Jul 10, 2020, 08:35 AM
Faris - Telecom Engineer
Hi , its a very nice and useful device ,i really like it.
Are you interested to produce a modified version of this device so it can work for a project that may require a production of large number of peaces (thousands )?
Regards
Jul 10, 2020, 08:55 AM
sorry for the Duplication
Jul 11, 2020, 05:19 AM
Aaro's Avatar
Hi,
Thank you. It is probably easier to design a spesific version for such high volume applications although I'm not interested.
Aaro
Regards
Oct 11, 2020, 11:55 AM
https://hmvc.eu/
@f5mmx
I programmed a Nano that I had and ordered the MMA8451, the OLED display and some thin wire from AliExpress.
Now I need to wait a month for those parts to arrive to finish it.
I would really appreciate it if someone could confirm I at least bought the proper parts?
I'm a bit in doubt with the display.
It would be quite a bummer if I can't finish it after waiting all that time and need to wait another month.
https://www.aliexpress.com/item/32946734550.html
https://www.aliexpress.com/item/4001030610504.html
I have compiled and uploaded this project to my Nano.
Oct 11, 2020, 01:50 PM
joesoar's Avatar
They look correct. I bought all my parts off EBay and shipping was 1-2 weeks for all parts...
Joe
Oct 11, 2020, 02:58 PM
https://hmvc.eu/
Joe
Thanks....
Oct 24, 2020, 08:28 AM
https://hmvc.eu/
I'm still waiting for the accellometers, but finished the rest of the schematics.
I expected the LCD to come on, but I see no life in it....
Is this to be expected?
I noticed some differences as well between the "normal" schematics here and the "breadboard" schematics here
The resistor on the breadboard is a 220 Ohm resistor (red-red-brown). I'm quite sure that's wrong and it needs to be 10 kOhm. As I saw that breadboard schematic first I already connected it with that 220 Ohm resistor. I hope my D2 isn't damaged.
The other difference is that the Oled's VCC is connected to 3.3V on the "normal" schematics and connected to the 5V on the "breadboard" schematics.
On both accounts I will be following the "normal schematics".
But I still haven't received my accellometers, so I still have to wait until I can see it working.
I will post a picture after it's finished. I think I have a nice way of attaching it to the deflectors.
On this picture the 3V3 isn't used at all (the 2nd hole on the right hand bottom side is still open).
I will also make sure that the 2 wires for SCL and SDA are not close to each other. I think I will twist SCL with VCC and SDA with GND. More than 100 pF between the SCL & SDA seems to be killing the communication of the I2C.
Probably it doesn't matter all that much, but it's not very consistent.
Oct 30, 2020, 06:09 PM
https://hmvc.eu/
Originally Posted by GarryOgilvie
I again ask for assistance.
I was finally able to have the program display with the oled.
My oled required a different descriptor in the sketch.
My issue is that the display is: INIT EN COURS
What does mean?
What do you mean with "my oled required a different descriptor"?
I built 2 of these and none display anything. Maybe I don't have the same oled as is needed.
Oct 30, 2020, 06:24 PM
Professional sink locator
Since I speak and understand English i translated "INIT EN COURS" to "Starting Up", which is the rough translation of the French INIT EN COURS.
You can do this in the sketch. Simply go through it and find what terms or language that you do not recognize and use google translator to find a term or phrase that you understand.
I'm simply a monolinguistic American, but I totally respect what our other soaring brethren from other countries share with us.
Latest blog entry: Repairing a boom break
Oct 30, 2020, 06:27 PM
You may want to again check your wiring, and also check which chip is on your MMA84XX boards. The wiring may be different than what you are expecting. The 8451 and the 8452 are different.
Oct 31, 2020, 01:17 AM
https://hmvc.eu/
Hi Garry,
Thanks for replying. The language is not my problem, my display doesn't react whatsoever. You were right about the chip. I did make it as a 8451 at first. that was the chip I ordered, but then I noticed that I indeed have a 8452, so I changed the wiring and connected SA0 to ground instead of 3.3V and wrote the other code on it.
Maybe I damaged it?
I checked the wiring many times, but I'm afraid I have some mismatch with the display.
today I'm going to test with some code that only handles the display. I would expect at least a reaction there.
I don't have an awful lot of expedience with nano's, but I did build a few OpenXsensors and they worked.
I have also tested 1 of the 2 nano's without the accelerometer to see if the display came on, but it didn't. I don't know if that's too be expected.
When I upload the sketch I need to select "old bootloader" for it to flash. I'm only saying this because it isn't working.
I'm now hoping I will find that my display needs another ID or something for it to work.
I have started with a new nano, oled display and accelerometer.
I only connected the display and ran this...
https://www.instructables.com/OLED-I...UINO-Tutorial/
The display works.
I then loaded the inclinometer software and the display showed an error regarding the sensor.
Not that strange if it is not connected.
I will now solder the accelerometer to it and it will probably work.
Eventually I will find out what was wrong... now following a step by step approach.
edit: it works... now the switch.....
Discussion It's a bird, It's a plane, it's::: BHOFM Electric Plane Talk 9 Feb 15, 2016 05:42 PM
Discussion Break out the canoe's, life raft's and kayak's kbstingwing Slope 30 Jan 08, 2016 09:00 PM
Discussion British FF Kits in the 1930's /40's/50's ? mrfirkin Free Flight 40 Nov 05, 2015 07:30 AM
Idea H9 Angle Pro Digital Inclinometer Modification Gerry B Flight Accessories 9 Mar 04, 2014 11:30 AM
Discussion Memsic MXD2125 Inclinometer with Parallax BS2 Geometrix UAV - Unmanned Aerial Vehicles 0 May 24, 2007 05:40 PM
