RMRC Cricket Pro V2
The RMRC Cricket PRO V2 has taken one of their most popular transmitters and totally redesigned it to appeal to today's pilot.
Cricket Pro V2 - 5.8GHz VTX with Smart Audio - MMCX
From RMRC
Where other transmitters expect you to count blinks, beeps, or to hold your tongue just right, the Cricket PRO V2 is one of the easiest around to operate with a two button system and clearly visible LEDs! The heavy aluminum case has been removed and the SMA connector has been swapped for the increasingly popular and lightweight MMCX connection. The PRO V2 has retained the same, variable transmitter output along with the 100% US legal channels. It also comes equipped with officially licensed Smart Audio operation which allows the user to control the transmitter remotely. We know you will love the redesigned RMRC Cricket Pro V2!
Features
  • Retail Price: $33.99
  • Extremely easy to operate with visible LEDs and 2 button operation.
  • Lightweight and secure MMCX Antenna connection
  • Dipole antenna and SMA adapter included
  • 25, 200, 600mw transmitting power on 100% US legal channels
  • Officially licensed Smart Audio control
  • Built-in microphone
  • 30.5mm mounting holes
Specifications
  • Frequency: 5.8GHz 40 Channel (37 unique)
  • RF Power: 25mW/200mW/600mW selectable
  • Power Input: 7-28V DC
  • Supply Current: 100-260mA
  • Camera Power: 5V (500mA max)
  • Connector: MMCX
  • Port Connector: JST-GH, 6-pin
  • Dimensions: 35 x 21 x 6mm (approx)
  • Weight: 6g without cables or connector
  • Made in China
Includes
  • RMRC Cricket Pro V2
  • 5cm MMCX to SMA Female adapter
  • 5cm MMCX Dipole Antenna
  • Wire Harness
  • Box and Manual
Operation (Assuming LEDs are at the top, and buttons on the bottom)
  • Left Channel/Frequency Button
  • Single press to change channel, long press to change frequency band
  • Right RF Button
  • Long press to activate and begins blinking. Short press to confirm RF transmission, LED will be solid when transmitting.
  • Single press to change RF power (L - 25mW, 2 - 200mW, 6 - 600mW)
  • The PRO V2 is always in pit mode and must be turned on each time unless using Smart Audio. Default power is L 25mW.
  • Stay Legal with all 40 channels
Photos
Learn More
Head over to RMRC to learn more about this unit.
Feb 04, 2018, 05:51 PM
Received my Cricket V2 and was excited to get it into my build. Everything was going very smoothly and I really enjoyed the MMCX connection so I could easily unplug the antenna to work it into my build. Once everything was set I discovered this VTX doesn't transmit unless you physically push a button. Unfortunately I was locating the VTX under the wing which won't easily be accessible every battery change and I'm not using a FC so smartaudio isn't a good solve either. Is there ANY way to bypass the need to press the button every battery change to transmit? Thanks!
Feb 04, 2018, 06:29 PM
P.I.Engineer's Avatar
that was the one thing that stuck out to me on this vtx. Having to push the button.
Feb 04, 2018, 07:37 PM
Would have been brilliant to have a DIP switch or solder pad that allowed you to select the default powering-on choice. Either like it is powering up in Pit or power up in last chosen transmit power. Perhaps something for V3. For now I'm going to yack this from my build and replace with a MMCX Mach 2. The Cricket will need to wait for another build which button access or smartaudio is an option. Otherwise it seems great.
Feb 09, 2018, 10:41 AM
Even changing the settings in BetaFlight OSD I can't get the auto pit mode to turn off. Thankfully on this first quad I've installed it I can get to the button, but I'd still like to disable it. Can't believe this isn't an option that can be set on the vtx itself.
Feb 09, 2018, 12:07 PM
Have you tried this?
TBS Unify Pro HV - Smart Audio Betaflight menu settings to disable Auto-Pit mode (1 min 46 sec)
Feb 12, 2018, 10:55 AM
Yeap, also did a quick dvr of the settings. I also just opened a support ticket with RMRC.
RMRC Cricket Pro V2 vtx config (0 min 24 sec)
Feb 14, 2018, 04:06 PM
Still working through the issue with support. It's looking like setting the OP mode isn't working in these units right now with Betaflight OSD. He said he was able to power on the vtx with a lua script as a workaround.
Feb 14, 2018, 05:05 PM
cool, thanks for the update
Mar 09, 2018, 10:22 PM
Does anyone know where I can buy the RMRC Cricket Pro V2 in Australia?
Mar 19, 2018, 12:02 PM
Any idea where to get that lua script?
Apr 28, 2018, 08:57 AM
Padraig
I would also like to know where to get that LUA script. I'm very disappointed in this. Mine is inconsistent it seems. When I first installed it, it would come on weak like the video above. But then it was just powering on when I plugged in the battery for a while, but that stopped, and now I have to push the button TWICE to get on full. The first push brings up the super weak signal that doesn't go more than 5 feet. Push it a 2nd time and it's full power. BUT! When I change power level to 600 through OSD, it doesn't change or save. In fact, I think there are a lot of features that don't seem to save through OSD. Anyone else have this?
May 06, 2018, 09:43 PM
pooljunki's Avatar
I have to turn mine on every time
May 07, 2018, 11:09 AM
"Aircraftus Fragmentum"
kydawg1's Avatar
I pulled mine from a quad....could hardly get to the buttons to go thru that crap every time. If only they fixed it so you had an options to turn off Pit mode and keep it set the same as the previous power cycle.
Jun 18, 2018, 07:50 AM
RMRC product description now says it will now default to your saved power and channel settings rather than defaulting to pit mode.
Alert Has your FX799T VTX Burned? (RMRC Cricket, Lumenier TX5GR, FX799T) jarenmorrisphoto FPV Racing 41 Oct 26, 2017 08:18 PM
News RMRC Cricket Cam - Camera, VTx, Antenna Combo Matt Gunn FPV Talk 30 Dec 11, 2016 04:34 PM
Discussion Eachine RC832 vrx with a RMRC cricket vtx (will it work)? Jagst FPV Equipment 2 May 08, 2016 03:54 PM
News RMRC Cricket V2 VTx and Mantis VRx Matt Gunn FPV Talk 4 Apr 14, 2016 04:29 PM
Discussion RMRC Cricket VTX question JaimeroJalapeno FPV Equipment 2 Feb 23, 2016 04:12 AM
