72" Wingspan Super Trainer | Maiden Flight Added! - RC Groups
Jan 16, 2018, 06:33 PM
Build Log
Hi guys, after not touching anything RC related for 2 years I am now back at it! Here is a new plane that I am working on. Although it has the classic topwing & rear prop trainer layout, this will be used as a personal slowflyer to carry my Mobius action cam and a GoPro Hero 4 Session.
Project Focus:
- Slow flying
- Very stable and smooth
- Easily detachable wing for transport
- Rigid fuselage & tail design
Dimensions:
- Length: 45.5"
- Wingspan: 72"
- Cord @ fuselage: 7"
- Cord @ tip: 5.5"
- Wing area: 3.19 sq ft.
- Flying weight: ~ 1200 g (42.3 oz)
- Wing loading: 13.26 oz/sq ft.
Specs:
- Motor: EMAX CF2822 1200KV motor
- Prop: 9x4
- ESC: Turnigy Plush 25A
- Battery: Turnigy 5000mah 3S LiPo
- Receiver: OrangeRx R615X
Maiden Flight:
Homemade RC Plane | 72” RC Plane | Super Trainer | Maiden Flight (4 min 21 sec)
Jan 16, 2018, 06:45 PM
Lighting Setup:
- Voltage regulator (constant 14.5V)
- 8x warm white 8mm straw hat LED's (100ma)
- 4x red 8mm straw hat LED's (100ma)
- 4x green 8mm straw hat LED's (100ma)
Jan 16, 2018, 07:02 PM
It looks really cool wish i could have one. That's a big battery what power system are you using to get it airborne. Hope the maiden goes well.
IMO ( In My Opinion ) →
balsa or carbon's Avatar
Looks good ! Flying video if possible !
Jan 16, 2018, 07:17 PM
Thank you, I am using a small 1200KV motor with a 9x4 prop. This combo will produce about 500-600 grams of thrust at full throttle. It should be able to cruise at around 50% throttle, I am hoping for 30 minute flight time.
Thank you, there is still a fair bit of work left before the maiden! But, there will definitely be some videos.
I hope the maiden will go well, I will be hand launching it. I am a little worried as I have never hand launched anything this size and weight.
Jan 16, 2018, 08:14 PM
I hand launch this 60" wingspan plane no problem :
FT Old Fogey-ish with 60" wingspan (1 min 56 sec)
Jan 16, 2018, 08:17 PM
https://www.youtube.com/watch?v=mGLj43y-VUM
Very cool, it flies sooooo slow! It looks very lightweight, what was the flying weight?
Jan 16, 2018, 08:28 PM
1073 grams flying weight , 60" wingspan with a 20" chord . I built it for the single purpose of flying slowly , so I built it as light as possible .... and it has to be flown gently .
The video in my previous post was of the maiden flight , here is another video of it flying higher up :
60" wingspan Old Fogey-ish flying up higher (4 min 52 sec)
Jan 16, 2018, 09:15 PM
Yea with that power setup you would probably have long endurance with that 5000mah battery. Hope it goes well, also please do maiden flight video.
Jan 16, 2018, 11:32 PM
Some progress on the cabin/cover, and a little paint. The battery cover is held in place with a tab that slips into the fuselage at the front and rare earth magnets at the top.
Tomorrow I plan to work on the nav lights and finish the wingtips. Maybe I can get the wings painted as well
Jan 17, 2018, 05:59 AM
Multirotor Enthusiast
Blacky's Boy's Avatar
A quick question
First off, love the design! Nothing like a big slow flyer
Excuse my ignorance but what are the electronics located at the midpoint of the wings for? Are they for the lights?
Jan 17, 2018, 08:52 AM
Thank you
The electronics are for the LED's, basically a voltage regulator and pack's of resistors for the white, green, and red lights.
Jan 17, 2018, 01:48 PM
Very nice build.I had NOT considered subbing masonite/temp. hardboard for plywood. Now I have to do some spec. comparisons. I just bought a sheet of HB -1/8"x2'x4' for hot wire templates. I have found Formica to be useful in place of thin plywood.
I was thinking of doing a similar size build of an old homebuilt called a Don Quixote. A very similar design planform to yours. Thanks for the proof of concept.
Jan 18, 2018, 04:42 PM
Navigation LED's wired up:
Discussion A Used 72" Trainer, How Far Would You Go To Fix It? GliderGuider2017 Sailplane Talk 1 Apr 05, 2017 06:16 AM
Cool [EU Warehouse][Only $85.99]Dynam Scout 980mm Wingspan Trainer RC Airplane PNP BG Tobey Banggood.com 1 Feb 23, 2017 06:43 AM
Discussion 72" Trainer Power System robski111 Power Systems 8 Aug 08, 2016 10:42 PM
Any J-3 cub owners out there (the HL, 72 inch wingspan version), with suggestion/vids Longarm Scale Kit/Scratch Built 1 Aug 14, 2004 10:19 PM
BIG DADDY Scratch Built DuskStik! 72" Wingspan!!! flytowner Parkflyers 132 Aug 21, 2002 02:08 PM
