Futaba T16SZ - RCGroups Video Review
Join editor Matt Gunn as he shows some of the functions on the newest 16-channel computer transmitter with an easy to read 4.3" LCD screen.
Futaba T16SZ - RCGroups Review
The T16SZ - A Powerful Air System
Product:Futaba T16SZ
Retail price:$699.99
Channels:16 proportional channels, 2 switched
Memory:30 Models
Included Battery:6.0V 1800mAh NiMH
Included Receiver: R7008SB
Available from:Tower Hobbies
The Futaba T16SZ bridges the gap between the more expensive 18 channel transmitters and the tried and true 14SG. By taking the bullet-proof design and ergonomics of the 14SG, and adding in a 4.3" LCD touch screen and a complete interface refresh, Futaba has given the modeler an affordable and easy to navigate computer transmitter system with an impressive feature list.
In this video review, I'll show you some of the main features that you'll utilize when you start up your T16SZ for the first time. But first, let's take a quick look at some photos of the Futaba T16SZ, and what you can expect when you open the box.
Features:
  • Compatible with FASSTest, FASST, T-FHSS and S-FHSS protocols
  • Full telemetry compatible
  • 4.3" LCD touch screen
  • 10 programmable mixes
  • S.Bus servo programming editor
  • S.Bus trainer port
  • 3-axis gyro support
  • 30-model memory with 15 character naming
  • Swash and throttle mixing
  • V-tail mixing
  • Adjustable servo speed
  • AFR/DR
  • AFR curve mode (3)
  • AFR curve point (17 points)
  • Idle down
  • Logic switch
  • 8 flight conditions
  • Throttle cut
  • Voice message/audio earphone jack
  • Micro memory card slot
  • Software updateable
  • Up/down/integral timer
  • Free online software upgrades
  • Lap timer memory
  • Stick calibration
  • 180 antenna rotation and 90 angle adjustment
  • Multi language (9 languages)
  • EPA
Video Review
Futaba T16SZ - RCGroups Video Review (8 min 53 sec)
Mar 14, 2018, 12:12 PM
Team Futaba
Silent-AV8R's Avatar
Minor correction Matt. The two switches on the top/back of the transmitter are 2-position switches.
Switch SH is a spring loaded switch (upper to right)
Switch SF is a 2-position (upper top left).
And those switch positions are the same on the Helicopter and Airplane versions
And for general information there is a long thread on this radio in the Radio Forum:
https://www.rcgroups.com/forums/show...32-Futaba-16SZ
And there are a number of videos done by Chip Hyde here:
https://www.futabarc.com/systems/fut...16sz/index.php
Scroll down a bit.
Mar 14, 2018, 12:34 PM
www.gunnphotoservices.com
Matt Gunn's Avatar
Thanks!
Latest blog entry: www.gunnphotoservices.com
Mar 14, 2018, 07:16 PM
USA: LakeGeorge, New York
I'll buy a 2nd hand used version...
Is there a selection in the menu to disable the inside
2.4ghz module?...
just in case I want to add UHF module (ie....Dragonalink UHF)
just askin'
Latest blog entry: My FAVORITE FPV CockPits'!!!!
Mar 14, 2018, 07:25 PM
Team Futaba
2.4ghz module?...
just askin'
No, there is not that ability.
Mar 14, 2018, 07:29 PM
S.A.D. member
ivanc's Avatar
Yes, there are at least two ways to disable the internal RF circuit.
1. Start the transmitter with an active warning like high throttle (throttle warning needs to be enabled) then select RF OFF.
2. In Trainer select Student
Ivan
Mar 14, 2018, 08:34 PM
Team Futaba
I was thinking more permanently. Both of those will work on a per flight basis.
Mar 14, 2018, 08:43 PM
Ivan
On the 14SG,
one said, hold the menu dial down while powering ON...
then menu asks to turn 'internal 2.4 module on or off'...
Can one try this on this new Tx if it works?
P.S.
gotta be honest with you...I like the new menu and
Futaba has the easiet & most friendly menu format
(compared to sheeeeety Taranis complicated menu).
Mar 14, 2018, 09:00 PM
S.A.D. member
ivanc's Avatar
The 16SZ does not have a "Menu" button.
Solution #2 is permanent for the specific model memory in which it is enabled. Indicated by the darker blue MONITOR light.
Ivan
Mar 14, 2018, 11:27 PM
Team Futaba
On the 14SG,
Hold down the right side U.Menu/Mon button and turn on the TX.
It will boot up with the RF off. The LED will be purple.
Holding down the left side button Home/Exit enters the update mode if you hold it down while turning it on.
Mar 15, 2018, 11:20 AM
Cool thanks..then its Right Button hold-down then.
..but do you have to do this every time you turn it ON once the UHF Tx is attached?
Mar 15, 2018, 11:41 AM
S.A.D. member
ivanc's Avatar
Yes... unless you turn on Trainer Slave for that model. Then you do not have to do the 3 button combo on power up.
Ivan
Mar 24, 2018, 07:58 AM
'Extreme Fabricator'
Should I buy this or another Taranis? What does this radio have that the Taranis or Horus doesn't? I especially like the precision of 4k gimbals when soaring, getting that breathe on the stick precision is addictive and not easy to step down from, does the Futaba have Hall effect 4k gimbals?
I liked the previous generation Futaba for the build quality, but it's expected for the price, although futaba receivers are knock you to the floor expensive, are they backwards compatible to this radio?
Mar 24, 2018, 09:52 AM
Originally Posted by alicecooper
What does this radio have that the Horus doesn't?
probably more reliable RF link. as for hardware quality it's not superior but far behind in sofware capabilities
the 18SZ will be upgraded (optional) to hall effect gimbals, if you don't own 4K servos it makes the gimbal' resolution useless.
Mar 24, 2018, 02:14 PM
Why is this RC Tx/Rx $600 and the Range is just beyond LINE OF SIGHT???
why can't Futaba make a 900mhz version for RC transmission? Something close to UHF distances!
just sayin'/askin'
(FPV fixed wing point of view)
Discussion Futaba T16SZ - binding issue/question CodiJack Radios 6 Dec 14, 2017 06:07 PM
Review RMRC Surfer 1500 - RCGroups Review Jim T. Graham FPV Aircraft 27 Aug 23, 2017 05:02 PM
News Futaba T16SZ - 16 Channel Transmitter Matt Gunn Radios 34 Jul 10, 2017 10:38 AM
