is a rough sketch.
May 01, 2018, 10:10 AM
My s1100 went maiden flight. The plane quite stable, but doesn't like slow speeds <55kmh. I use 31cm CoG.
May 01, 2018, 10:29 AM
That great man. ive got my cg in the same place. Friday is the day of my maiden. should be able to get some dvr footage if it
May 01, 2018, 10:58 AM
Here is video
Reptile s1100 launch in manual mode (9 min 53 sec)
May 01, 2018, 01:52 PM
it would be cool if someone could design a sort of round nose insert for setups that arent using the camera nose
May 01, 2018, 03:22 PM
HexaFlexa's Avatar
If its flying badly below 55kmh its because you got CG too far back.. . Thats 25mm behind stock.. And my guess is you still have up trim ?
May 01, 2018, 03:50 PM
A bit.
May 05, 2018, 12:53 AM
Success at last
I didn't think it was possible but the S1100 is hands down better than the Sonicmodell HD wing in almost every way.
Flies more stable at high and low speed
A full Amp more efficient
Waaaaaaay WAY stronger foam
She's everything I wanted. Brilliant. And with the eagle tree vector she is solid. Honestly today was just awesome.
But I did have an oh crap moment. At 13.6km out (New personal record btw &#128513 I hit failsafe and i couldn't come out it. For 3km the plane flying back over a district. Real scary with a new plane. Fortunately the vector saved the day. Throughout the 3km it flew flawlessly. Honestly the best AP ive ever owned. At 10km I was able to gain control again. I blame the antenna I had on the tx (tuned bignose13 coil loaded dipole instead of my standard moxon). Because of that I wasn't able to fly the windfarms. But I will test her out again with a 9x7 (i broke it today in a stalled launch) and my moxon antenna and try to reach 20-25km.
Cg :305mm
launch fail
S1100 Launch Fail (3 min 13 sec)
maiden
Reptile S1100 Harrier Maiden At The Beach (6 min 7 sec)
antenna range test
S1100 Pagoda and Crosshair Range Test (23 min 42 sec)
Sorry for the lack of audio.
May 05, 2018, 07:37 AM
fools? at least i'm honest :)
korakora's Avatar
i don't know why others review seems strugling with nose heavy
so i launch her with both hand because too scared with nose heavy (CG at 28) i can't make CG more backward because my battery too heavy
and then ? where is the nose heavy
i'm not have a chance to try manual (she born perfect) w/o need TRIM at all
she pass to be my next LR BORING plane fleet
Reptile Harrier 1100mm (20 min 52 sec)
Discussion Reptile S800 SKY SHADOW 820mm Wingspan FPV EPP Flying Wing Racer KIT or EPP kbird Flying Wings 1580 Oct 03, 2019 12:14 PM
New Product [New Arrival]Reptile S800 V2 SKY SHADOW 820mm Wingspan FPV Flying Wing RC Airplane BG Tobey FPV Aircraft 680 Sep 27, 2019 11:37 PM
New Product ZOHD Orbit 900mm EPP AIO HD FPV Flying Wing RC Airplane PNP With Gyro guyst FPV Talk 5 Oct 22, 2018 06:28 PM
New Product Reptile S800 V2 SKY SHADOW 820mm Wingspan Gray FPV EPP Flying Wing Racer PNP With FPV D Gains FPV Aircraft 1 Aug 10, 2017 10:31 AM
