Jan 17, 2018, 10:31 PM
CUAV HACK LINK Digital Data Link System for PIXHACK Flight Controller FPV UAV Drone Q
CUAV HACK LINK Digital Data Link System for PIXHACK Flight Controller FPV UAV Drone Quadcopter
http://store.fpvbox.com/index.php?ro...product_id=129
Specifications:
- Support HDMI video input (720-1080P)
- Real time 720P HD video and mavlink flying data
- Using APP to display video and flying control
- Dual antenna MINO technology, dual channel 500mW RF unit
- Distance up to 2-3km
Ground station:
- Built in OLED that can display flying data and quantity of electricity
- HDMI 720P vidoe output, can connect to monitor and glasses
- MAVLINK output, can connect to CUAV antenna
Description:
- HACK LINK is the HD digitallink system, supports MAVLINK data.
- This is for PIXHACK
- HACK LINK supports 720P HDMI real time video transmission and mavlink data, also supports PPM remote control data forwarding. You can see and control the video by phone or tablet PC.
- IMX6 CPU for ground/air station, and running Linux system
- Not support SBUS input, only supports PPM input
- Not support to connect the phone by USB
- RC IN without 5V output, if connecting PPM receiver,needs independent power
Hardware parameter:
Air station:
- Communication ditance: 1-3km
- Effective isotropic radiated power (EIRP):500mW*2
- Receiving sensitivity (1%PER): -95dBm-+2dBm
- Antenna gain: [email protected]
- Working frequency: 2.4Ghz ISM
- Antenna connector: UFL
- Working voltage: 5V +-0.4V
- Max. current:1600mA
- Processor frequency: IMX6 1GHz
- Memroy: DDR3 512MB
- System disk capacity: 8G
- Delay: 100*200ms
- Working temperature: -5~60 deg C
- Size: 75*45*45mm
- Weight: 79g
- Video input format: HDMI 720/1080P
- Support hardware: Camera with HDMI output, GOPRO3/4/Xiaoyi,etc
Ground station
- Antenna connector: SMA
- Working voltage: 5V +-0.2V
- Max. current:1700mA
- Battery capacity: [email protected]
- OLED resolution: White @128*64
- Working temperature: -10~50 deg C
- Size: 80*45*25mm
- Weight:150g
- Video input format: HDMI 720p
Package list:
- 1 x HACK-LINK Ground station
- 1 x HACK-LINK air station
- 2 x Antenna
- 2 x Sipex to SMA connecting cable
- 1 x Micro HDMI cable
- 1 x USB data cable
- 1 x HDMI interface cable
- 1 x Signal cable
- 1 x Power cable
- 1 x Power supply module
- 1 x PIXHACK/PIXHAWK USB cable
Jan 17, 2018, 10:32 PM
CUAV Hack Link 720 HD Fpv system streaming with Telemetry (1 min 1 sec)
Mar 08, 2018, 10:18 PM
RC part
hi ,dear , how are you ?
we are the factory to make CUAV producst. you can check our website here
https://leixun.aliexpress.com
I think we can cooperate each other, dear
Best Wishes !
lindy liang
Guangzhou CUAV Technology Co,.LTD
Address: N203B , 3 North Gate,Technology Park software building , City Ring Road South 2 ,Nansha District , Guangzhou City,Guangdong. China
Tel: 13570272379
Wechat:0086-13570272379
E-mail :[email protected]
Websit:
http://www.cuav.net/
Mar 30, 2018, 07:06 PM
Hi, I have two problems, the first and most important, is that the telemetry transmission is disconnected and reconnected, constantly.
Which causes it to disconnect from the navigation programs. I'm using pixhawk 2.4.4 and pixhawk 2.1 with the same results, in 57,600 as well as 115,200 baud.
The second problem is that I can not see video in any of the 3 app, that I installed, if I see perfect video on a monitor.
Regards
New Product CUAV HACK LINK 2.4G Digital Link HDMI PPM & Mavlink for PIXHAWK sevet Multirotor Drone Talk 61 Aug 02, 2018 04:43 PM
Discussion CUAV Hack Link 2.4GHz 720P HD Video/Mavlink Transmission Juli112 FPV Equipment 8 Jan 30, 2017 03:06 AM
Discussion Rabbit flight control FPV data hack bnn1044 Multirotor Drone Talk 3 Apr 29, 2012 07:58 PM
