8 & 10 channel receivers Master/ Slave - RC Groups
Jan 26, 2018, 03:45 AM
If you bind two 8 channel receivers as master and slave and map the outputs of the slave the same as the master then connect to servo with y leads would this give any diversity if the antennas were set at 90 degrees. Would the servo work with two input signals.
Probably a dumb question but I have 10 of these and would like to use them.
Jan 26, 2018, 12:34 PM
The 8 and 10 channel receivers can not be used as master/slave, only the Nano and RFU have this capability. Also, you can NEVER connect two receivers to the same servo!
Jan 27, 2018, 01:44 PM
E_ferret's Avatar
wellll, it Is physically possible, but......
Discussion Slave 8 &10 receivers cellbuster Xtreme Power Systems 3 Jun 21, 2016 10:11 PM
Question Futaba 10c Master / Turnigy 9x Slave??? panos2408 Radios 0 Sep 20, 2015 03:55 PM
Help! DX-6 (master) to DX-8 (slave) ih8nixon Radios 7 Oct 14, 2011 11:05 PM
Discussion Using a 10 channel receiver w/8 channels avaiable on a Futaba 9 Cap Al Czervik Xtreme Power Systems 2 Oct 12, 2007 11:09 AM
Discussion Can a satellite receiver be connected to main XPS 8/10 channels receiver ? jellyfish Xtreme Power Systems 30 Oct 08, 2007 01:01 PM
