New? fly-toy from Toys R US.
Is this new? Or have I just failed to see it?
I just ordered one. At worst, I get new parts! http://www.amazon.com/exec/obidos/tg...=glance&s=toys --del |
Del,
This looks just like something I was looking at with interest, in a local newspaper here in the UK. It had been reduced from £20 to £9.99. The newspaper picture was rather fuzzy. Your web pic's give a better idea of what the plane looks like. I can't see if there is any banking/ turning control though, it looks as if there is just a sliding throttle quadrant? It doent say in the blurb, if there is a turning control, but it says it can be flown inside the house! Interesting carbon construction and ring to protect the prop and a spare wing included. Let us know how you get on with this. The other Graham |
hi graham i made a post some where about this i have 2!
there ok! waiting to convert mine! comes with a lipo and 2 sets of wings how it works is when you open her up she climes them when you let off she dips to the left letting you do some nice circles! i can fly mine in a very very small room! ROG is posable on any surface! very fun hope this helps cosha ![]() ps got mine from argos 5 months ago £19.99 now there £29.99?? dont know what thats baout |
There are several threads dealing with these. I forget what they are called, which makes it harder to search. They have 2 channels: motor on/off, and turn-left/go straight. Yes, they do not turn in both directions, there are only two buttons to push.
In the gym where I saw them flying, they did amuse the adults for about 5 minutes and then they gave them to the kids. They did survive the kids' abuse for quite a while and kept them amused for a long time. They seem to be sturdy enough (see 'abuse' above) to warrant the effeort to convert. They are marginally powered and will require some work, but may be worth your efforts. |
I have already hacked one of these. See the thread, 70% micro Tifo It''s actaully one channel. The wings are canted so they always fly in a circle. The GB looks pretty good but be very careful when you remove the lipo. It's glued to a plastic frame member so I damaged it when I tried to unglue it. So much for that. I had to buy another lipo. WHat you can do is hack it so you get a battery powered 1 cell battery charger. I think Mike Taylor is talking about something else. The controler has no button but has a slider that controls the motor. It called the Jasman Vroom Zoom
http://www.argos.co.uk/webapp/wcs/st...oductId=108591
They are still £29.99 in argos. I wonder why they didn't make a version with steering? |
If you were to convert it to 2 or 3 channel you would have to build another wing from carbon fibre so it would not turn to one way. take out the 1 channel rx and replace it with bit, infra red, or just the normal jmp or rffs radio. Keep the speed control, motor and maybe the prop and the battery in the plane. You could still use the charger if you use the same lipo that was in the plane originally. I do not know if the lipo would have enough power to fly it.
The plane seems a good price for what you get. Cannot wait to see if anyone has converted this plane. Alex |
VrRoom Zoom
Hi all,
The plane is called a VrRoom Zoom and there have been a couple of very short threads about it elsewhere. https://www.rcgroups.com/forums/show...7&page=2&pp=15 http://www.smallflyingarts.com/cgi-b...num=1094732522 I purchased it just because I could fly it in my classroom between periods. If you launch it level and don't apply too much throttle, it will make about an 8' circle in the classroom without climbing and hitting the ceiling. However, it is not as easy as it sounds, because the Tx is prone to glitches. At that point the plane falls off in another direction and begin a new circle from that point, invariably into the wall. This leads to what I consider the achilles heel of this design: the propeller is simply glued to the end of a shaft and is not really replaceable. When it breaks you have a much shorter shaft to place the prop unto, so they can only be done once or maybe twice. Although it is protected by a carbon fiber loop, if an object (such as a desk) strikes the propeller, then it snaps and you are in a predicament. I had to cut the foam away from the motor, replac it with a prop from DEW, force the prop on, and then use a wire configuration to hold the gear assembly on the plane. The other problem with the versions I saw and flew was it is way tail heavy, and no real way of moving the CG. To balance it I used paper clips. That is fine until the plane is a bit higher in the air (say in the gym) and the inevitably glitch occrus: the plane then takes a straight nose dive, breaking the propeller. It is a cool idea for a little fun tight space flying, but did not prove to be durable. I am not really skilled enough to hack the plane, although it probably could be made into a good little indoor plane. If they would move the CG and make the prop repairable, I would purchase another one. They are only about 25 dollars here in SE Asia. Hope this is useful. I have one intact carbon fiber frame and a couple of wings. If I could find an inexpensive way to hook up a new motor and prop system I would be able to put it back into action. Any suggestions? Hope this is useful. |
Suggestions?
Okay, I knew this plane would come up someday, anyway, my fathers good
friend is the main designer for this company (which operates out of Germany) He sent me 2 free ones ![]() snapped) ![]() impact (something stupid I did ![]() correct C.G is established with the use of modelling clay, it flies in tight 5ft diameter circles. I personally was a bit skeptical at first at what the performance of a single-channel motor controlled plane would fly like, but with its generous polyhedral, it flies beautifully. I've already sent some e-mails to this man (the designer) outlining how great it would be if the company could utilize magnetic actuators for 2 channel motor and rudder control. Needless to say, this would still fly in your living-room (mine did! ![]() ![]() Thanks, Sean ![]() |
Thanks guys, for all that useful information. It sounds worth buying at the price Iv'e seen it at.
Perhaps It was going for £19.99 not £9.99? Now where did that newspaper cutting go. . . The other Graham |
OK, sound's like I'm "behind the curve" again... Not that unusual..
But, YES!! Sean, After seeing Wattage MF's dissapear off the local hobby shop's shelves like bottled water in the desert, there is a market. And after having built a couple of models with the WAMF electronics, and seeing the reaction of folks at the gym when ya get it to fly slow and actually turn.. it's clear that there is room for improvement, and money to be made. Anyhoo.. Toys _are_ us... And if I can help _us_ get more toys, let me know. --del |
Beanoman ---- just (off-topically) curious: What is "Beano"????
Peter |
Didn't you ever see 'Blazing Saddles'? Beano prevents that scene around the campfire...
Many thanks Mike: I had a sneaking suspicion it might be something of that ilk!!
Peter |
Reason: typo
Thread Tools | |
Similar Threads | |||||
Air Hogs Defender from Toys R Us (twin-engine, no control surfaces) mods/info? | jay flay tway | Scratchbuilt Indoor and Micro Models | 9 | Dec 18, 2006 12:44 AM | |
Bought a bunch of the 5" TFT screens from Toys R Us -- Need one? | JohnSoPA | Aerial Photography | 15 | Jan 23, 2005 12:50 AM | |
Toys R Us | Peteohms | Scratchbuilt Indoor and Micro Models | 4 | Nov 27, 2003 10:15 PM | |
Anyone using the Toys-R-Us batteries in a GWS Zero? | WickedFunRC | Batteries and Chargers | 4 | Nov 16, 2002 11:18 PM | |
Packs @ Toys R Us | Daddio | Aircraft - Electric - Airplanes (FS/W) | 19 | Oct 18, 2002 11:43 AM |
