This thread is privately moderated by scousethief, who may elect to delete unwanted replies.
Jan 30, 2018, 07:42 AM
Quad Erat Demonstrandum
scousethief's Avatar
Eachine Lizard105S FPV Racing Drone BNF ..........Harder, Better, Faster, Stronger ?
https://www.banggood.com/Eachine-Lizard105S-FPV-Racing-Drone-BNF-Omnibus-F4SD-28A-Blheli_S-ESC-720P-DVR-5_8g-25200mW-VTX-4S-p-1258632.html
Eachine Lizard MK II Tony Stark style ( lots of metal ) review model on the way.
Specifications: User Manual download
Brand Name: Eachine
Item Name: Lizard 105S Micro FPV RACING DRONES BNF
Weight: 80g( battery not include)
Flight controller: F4 Flight controller built-in OSD with Damping box IMU
Motor: Eachine 1104 KV6000 brushless motor
ESC:BS-28A 4IN1 ESC DSHOT600 Ready
Propeller: 60mm 4-blades propeller
Camera: 130Degree 720P Camera
DVR: 1280*720 Real HD Video recorder
VTX: 5.8g 25MW/200MW Switchable 48CH Video transmitter
Battery: 14.8V 550mah 60C lipo battery
OSD: Betaflight OSD
Firmware of Flight controller :Betaflight 3.2
Rear LED Ready( LED_Strip function)
Buzzer Ready
Receiver Option:
-Compatible Frsky XM+ Receiver with Telemetry
-Compatible Flysky 10ch AFHDS2A receiver Ibus output with Telemetry
-Compatible Specktrum DSM2/DSMX Compatible receiver
Flight controller Specification:
-Size:27mm*27mm*8mm
-Mount hole: 20mm*20mm
-Processor: STM32F405RGT6
-Sensor: SPI Sensor MPU6000 with Damping box mounted
-Built-in Betaflight OSD ( Batt voltage, RSSI , Artificial HZ , Fly mode , -Flytime, Craft name etz.)
-Firmware version: Betaflight 3.2
-Target: Omnibus F4SD
-Work voltage: 2S-4S lipo battery
ESC specification:
-Size:27mm*27mm*5mm
-Firmware version: BLHELI_S 16.5
- BB2, 48MHZ Chip
-Lipo Battery: 2S-4S
-Con. Current: 28A
-Peak Current: 35A (5S)
-Programming: YES
-Betaflight pass-through ready
-Dshot600 ready(Default)
DVR Specification:
- Dimension: 27*27*3.5mm
- Mount hole: 20mm*20mm
- Records effective pixel :1280(H) x720(V) 60FPS
- Output format: NTSC/PAL
- ISO Sensitivity: Auto ISO
- Video format: MOV(H.264)
- Operating voltage: 5V
- Standby current: 250-260mA @5v
- Work current: 280-300mA @5v
- Max Micro SD: 32GB ,FAT32
Camera Specification:
Video Format: NTSC/PAL
Image Resolution: 1280x720
Sensor: 1/4 inch CMOS
LENS ANGEL: H:130/V:100
Supply Voltage:3.2v~5.5v
Features:
- Extremely light and powerful, 4S power makes the Lizard 105s like a beast
- STM32F405RGT6+ BLHELI_S ESC make your Operating feel more stability and silky
- Adjustable Angle of Camera
- Adjustable VTX Power 25mw/200mw
- 720P extremely video experience
- 5.8g video real-time transmitter
- Jaw-dropping flight performance
- Betaflight support
- Acro mode / Air mode /Angle mode support
- Built-in OSD(Using F4 MCU controls OSD over SPI bus in DMA mode)
- OSD Configuration has been include in BETAFLIGHT GUI
- Radio Stick to control PID Tunes
- BLEHELI_S pass-through ready
- Telemetry RSSI Output ready (XM+ and Flysky version)
Package include:
1 x Eachine Lizard 105S Frame kit
1 x Omnibus F4 Corner Nano flight controller build-in OSD
1 x Compatible Frsky XM+/DSMX/Flysky AFHDS2A Receiver(optional)
4 x Eachine 1104 6000KV brushless motor
1 x BS-28A 4IN1 ESC Dshot600 Ready
4 x 60mm 4-blades propeller CW
4 x 60mm 4-blades propeller CCW
1 x 720P HD CMOS 1/4 inch camera
1 x 720P DVR
1 x 5.8g 25MW/200MW Adjustable 48CH VTX
1 x UXII Antenna
1 x 14.8V 550mah 60C lipo battery
1 x WS2812 LED Board+Buzzer
4 x Propeller guarder
Video New Frame! Lighter, Better, Faster, Stronger. LegendFPV FPV Talk 1 Sep 24, 2017 06:38 PM
Video T-REX 450SE...Harder, Better, Faster, Stronger Al Austria Electric Heli Talk 12 Jan 05, 2008 01:48 AM
Discussion T-REX 450SE...Harder, Better, Faster, Stronger(Ready Heli entry) Al Austria Mini Helis 0 Nov 19, 2007 01:46 PM
faster stronger louder harder GehhtoFlyer Micro Helis 4 Mar 28, 2005 06:17 PM
