Download
An Ardupilot frsky telemetry LUA script for the Horus X10/ X12 and Taranis X9D/E/QX7
Hi,
it all started as a way to learn lua and the new frsky passthrough protocol and day after day the project grew into a full blown telemetry script. It requires aHorus X10, X12 or a Taranis X9D+,X9E or QX7 radio, OpenTX 2.2 and arducopter 3.5.x. - full implementation of the frsky passthrough protocol - per model configuration menu - dual battery support - vocal alerts - vocal fence - min/max values - frsky sensors passthru the code is available on github https://github.com/yaapu/FrskyTelemetryScript Edit:18/05/2019 Taranis X9D/QX7 and X-Lite version 1.8.0 Edit: 4/06/2019 Horus version 1.8.0 rc2 horus_1.8.0_rc2.zip |
I just installed the script, it is working very well. Impressed how fast the horizon follows the angles. Thank you for the great work!
I have a Radiolink Mini Pix, XSR receiver and X7S carbon radio. I tested it on only on the desk yet. I had to rename the script from .luac to .lua. Enabling luac on the radio is not working. The radio beeps slowly, not sure what is its meaning? A screen with the GPS coordinates could be helpful. I have only one battery, is it possible to disable the other two? |
the script beeps every time a new mavlink message arrives, you can see the incoming messages by short pressing [PLUS]/[MINUS] You can disable the beeps from the configuration menu, to enter config long press [MENU] To add GPS coordinates: - make sure you run sensor discovery, GPS should appear in sensor list - add a second telemetry screen with NUMS and select GPS as the value to show. - while the script is running short press [PAGE] to view second telemetry screen, press [PAGE] again to get back to the telemetry script Second battery support is enabled only if the script detects it, otherwise will only monitor 1 battery, do you have an issue with battery monitoring? |
yaapu, Very impressed with your script. Thinking of putting it on my 680 hexacopter to replace my original script (yours lua screen is way more intuitive I think). I have 2 batteries on my hexa paralleled up running through 1 x Mauch sensor (instead of regula APM power brick), so Arducopter sees a single battery which I'm happy with. For monitoring cells however I have 2 x FLVSS sensors. In order to use both with your script, I appreciate the first sensor should use the name Cels on the OpenTx telemetry sensors page (the default name) , but what should I name the second sensor (I have it using ID15) for it to be used by your script? Am I correct in thinking Cel2 ?
Thanks, Paul p.s. I noted when I tested your script on my text quad (which has FLVSS also) that the minimum cell value was sometimes a little off compared with the FLVSS LED display values - maybe just 0,01v difference but I would have thought it should mirror it precisely? |
I thought I'd just go ahead and connect an inverter to Serial4 on my hexa (in place of the previous teensy) and it works fine. I can see aggregated battery view for the 2 FLVSS sensors. I'm not sure how I get to separate battery views as your notes (on github) seem to have a conflict. You say:
A short press of [ENTER] on Taranis or [ENCODER on Horus ]cycles between all the sources then later on: A short press of [ENTER] on the Taranis or [ENCODER] on the Horus switches from single aggregate view to individual dual battery view. In reality the short press of ENTER does the first of these two actions, to cycle between battery sources. So not sure which key to do the latter - can you please advise as I have tried all the keys but don't get the dial view. Cheers, Paul |
a short press of [ENTER] does both, if 2 batteries are detected the first press switches to dual view, subsequent presses cycle between sources, if you press exit the selected source becomes the current one. In your case the second battery is not detected for some reason. I look for the second FLVSS as "Cel2", is has to be of type table to be detected by the script, ID should not matter as long as is different from default. I must admit that I tested dual FLVSS sensors only in companion, but I have a second FLVSS on the way and I'll be able to test it better. Code:
------------ -- FLVSS 2 ------------ cellResult = getValue("Cel2") if type(cellResult) == "table" then cell2min = 4.35 cell2sum = 0 for i = 1, #cell do cell[i] = 0 end -- cellcount is global and shared cellcount = #cellResult for i, v in pairs(cellResult) do cell2sum = cell2sum + v if cell2min > v then cell2min = v end end -- if connected after scritp started if batt2sources.vs == false then battsource = "na" end if battsource == "na" then battsource = "vs" end batt2sources.vs = true else batt2sources.vs = false cell2min = 0 cell2sum = 0 end L |
Cheers, Paul |
![]() Thanks for digging this out |
Paul please try this version and let me know :-)
Thread Tools | |
Similar Threads | |||||
Discussion | F3K programs for OpenTX transmitters | jfrickmann | Hand Launch | 1871 | Feb 25, 2021 08:42 PM |
New Product | Upgrade Taranis Loudspeaker for Frsky Q X7 / X9D / X9D Plus and X9DP SE | sevet | Radios | 1 | Sep 19, 2017 09:13 AM |
Discussion | FrSky Taranis X9D Plus and Q X7 Buddy Box Trainer | cremachine | Radios | 4 | Jul 23, 2017 07:45 PM |
Yippee! | BUDDY CODE for FrSky TARANIS X9D (Mode 2) | cacomistle | HobbyKing | 5 | Mar 29, 2014 01:57 AM |
