microvector set up ? - RC Groups
Jan 18, 2018, 07:51 AM
how do you set this thing up without using an osd (cant be done). eagletree syes you can. HOW
yes you can set it up with a comp. but when you have an err code (I do) you need an osd. and I don't have an osd yet
so as im getting an err code i cant do a thing with it what do i do now?
and why put power wires on the output to the servoes when in the manual it syes not to hook them to servoes ?
but on youtube there are vids ppl are doing it. is it ok to do it or not.
Jan 19, 2018, 07:49 AM
A good read of the manual will serve you well.
http://eagletreesystems.com/Manuals/MicroVector.pdf
"how do you set this thing up without using an osd"?
By using a computer as you said yourself.
Otherwise you have to wait until you have a monitor or some sort of display that accepts composite video display or video transmitter / receiver / display arrangement.
You don't even need a camera.
RE servo wires and power etc,
Power for your servos should come from an external power source such as BEC or ESC.
You should not power your servos from the PSU module even if you see Youtube videos doing so. I guess Eagletree as the manufacturer might know better than Youtubers about their own device.
You run the risk of overloading the PSU and shutting down the system in-flight resulting in a crash.
The cables with servo connectors should only be used for powering your camera and video transmitter.
Hope this helps some what.
Geoff
New Product Eagle Tree MicroVector integrated Flight Controller/OSD - Vector's little brother :) billpa FPV Equipment 1198 Feb 22, 2018 04:01 PM
Help! Radio Set Up - what's the best set up for a number of 1/5th & 1/8th scale bikes? PUMA937 Motorcycles 4 Mar 03, 2011 12:34 PM
Help! To set-up or not to set-up Mystery 100A pompebled Racing Boats - Electric 13 Nov 03, 2008 04:24 AM
Discussion Easy Star set up please - no speculation -no ideas - only your set up and facts ! djdaveq FPV Talk 20 Oct 03, 2007 01:56 AM
