Associated Northrup Fabricators Trophy Rat BL RTR
What do you get when you cross a 1937 International pickup with a 2wd desert racing chassis? The Trophy Rat!
Based on the Real Trophy Rat!
Team Associated’s Ready-To-Run 1:10 replica of Northrup Fabrication’s Trophy Rat is wrapped around the chassis and engineering of the 9-time R.O.A.R. Short Course National Championship-winning truck. The Trophy Rat is both all show and all go! The truck features a water-resistant high-power Reedy brushless speed control and 3300kV brushless motor, a 2.4GHz 2-channel radio system as well as the ALL NEW DVC (Dynamic Vehicle Control) receiver unit with built-in adjustable digital gyro which allows vehicle stability to be adjusted to flow with the terrain. A Reedy metal-gear digital high-torque servo and LED lights front and rear round out the Trophy Rat!
CLICK HERE for more info on the Associated Northrup Fabricators Trophy Rat BL RTR.
Features:
  • Based on the 9-time R.O.A.R. National Champion short-course race truck platform, with rear motor design
  • 2.4GHz 2-channel radio with new DVC (Dynamic Vehicle Control) receiver; featuring built-in adjustable gyro
  • High-torque, metal-gear Reedy Servo with spring style servo saver
  • Powerful Reedy 3300kV Brushless motor
  • Water-resistant high-power Reedy brushless speed control with T-plug connector and LiPo low voltage cutoff
  • Realistic Trophy Rat Body based on the Northrup Fabrication's “Trophy Rat”
  • Realistic Method Wheels with 12mm front and rear hex-drive nuts
  • Four integrated LED’s included, 2 front, 2 rear
  • Water-resistant enclosed receiver box
  • Durable and lightweight aluminum top shaft
  • Low center-of-gravity molded composite chassis with hook-and-loop battery straps that accommodate both NiMH and 2/3s LiPo stick pack batteries
  • Metric hardware throughout
  • 14 precision rubber-sealed ball bearings
  • Durable front and rear body mounts
  • Rear CVA drive shafts for more reliability
  • Aluminum 12mm big bore coil-over shock absorbers
  • 2.6:1 ratio gearbox with heavy-duty sealed gear differential and externally adjustable V2 slipper clutch
  • Rugged steel turnbuckles for adjustable camber and front toe-in
  • Fully adjustable suspension geometry
  • Vertical ball ends for roll center adjustments, front and rear
  • Many Factory Team options already available!
Jan 29, 2018, 10:35 AM
That looks like it could make a great crawler or monster truck body.
Jan 29, 2018, 11:04 AM
Panhead5496's Avatar
Is the DVC similar to TSM/AVC or a different thing entirely?
Latest blog entry: My RC Garage: Boats
Jan 30, 2018, 01:29 PM
Rek. käyt.
I guess all those "cheating" devices are gyro based.
Jan 30, 2018, 01:37 PM
Matt Gunn's Avatar
As someone who has used both, I can definitely say there's no cheating. You're not racing anyone. Additionally, a gyro smooths out turns and makes long drifts possible. It's more fun than anything else, and I drive many different types of cars with and without gyroscopic stability assist.
Jan 30, 2018, 01:51 PM
The gryo is a nice feature if you're going to continue to use the rock hard tires that most RTRs come with. When I replaced the Traxxas Talon tires on my Stampede with something that actually had some grip, I put them onto my son's Circuit to gain ground clearance in the grass. Any time we were on dirt, he couldn't control the truck at all because those Talons are garbage. I put a cheap gyro on the truck and it was a night and day difference. Once I upgraded the tires on his Circuit, the Gryo became obsolete for how we use the vehicles.
Apr 24, 2018, 10:29 AM
jgg12002's Avatar
There was a guy keeping up with the buggy’s at my local track with one I know he did some mods I’ll find out what and report back. looked like he was having a blast with it not sure if I’ll upgrade my slash 4x4 to an ultimate or get this one for carpet. Nice looking ride.
J.
News Pro Boat Zelos 36 Twin Catamaran BL RTR Matt Gunn Racing Boats - Electric 33 Dec 16, 2017 12:12 AM
News Team Associated 1/18 APEX Touring Car 4WD RTR Matt Gunn On-road Cars 3 Aug 28, 2016 01:56 PM
News Team Associated 1/18 Reflex 4WD Offroad RTR Matt Gunn Off-road Cars 11 Aug 26, 2016 11:43 AM
Discussion Fabric Finish on a Fabric airplane? Majortomski Scale Fuel Planes 14 Nov 04, 2015 03:59 PM
Question Ansmann Mad Rat RTR Brushless Raceboyz Electric Power Cars 2 Aug 22, 2010 06:31 AM
