AXII Antennas From TrueRC Canada
The AXII antenna was developed through a collaboration between TrueRC and Lumenier. Let's take a look at the different styles and options of this popular FPV 5.8GHz antenna.
Multiple AXII Options From TrueRC Canada
The AXII antenna has been on the FPV market for a little while now, but I wanted to share a couple of options from Hugo at TrueRC Canada. Hugo collaborated with Lumenier to create the AXII, and the result is one of the smallest, lightest, and best performing 5.8GHz antennas yet. Here's some info on the AXII design, taken from TrueRC's website:
The Lumenier AXII 5.8GHz Antenna makes a giant leap forward in FPV antenna technology. Lumenier, in collaboration with renowned FPV antenna designer Hugo of TrueRC, brings you one of the smallest, lightest and best performing FPV antennas in the world. The AXII antenna is an original design that features a new RF pathway technology (unique hybrid network) allowing it to be incredibly light weight (7.6g) and less than half the size of most other 5.8GHz CP antennas.
Even though the AXII is both small and light weight, it does not sacrifice any performance. In fact it out performs most other antennas in all categories. Precision engineering has given this antenna a near perfect 1.0 Axial ratio resulting in a true circularity. On top of that the AXII has a high max gain of 1.6dBic enabling better range and penetration. It has a wide bandwidth covering the popular FPV 5GHz band from 5.5GHz-6.0GHz, ensuring you have a clear and strong signal no matter which frequency you’re on.
The AXII is designed to be ultra durable and put up with the beatings FPV pilots put on their antennas. The cable is a semi-rigid, black coated RG402 cable and 45mm long, allowing for 90 degrees or more of freedom. The SMA connection is reinforced with a metal collar crimped to the base for extra support. The outer shell case is made from an impact resistant polycarbonate material, and it is sealed shut to guard the antenna elements inside. Note: When installing, secure the antenna via the SMA connector, do not twist the cap.
CLICK HERE to order the AXII antenna from TrueRC Canada.
Mar 09, 2018, 08:28 AM
My tapeworm tells me what todo
whom has these in the US?
Don't want to deal with customs BS
Mar 09, 2018, 09:16 AM
Matt Gunn's Avatar
There isn't any customs BS. I've ordered from TrueRC Canada countless times. Shipping is actually faster than many US distributors.
Mar 11, 2018, 05:12 PM
USA: LakeGeorge, New York
Get a hold of HUGO here (TrueRC himself)....
PM him, he will send you these as fast as humanely possible.
100% worth it.....
New Product New CP antennas from TrueRC Hugeone FPV Equipment 761 May 11, 2017 01:29 PM
Question Truerc x-hair goggle antenna Bgodard FPV Racing 2 May 08, 2016 08:14 PM
News TrueRC X2-Air 3.3 Directional Antenna Matt Gunn FPV Talk 0 Dec 08, 2015 04:19 PM
News Free Antenna Tuning from TrueRC.net Matt Gunn FPV Talk 0 Aug 28, 2013 01:28 PM
Discussion Thomas's LRS now available from TrueRC Canada! Hugeone FPV Talk 14 Mar 23, 2010 10:01 AM
