New Castle Creations Talon 60 ESC
Castle has some of the best ESC's on the market and the Talon series works great for both planes and Helis. Last month, they added a new product to the Talon line with the Talon 60.
Splash !Castle Adds a New ESC to the Talon Line Castle has some of the best ESC's on the market and the Talon series works great for both planes and Helis. Last month, they added a new product to the Talon line with the Talon 60. It's perfect for RC helicopters in the 360-450 size class and it can handle setups up to 1400 watts with 6S voltage. It comes with all the heli functions you'd expect from Talon like the easy to setup governor mode. The ESC is small and slim making it easy to install right where you need it. The Talon 60 has a heavy duty 8A continuous BEC circuit that can handle a remarkable 20A peak current. It's also telemetry capable for monitoring voltages, temp and other parameters if you have a compatible radio system. The Talon 60 is designed and manufactured in the USA and is fully supported by the Castle Team along with a 1-year warranty. !!Check out the Castle Creations Talon 60 Here !!Technical Specs:
  • Input Voltage Range: 2S -6S LiPo
  • Max Continuous Amperage at full throttle: 60 amps
  • Max Voltage: 25.2V
  • BEC Voltage: User selectable choice of 6 or 8 volt output (default is 6V).
  • BEC Output: 20 amp peak , 8 amp continuous
  • Size: Width: 1.19" (30.2mm)
  • Length: 2.56" (65mm)
  • Depth: 0.41" (10.6mm)
  • Weight : 2.05 oz. (57 g) with wires, 1.09 oz. (g) without wires
Jan 26, 2018, 04:15 PM
as much as I can
beenflying's Avatar
Should be a popular size for 380's and 420's, but I think I still prefer the Hobbywing 60A V4 for similar money. The Hobbywing also has a more flexible BEC voltage setting, less weight and looks nicer, IMHO.
Jan 26, 2018, 05:14 PM
Turnigynarian
2Doggs's Avatar
For me, both are a hard sell next to a $30 YEP 60A! I can put up with the bland colour scheme of the YEP too, since it hides under my canopy!
The Hobbywing V4 is impressively light, however.
Jan 26, 2018, 05:51 PM
as much as I can
beenflying's Avatar
Yes, the YEP is a very good value ESC, if you can live with it's history and the LV BEC. In my older heli's I have quite a few of them.
Jan 29, 2018, 12:33 AM
Cá bhfuil Micheál?
spykez's Avatar
Competition is good, I guess! Good to see they're still in business, honestly. I guess their products are quite diverse and not limited to helis. I wonder do they do the multi thing as well.
Jan 29, 2018, 11:47 AM
Steve_'s Avatar
They make all sorts of stuff. http://home.castlecreations.com/
Heck, I have Castle motors and ESC's in my R/C trucks.
Traxxas Rustler with Sidewinder III 4600KV (1 min 52 sec)
Jun 03, 2018, 11:19 PM
Twin Cessna's Avatar
I have always used Castle esc's in all of my planes because I have to much invested in them to cheap out on a controller and receiver power supply. Plus my Talon 60 works great.
Discussion Castle Creations Talon 90 - Set Up Mister Kenova 3D Flying 17 Jan 13, 2019 09:14 PM
Discussion question on Castle creations Talon 120 hv speed control setup pault Large Electric Helis 2 Dec 27, 2015 05:34 PM
News Castle Creations Talon Series and the Talon 120 HV Jim T. Graham Electric Heli Talk 0 Apr 07, 2014 05:21 PM
Discussion Castle Creations Phoenix 60....Too Much ESC? xholbyx922 Electric Plane Talk 5 Sep 19, 2008 09:35 AM
Question Typhoon EDF 2W motor Castle Creation 60 amp ESC how to set it up? redtail Power Systems 2 Aug 30, 2007 07:05 PM
