F4U Corsair 1300mm (with retracts) - RC Groups
Jan 30, 2018, 06:40 AM
No RTF flies like your own SB
mperaltaoz's Avatar
Build Log
Hi All,
Sharing my new project: F4U Corsair with the following specs:
Wingspan 1300mm
Estimated weight 1.5 kg
Motor D3548 790Kv 715W
Propeller 3 blades 11x7
ESC 60A
UBEC
Twist-n-turn retracts
I've built this plane 2 years ago (https://www.rcgroups.com/forums/show...-F4U-1-Corsair) in a smaller version and without retracts.
It was a great plane and I enjoyed flying it until I sold it recently to make room for this project.
This one is going to be bigger and with retracts. It will also be built with a different construction technique.
Plans attached below.
Jan 30, 2018, 06:48 AM
mperaltaoz's Avatar
I'll be fastracking things with this one as I'm going pretty fast.
See photos below for wing build.
For more details on how to cut fuselage and wing sections, you can see my previous 2 projects:
- Bulldog Racer (https://www.rcgroups.com/forums/show...g-Racer-1200mm)
- T28 Trojan (https://www.rcgroups.com/forums/show...-Trojan-1200mm)
Jan 30, 2018, 06:57 AM
mperaltaoz's Avatar
Retracts
And here is how I did the retract mounts and wheel wells.
I used a foam cutter I got from Banggood which works a treat for cutting holes in wings (spar groove, retract mounts, wheel wells, etc) and fuselages (ventilation holes).
Then I removed the middle piece with a dremmel.
The retract mounts are my own design and 3D printed at home (STL file attached)
Jan 30, 2018, 07:00 AM
mperaltaoz's Avatar
All sections cut, sanded and glued (including cowl)
Feb 07, 2018, 03:51 AM
mperaltaoz's Avatar
Added internal pushrod snakes and servo trays.
Glued both halves together.
Feb 13, 2018, 06:04 AM
mperaltaoz's Avatar
Flaps
Flaps and ailerons cut and hinged.
A piece of credit card does the trick for the scale flaps.
Today, 12:51 AM
mperaltaoz's Avatar
Airframe ready
Hi there,
I've finished all the parts, sanded and covered them with a coat of WBPU.
Next step will be scale panel lines and paint job.
Today, 05:04 AM
mperaltaoz's Avatar
Panel lines
All panel lines and ribets done and ready for the paint job!
Today, 06:32 AM
crankster's Avatar
Mario, you’re unbelievable. This is looking awesome !!!
Discussion GUILLOWS CORSAIR F4U 1D With Rotating Retracts MPP Scale Kit/Scratch Built 167 Jan 18, 2017 02:53 AM
Discussion Flyzone select scale F4U Corsair - Need help with retract replacement Vbluguitar Electric Warbirds 1 Mar 23, 2016 12:25 PM
Question CG on PZ F4U Corsair with Rotating Retracts hongrn Electric Warbirds 12 Jan 28, 2011 04:35 AM
Help! Hangar 9 F4U Corsair 60 with Retracts cgjohnst Fuel Warbirds 10 Jan 14, 2010 04:38 PM
