Jumper T8sg Plus V2.0 multi protocol transmitter - RC Groups
This thread is privately moderated by old4570, who may elect to delete unwanted replies.
Jan 27, 2018, 09:42 PM
New Product
Product link
Brand: Jumper
Item No.: T8SG Plus V2.0
Size: 158 x 150 x 58mm
Weight: 338g (without battery)
Transmission frequency: 2.400GHZ-2.7GHZ
Transmitter Module: Four in One High Frequency Module (CC2500 CYRF6936 A7105 NRF2401)
Transmit power: maximum 22dbm (transmit power adjustable)
Antenna gain: 2db (detachable antenna, easy modification)
Working current: 88Ma@8.4V
Working voltage: DC4.5-DC18V (factory with 4 x AA battery box, lithium battery recommended 2s balanced head line, batteries not included)
Remote control distance:> 2km @ 22dbm
Open source firmware:
Number of channels: up to 12 channels (depending on the receiver)
Display: 2.42-inch OLED display, 128 * 64 resolution
Rocker way: non-contact 3D space vector Hall joystick
JR/FrSKY compatible module bay on rear side
Upgrade method: USB online upgrade
Support Protocols:
Walkera full range
DSM2/X full range
Flysky and Flysky 2A
FrSKY
FUTABA s-fhss full range
WL Toy series, Hubsan series, Esky series and many more (Currently a total of more than 40 supported protocols)
Uses open source software with continued support and development, adding new protocols regularly.
Simulator mode: 3.5mm standard ppm output
USB output.
Features:
* Built in four-in-1 RF Module (CC2500 CYRF6936 A7105 NRF2401).
* Open source multi-protocol firmware, compatible with most mainstream remote controls
* Non-contact 3D space vector Hall remote sensing Gimbals (T8SG Plus Only).
* T8SG Plus 2.42 inch OLED display, Bright display works even in direct sunlight.
* JR/FrSKY compatible module bay on rear side.
* USB online firmware upgrade.
* Transmission power adjustable to adapt to different location requirements.
* Detachable antenna, easy to change.
* Ultra-low power consumption, longer battery life.
* Up to 12 channels of output (depending on the receiver), Open Source Firmware, all channels are fully programmable.
* Wide voltage input (2s lipo recommended).
* Multilingual menu.
* Vibration reminder function.
* Support telemetry (depending on the receiver).
* Carry Case included.
Aaaaaw !
Might supersede all before it (?)
Jan 28, 2018, 05:06 PM
Hey, watch this!
Raymond-leflyr's Avatar
Wow, $110 American. This might make a good choice for a single backup transmitter since I fly Spectrum and Futaba. I wonder if it would work as a buddy box?
Jan 28, 2018, 07:56 PM
I have watched a few Jumper T8sg reviews and no one mentions a trainer port
Feb 08, 2018, 05:05 AM
Glen
glenby's Avatar
it has one on the top.
a jack plug. I think it is 3.5mm
Discussion Jumper X68T Micro FPV Whoop Racer Flight Test Review (Made for T8SG Jumper) t00nz843z Micro Multirotor Drones 1 Jun 18, 2018 04:33 PM
Discussion Jumper T8SG Plus V2.0 Multi-protocal 12CH OLED Transmitter for Flysky Frsky DSM2 BobFromMars Banggood.com 7 May 21, 2018 06:02 PM
New Product Jumper T8SG Plus With V2.0 Hall Gimbal & OLED Display fastmax Radios 1 Feb 28, 2018 05:03 AM
New Product Jumper T8SG Plus Multi-protocal Transmitter GeekBuying Multirotor Drone Talk 0 Jan 23, 2018 03:01 AM
New Product Jumper T8SG Plus Multi-protocal Transmitter Geekbuying GeekBuying Geekbuying.com 0 Jan 23, 2018 02:34 AM
